Question about HP L1706 17" LCD Monitor
HP L107 Flat Sceen won't turn on, it just beeps and the light flashes.
  • 732 Answers
Crazy kit157, If pc is ok with different monitor connected then go here: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Do some reading and see if something sounds familiar even though your's is different model!! Remember this, for at least the next 5 years! ALL BRANDS of CCFL back-lit monitors use the same basic electronics design and operating principles to display information on their lcd panels!!! If you still need or want more information, just return to this original post and do additional comment for us tech's to read. Povide "date of manufacture" and correct model number. rate this response ONLY if you have done your "research" first and feel that it was helpful in understanding unit's problem. 12fixlouie north of Windy City.
Posted on Sep 12, 2010
When I turn on the tv it beeps 4 times then the power button light will flash 3 times in a row but the power will not come on it just keeps flashing 3 times
power will not come on Linda, could be bad capacitors or cracked/bad solder joint,bad main logic board.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung TV won turn on blinking red light explained fix 18
Sony Bravia TV kdl red blinking led light error codes solutions
Apr 02, 2016 | Televison & Video
HP desktop computer makes many long beeps i a row and won't turn on
Those beeps are warning beeps look up what the beeps mean for your machine.
Jan 02, 2013 | HP Computers & Internet
Stunt copter won't sync
I presume you have lights & sound on the controller when you turn it on - fourteen quick beeps and then a different toned fifteenth beep. The screen lights (blue). Insert the battery (lettering facing up toward the helo fuselage unitl it's seated all the way - an LED inside the fuselage, visible from behind, quick flashes and then begins a slower blinking.
Once the helo battery is inserted, turn on the controller, which starts the aforementioned beeping. On the last controller beep the helo's LED will stay lighted, indicating the helo & controller are synched.
I had a problem making sure the battery was inserted all the way into the helicopter. You'll know it's inserted properly when the LED inside the helo flashes.
Dec 26, 2012 | Brookstone Stunt Copter RC Helicopter
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
My model hlp 4674 wx/xaa sceen won"t do anything
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Samsung CXM2785TP 27 in. TV/VCR/DVD Combo
My tv ill turn on to a white sceen and then beep very loud and then it goes black and then goes white again and beep and i continues to do this until i unplug it
The tv Tuner signal board is the causes and the problems,it dead amd process the incomming air signal.That the board,where the incomming broadcasting tv signal cable plug into it.Tries websites like Shopjimmy.con,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Dec 15, 2010 | Philips 19PFL5422D Television
The sceen wont turn on the little light is flashing but the sceen doesnt turn on the computer is perfectly on but sceen doesnt see that >.>
First make sure that your VGA cable comming from the back of your monitor is still connected to your computer, check both sides on the back of your copmputer and your monitor if they are both in then maybe your cable is bad.
Sep 03, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
HP L1706 17" LCD Monitor Logo
67 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
