Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Water is leaking from my badger 1/2 hp insinkerator. it appears that water is dripping from one of the screws from the bottom
  • Ace Hardware Master
  • 43,501 Answers
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
c
Posted on Sep 29, 2010
Insinkerator badger 1 leaking from the bottom
check to be sure water is not leaking down the side from d/w drain or sink drain if not look inside with flashlight to check for rust if rusted trough time for a new one
Aug 10, 2015 | In-Sink-Erator InSinkErator Badger 1, 1/3...
My sink erator badger 5 is leaking at the bottom, should I replace it or try and stop the the leaking.
mine was leaking from bottom, dripping off power cord...pulled it apart..the pan that separates the water and food from the electric motor was developing pin holes from corrosion...I dont know that you can get this part...was thinking about tacking a small weld...but best off getting a new one...I am sure it has served...
Jan 12, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
WATER DRIPPING OUT OF BOTTOM OF UNIT, WHAT'S UP?
heatman101
e
Sep 17, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: leaking out the bottom...
Here is a tip that I wrote about how and where a garbage disposal will leak andwhat can be done to fix it.
heatman101
May 17, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water has begin to spray/leak when using the
heatman101
g
May 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I just noticed that my insinkerator Badger 5-75
heatman101
May 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Drips from bottom of Inskerator Badger 5
Obviously you didn't like what I answered you before, but if that is not the case and the leak is infact coming out of the bottom of the disposal then you are really not going to like the bad news I have for you now...
I had to remove a disposal today to fix a sink that is exactly like yours, so I took a close look at it an the bottom line is that if you are getting water out of the motor then you have a seal leaking where the motor shaft goes into the grinder part.
From what I can see on from this exploded diagram that is not even repairable and the part you would need is not available.....
So... it looks like you need to look for a new one... or check to see if you have had it less then two years...they do have a two in home warranty...
sorry I can't give you better news...
heatman101
May 07, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water is coming out the bottom of my Badger 1 disposal. Solution???
Check the fittings, the hoses could be loose... If the leak isn't coming from there then you have a seal leaking or a rust through that is causing water to leak and would need to replace the disposal.
Oct 06, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaks from two locations on my Badger 5, 1/2 hp disposal
These holes are probably due to wear, as they are at about the level of the cutter. In general, residential disposals are not repairable and once they begin to leak, they must be replaced. The Badger series is Insinkerator's budget line and probably has about a 5 year lifespan with normal use.
Dec 20, 2008 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
1,398 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
