Question about Zanussi TC7102W Electric Dryer
Noisey motor - Zanussi TC7102W Electric Dryer
  • Zanussi Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
eru
Posted on Sep 29, 2010
I have a 1999 Sable and the ABS motors seem to come on and off randomly. I cant aford to fix the problem. Perhaps pulling the fuse and disconnecting the ABS system would be an easy solution?
yes you can do this then car will revert to conventional braking system ,but the ABS motors do run randomly to maintain pressure so its nothing to worry about perhaps motors are a bit noisey which is why you can hear them ,I would advise you to leave well alone to be honest as i think teh system is working ok abeit a bit noisey
Mar 12, 2011 | 1999 Mercury Sable
Noisey suction motor
These motor/pumps often are noisy, but if this is something new, the motor/pump bearings could be dry or worn out. Try a little WD40 on the bearing, but you will have to open the unit and it may be assembled with tamper proof screws!
Jan 19, 2011 | Tilia FoodSaver V2240
I have a ticking in the top of motor sound like it,s in the head
YOU HEAR VALVE LIFTERS.MOST TIME YOU HEAR VALVE LIFTER NOISE.LIFTERS ARE WORN OUT OR OIL + FILTER COULD NEED CHANGING.BECAUSE DIRTY OIL WILL STOP UP LIFTERS CAUSE THEM BE NOISEY.YOU CAN ADD BOTTLE OF MARVEL MYSTERY OIL IT WILL HELP QUIET DOWN NOISEY LIFTERS.
Oct 20, 2010 | Mitsubishi Montero Sport Cars & Trucks
Dryer squeqks while rotating
It could be a noisey idler pulley that belt rides on, or a noisey drum bearing or drum glides, or even possibly a motor bearing going bad. Would need to be checked by repairman to determine exact cause.
Feb 04, 2010 | GE DBXR463GB Gas Dryer
Fan too noisey
that fan is called a inducer motor. remove the metal cover which the motor is attached to and adjust the small blower wheel. if that does not due it, replace the motor
Dec 15, 2009 | Goodman GMS90703BXA Heater
Dryer runs for few minutes and stats to get noisey
would help if knew the bran and mod#,sound's like you have a bad motor.
Nov 22, 2009 | Kitchen Ranges
Low speed cycle trips motor thermo coupler safety switch
WITH THE MACHINE OFF YOU SHOULD BE ABLE TO SPIN THE AGITATOR FREELY IF YOU CAN'T THEN YOU HAVE TRANSMISSION PROBLEMS. IF YOU CAN THEN YOU HAVE CLUTCH PROBLEMS. THIS SITE MAY HELP YA www.repairclinic.com
Apr 07, 2009 | Washing Machines
I have a 2003 Mercedes C240. When it starts up there's a humming noise that quits after a few minutes, but when the car starts moving it starts clicking.
THE HUMMING NOISE IS YOUR SECONDARY AIR INJECTION PUMP. THEY TEND TO BE NOISEY AT START-UP. IF IT IS NOT WORKING COREECTLY IT WILL SET A CHECK ENIGNE LITE. THE CLICKING NOISE IS NORMAL IF IT GOES AWAY AFTER WARM-UP. THESE MOTORS ARE NOISEY WARMING UP DUE TO THE HYDRAULIC LIFTERS.
Mar 21, 2009 | 2003 Mercedes-Benz C-Class
Very noisey
Hi there. This noise you are hearing is coming from the gear case (transmission). You may have some alignment issues within the gear case that is causing the grinding. there also is a clutch system here in this location as well. i would have a look before the gear box locks up. this will shut the entire unit down if so.
please rate and god bless.
Mar 17, 2009 | Washing Machines
Washing machine noisey on final spin
this isn't a problem usually every washing machine is very noisy on a final dry its normal
Oct 15, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi TC7102W Electric Dryer Logo
151 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
