Question about Siemens Gigaset 8825 Cordless Phone
I have a Siemens Gigaset 8825 phone system and just bought the HP 8500 All-in-One Officejet Pro. When the Siemens is plugged into the Ext-2 port, the fax test for the HP fails, stating that I am using the wrong phone cord. The problem is not the cords (using 2-wire phone cord), but rather is the phone. When I plug another phone into the system, it works OK. Do I need a new phone system, or is there a fix for this apparent incompatibility?
  • Ben Anderson Sep 12, 2010
    I have tried all phone cord options and the problem persists. It may be that the Gigaset 8825 is not compatible with my new HP printer. Has anyone successfully used the Gigaset 8825 in combination with the fax function of the HP Pro 8500 All-in-One printer?
  • 10,515 Answers
Hi,,
To be honest, i have never seen such a problem between Siemens and HP officejet printers.As of now, i have not even heard of any patch / bypass for the same. Make sure that the cord is correct. If the cord is correct, there is no other option than to use a different phone.
I wish i could have a better solution.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 12, 2010
    Genius:
  • 1,416 Answers
From your statement it show that the phone (Gigaset 8825) to be wrong in function this is because the wire that you are making use of on the connection might not be compatible with phone to carry out is assignment a it expected of it ,
what you are to do to get well the problem is from, first of all make use of the other phone wire that work out with the phone Gigaset 8825 to test run your Gigaset 8825 phone to sell if it will work then the problem is not from the phone it from the wire that you are making use of for the connection ,but if the problem remain the same then it the mean that all test running has been carry out to determine well the problem is from,
mean that you will have to return the phone to store of purchase that is if the phone fail to out the other phone wire but if it work with it then also mean that the wire is not compatible with the phone which will need a replacement.
please note this information DO NOT damage the HP 8500 all in one before going to the store for replacement .
hope this help is any way ?
thank you and thank for using fixya.
Password
Complete the following steps to reset the PIN on the 8825 back to 0000.
1. Press MENU.
2. Scroll to System Settings but do not press SELECT.
3. On the keypad, enter *65# (Star, 6, 5, Pound).
4. It will display "System PIN Reset" and return to the idle screen.
Sep 26, 2009 | Siemens Gigaset 8825 Cordless Phone
Change recorded message
Please follow the steps:
1. Press MENU
2. To select "ANSWERING SYSTEM MENU?", press SELECT
3. Scroll to "GREETINGS?" and press SELECT
4. Scroll to type of desired message and press SELECT
5. Scroll to "RECORD GREETING?", and press SELECT
6. Record a message or greeting through the base speakerphone or base station handset. 7. Press SELECT to play back greeting/ message.
NOTE: To avoid background noise, record message through the corded handset.
Sep 12, 2009 | Siemens Gigaset 8825 Cordless Phone
I have a gigaset 8825. I have a "distinctive ring" problem
I have the same phone system, and *think* you may be able to fix the problem by adjusting the amount of rings before answer on each unit. This assumes there is an auto answer system engaged. Hope that helps some.
Ken Lundberg
Jun 19, 2009 | Siemens Gigaset 8825 Cordless Phone
Siemens gigaset 8825 has a problem with the base unit
http://kb.efficient.com/display/1n/index.asp?c=&cpc=&cid=&cat=&catURL=&r=0.5180628
Jan 08, 2009 | Siemens Gigaset 8825 Cordless Phone
Gigaset 8825 new
They are not manufactured anymore, but you can buy used ones off Ebay.
Jul 07, 2008 | Siemens Gigaset 8825 Cordless Phone
System pin unknown
I will email you steps to restore factory default PIN...send me a note
Nov 20, 2007 | Siemens Gigaset 8825 Cordless Phone
Power supply gigaset 8825
The power supply for the 8825 base is to be 13 volts AC, rated at 850 milliamps or higher. You can go anywhere from 13 up to 15 volts without hurting the unit, and a higher current rating is even better. We actually make them ourselves through bulk purchases of varieties of power supplys. Your next delimma will be the plug size, it is a pretty common size, most universal adapters will have the right size of the outer and inner connections.
Nov 16, 2007 | Siemens Gigaset 8825 Cordless Phone
Siemens gigaset 8825 handheld phone
Yes you can go to www.cordlessrepair.com for all your Siemens purchasing and repair needs.
Oct 10, 2007 | Siemens Gigaset 8825 Cordless Phone
Siemens Gigaset 8825 Cordless Phone Logo
169 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
