Question about Polaroid i531 Digital Camera
It wont stay on
My camera wont stay on...it comes on for like a second an shuts right back off with 3 beeps...and the shutter is stuck on opened..ive replaced the batteries an everything???
  • 8 more comments
  • kurtis86 May 19, 2008
    i drop it and now it want stay on, it will beep 3 time and go off
  • Mary kelpine Jun 02, 2008
    My polaroid i531 has the same problem . Lens won't close , When I turn it on it starts to show display, beeps 3 times and shuts off. I have replaced the batteries,
  • brookescam Jun 16, 2008
    Camera will not stay on. Lens is open. Changed batteries, tried connecting USB to computer
  • 1nyzshag Jun 25, 2008
    I've had this problem just now with my i531. First, I turned it ON, got a quick three flashing green lights and goes OFF instantly, however, the shutter lens stays OPEN and won't close.
    I removed the batteries and start turning it ON again but this time it won't turn ON now, no flashing greens whatsoever, the shutter lens still OPEN. Replaced batteries already but it didn't solved it.
    My nth try with a pair of freshly purchased 2400maH didn't worked either. I brought it back to the storage box now frustrated!
  • sparky36 Jul 25, 2008
    when i have the sc card in there is no display at all take the sc card out and there is only for a sec the green light flashes and 3 beeps then shuts off i have chaged the battreys but the same happens
  • Anonymous Jul 28, 2008
    my digital camera does the exact same thing, I have tried to wiggle the lens, and still no budge.
  • Anonymous Jul 29, 2008
    same thing... turns on and beeps then shutter is stuck
  • timwscott Sep 01, 2008
    After it turns on, I can take one pic, sometimes two, then the thing shuts off. [email protected]
  • nathaly07 Sep 19, 2008
    my camera wont stay on, turns on for a few second, the lens wont retract. but it does not beep before it turns off.
  • cjsmama1222 Sep 30, 2008
    My camera is doing the exact same thing. I push the power button, the green light flashes, the camera pops on for a second, it beeps 3 times and then the camera turns off.
Mine is not jammed but it still wont come on it beeps like the batteries are dead(but brand new) and the lense retracts and everything but it acts stupid!! like the batteries arent strong enough...
Posted on Oct 02, 2008
    Problem Solver:
  • 6 Answers
Look at the lens from all angels and you'll be able to tell that it is jammed. wiggle to set the lens back into position. i heard a snap, turned the camera on and it now works!!
Posted on Jun 28, 2008
The same thing happend to me just now... you have to wiggle the lens untill it goes into place then it should retract when you turn it on. :]
Posted on Jun 14, 2008
SOURCE:
Samsung digimax s500/cyber530 won't start with new batteries
I have a samsung digital camera digimax cyber 530 - just replaced batteries and camera wont start, i get 3 flashes from the green light screen nw comes on then goes off & the lens wont retrack back in the camera
Oct 20, 2009 | Cameras
Won't stay on even with new batteries- it beeps then turns off
my camera is doing the exact same n i'm hunting the net right now for some kind of solution!! :( i think its something to do with the lens, mine was completely stuck, but i gently pushed it n it went back in and moves in and out fine, but the cam still comes on for a couple of seconds makes this wierd beep n goes off again!
May 27, 2009 | Samsung S760 Digital Camera
Occasionally while shooting in auto/portrait my shutter will stay open for 1 second or longer, for no reason
Have you tried to reset the camera and reboot the firmware? I had that problem with a friend's camera and it simply worked.
Other thing is: are you using the original battery or a third party battery? sometimes bad quality batteries are creating such a problems like shutting down the camera, shutter lags...
I hope it helps, if not let me know
Nov 03, 2008 | Canon EOS 40D Digital Camera
Kodak easyshare c533 lens is stuck
after 4 seconds view screen pic melts and goes blurry
Oct 19, 2008 | Kodak EasyShare C533 Digital Camera
Sumsung digimax
get a butter knife or any thin object like that and use it to push out the lens and turning it on at the same time you will hear a clicking noise which is normal once completely out, use your hand with a gentle but firm presure move it form left to right
and then hopefully it should work after that
x
Jan 14, 2008 | Samsung Digimax S500 Digital Camera
Shutter
sounds like the lil motor that is in charge of opening and closeing the shutter might have shorted out causing it to stick, or it could have just simply burnt out or striped the lil gears on the motor. If the shutter moves alil bit i would say you probably have a short in the shutter motor.
Dec 05, 2007 | Fuji Zoom Date 60 35mm Point and Shoot...
Will not turn on
Sounds like your lens is stuck. Try a gentle tug and it should open all the way. Then you can power your camera down.
Nov 01, 2007 | Samsung Digimax S800 Digital Camera
It dont turn on
I had the same problem. Try to turn it on, 3 beeps and then it would shut down. Screen would come on for that time. Also, the lens was stuck open. It wouldn't close.
I twisted the lens (gently) and it appeared stuck. A gentle screw motioned seemed to free it. I hit the power button and it come on, but this time no 3 beeps and shut down. I then turned it off and this time the lens retracted and closed.
So, it appears that if the lens gets stuck open, it has a shut down feature that doesn't allow the camera to go further into its operation modes. I believe this stuck open problem occured on our camera when the batteries went low.
Again, a second of gentle twisting seemed to unstick it and with fresh batteries in, it was able to operate and shut down properly.
As far as batteries, I use the rechargeable Ni-Cad 2500 mA. They last a while.
Blessings to you!
Jun 02, 2007 | Samsung Digimax S500 Digital Camera
Lens problem
If you've replaced the batteries with fresh ones, it probably has a broken zoom assembly. It'll have to be replaced by a repair shop.
Dec 13, 2006 | Canon PowerShot A520 Digital Camera
Polaroid i531 Digital Camera Logo
382 people viewed this question
Top Polaroid Cameras Experts
Ekse
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
