Question about Microwave Ovens
When one of the gas hobs is on ,it does not burn with a blue flame but a more yellow one .also black soot forms under the burner plate.it is on lpg
    Problem Solver:
  • 12 Answers
Have to adjust the piolot lights for the amount of gas coming out. U have too much gas coming out(yellow flame). On older gas ranges, there was a small screw between the piolot light & burners that had to be adjusted. (if this is a older model) have to turn the screw just a little at a time, till ur flame returns to blue on ur burners. Hope this helps.
Posted on Sep 12, 2010
I clean the burners and the ignite it is not working if i used a lighter the back tow burners will turn on but not the front ones
Sometimes when we clean the burners we get some debris or gunk into the gas outlets. I always take a toothpick and clean out the gas openings. Be very careful that you don't break the toothpick off in the opening. Once you've done this, use a lighter at the burner and turn on the gas. You should have a flame. Let the flame burn for about 5 minutes to burn off any more "gunk" that may be in there. Also, if your burners have covers, make sure they are in place before you light the burner.
Depending on the age of your range, you might need to clean around the igniter. Some are concealed and you can't reach them. Those that are not concealed can be cleaned by wiping with a soft, dry cloth.
I hope these suggestions help you get your range working again. If they do, please come back to Fixya and rate my advice!
Aug 15, 2011 | Microwave Ovens
Whirlpool model SF3020EKQ3 was converted to LP oven lights nice blue flame but flame is very small oven does not get hot enough
HI,
If your able to adjust the orifice hood to the oven, then turn it counterclockwise unit the burner is full and minimal yellow flickering is present. If you go too much, this can be deadly can cause carbon monoxide to admit into the kitchen during use. I have found adjusting while the burner is on is the easiest way to make sure it is correct, use caution....
I hope this helps
Jul 23, 2011 | Microwave Ovens
Low flames on my hob when all 5 burners are on
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Apr 21, 2011 | Microwave Ovens
When stove is on a yellowish orange flame comes from burner.This has not occured until now. We own this viking oven for about 10 yrs without any issue whatso ever. Can you help to resolve this issue
You need to replace the burner if you want blue flame. Since its 10 years old, it's about time to replace the burner with similar size and shape. Old burner have big hole causing yellowish flame compare to new one.
I hope I solve your problem.
Mar 30, 2011 | Microwave Ovens
All 5 burners are burning orange-yellow flames.
According to this thread:
http://www.dslreports.com/forum/r23696179-Gas-stove-orange-flame
It sounds like it is impurities in your (or more likely your suppliers) gas line. If it goes away but reoccurs semi regularly, then I would guess this is what it is.
If it is happening all the time, or you are concerned about it, call your gas company and ask them about it. I am sure they havve heard of the problem before.
Good Luck!
Mar 03, 2011 | Microwave Ovens
I have double cylinder fecility of Indane LPG gas. Now I have shifted to a house fitted with Adani gas pipe which I am not using as I am staying on rent and don't want to loose my cylinder membership. I...
As far as I can see it, if you want to use your cylinder gas then you will have to collect it yourself if there is no company in your area that sells LPG. To use pipes gas you will have to change the burner mixture setting on your cooker otherwise is may not burn properly.
Stupid rules I know.
Dec 31, 2010 | Microwave Ovens
The gas stove fire burns with black soot and is only 1 month old
Gas should not burn with soot, if it does it is dangerous as poisonus fumes will be produced as the air/fuel mix is wrong.
Call a qualified gas engineer to check out the installation and make it safe.
Nov 11, 2010 | Microwave Ovens
Hi, got old Eurolec Gas oven/hob. Hob lights up fine. Was cooking in oven all morning, no probs. Tried to light oven for evening meal & gas will not stay lit, goes out once ignitor & temp' dial...
Hi, your thermocouple is faulty, it is the little probe like thingy that sticks up into the pilot flame. It is there for safety purposes, detects flame and holds a valve open magnetically to allow the gas to pass through. Try giving it a clean with a scourer, sometimes works, or your pilot flame is not big enough, could be low on gas or unit needs a service Kristian KJ Tech
Sep 15, 2010 | Microwave Ovens
On Dacor cook-top. LP gas, what is recommended pressure (inches of water) in manifold? Have one burner of 6 that blackens cookware.
For LP you should be right around 10" WC....to high of pressure will give too much gas and burn rich... and make the soot that makes the cookware black...
heatman101
Sep 14, 2010 | Dacor Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
