Question about Samsung HL-P5063W 50" Rear Projection HDTV
We understand that your problem is: I have a Samsung Model HL-P5063W, It won?t turn on anymore. What it is happening is that when the TV was being turned it shows 3 blinking lights. TIMER and LAMP in green color and STANDBY/TEMP in red color. My problem started about 8 weeks ago. So far I have replaced the bulb ($145.0) and color wheel ($114.00) , do not know how many more spare parts I would need to buy to have the TV repaired. I have been told the following can be also wrong powerboard , or power supply , ballast ,fans, sensor board on the colorwheel housing, and light engine . How do I know the part number to order? It seems a lot of spare parts to buy, at this point what is better get a profesional service or continue buying more spare parts, so far I have spend about $250.00 In addition can you help to identify what is the black sticker on the color wheel silver bearing and how check the color wheel connections top the DMD board, especially the flat ribbon cable? I got these information from some information I got on line below" " "Make sure the timing mark (black sticker on the color wheel silver bearing) has not fallen off or been damaged. This can also cause your TV to turn off after a few seconds when it can't detect the colorwheel actually spining." "Be sure to double check you color wheel connections top the DMD board, especially the flat ribbon cable. Although it can go on both ways, it will only make connection one way. I believe the metal connection on that flat ribbon cable will face the rear of the set, but I may be wrong.
  • proano1 Sep 12, 2010
    Thank you . I understand the light engine is too expensive to replaced
    it. I would insist further in the color wheel issue as per your
    recommendation.
    I am not sure about how to check the version though
    here is what I have in the rear back
    MODEL HL-PS063W
    SVC Model
    HLP50630WX/XAA
    AC 120V 60
    Hz
    Manufactured
    Sep-04
    L62B
    AT50L3
    Seems to be L3 version? if is that the case I did order the correct
    color wheel ( BP96-0067A) from Samsung.
    So assuming I have the corect color wheel What I can do now? remove the jumper? or check again the cabling , I am no sure how to check again, I have changed the color wheel several times , but I have not try yet to install back the original one to see if the problem I had initially repeat.
    Regards
    Fernando Proano
  • proano1 Sep 13, 2010
    Dear guru
    Finally I got color and sound. I did reset the lamp using user factory reset function with the remote control and
    now color are not good. How I can adjust the colors? I tried all from
    the remote control and still have the same problem. Do I need to use the
    jumper to fix the color that may be reversed color?
    Regards
    Fernando proano
  • Samsung Master
  • 19,396 Answers
About color wheel. I think that the wiring issue is only depending on the replacement sent. There are two different wheels mounted in this TV. The issue is explained here.
Parts are listed here.
Parts such as the light engine will make repair not worth, this parts are often not held in stock by distributors. To give you an idea, here the light engine.
Problem in any case is likely the color wheel. Regarding the stickers, this is used for calibration(CCA), but not all color wheels use the sticker. I think this Samsung has no sticker.
Posted on Sep 12, 2010
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
The unit only powers on sometimes or won't turn off unless unplugged. The color begins to fade and go out after being powered on for awhile
Go to online Encompass Parts Distribution and type in your model number they will have a listing for Boards and board numbers Color wheel BP96-00674A, Lamp BP96-00608A these amost common Parts Call Encompass Parts 1-800-638-3328 if you need anymore help let me know I have same TV. just repaired it 2 months ago.
Nov 14, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HL-P5063W speaker replacement.
Here is Samsung service locator where you can put in your zip and then find where to buy your replacment speaker.
http://www.samsung.com/us/support/repairlocation/serviceLocator.do?group=&type=&subtype=&model_nm=HL-P5063W&dType=D&mType=UM&vType=R&prd_ia_cd=02010300&acc_ia_f
Dec 31, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
My TV makes me wait...
Best suggestion = change lamp
second = change lamp fan
last = change engine
Oct 24, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HL-P5063W 50" Rear Projection HDTV Logo
107 people viewed this question
Jerry Greenberg
Jerry Greenberg
