Question about Fisher and Paykel Washing Machines
We have a Model GWL 15 Washer that is about 3 years old. We have power to the washer, but it seems to have no power. No lights, nothing at all. We tried the unplug for 60 seconds and replug, but still no sign of life. Any suggestions? Does this machine have some sort of reset?
  • 343 Answers
F&P machines are very simple mechanically, but quite complicated electronically.
If you have no lights on the display and power is getting to the machine the most probable cause is that the controller board and/or the internal fuse has failed. The question is why?
It's probably best in the long run that you call a F&P tech because he/she can test all the components that may have caused the controller to fail.
It's common for a primary fault to create a secondary fault further along the in the system.
Replacing a failed component without checking the rest of the machine can result in the part failing again, which is expensive.
A tech should warranty their work, and be able to show why the part(s) failed.
Probably not what you hoped to hear, but cheaper in the long run!
Good luck....Nomess
Posted on Sep 12, 2010
My 2 year old Whirlpool washer does not work ...with power on I get no indicator lights ...it just hums and acts like the drum is trying to move ...nothing working ...I can have lid open and it still hums...
you did not give model number, but on some you can unplug washer then hold down power button while plugging it back into power and that will reset the control panel. worth trying. good luck.
Mar 03, 2015 | Whirlpool Washing Machines
GWL Washer won't spin only beeps; Diagnostic lighs:the third light is lit up green in the bank of lights on the left; the first light on the right is lit up orange and the third is lit up red. Thanks,...
GWL Washer won't spin only beeps; Diagnostic lighs:the third light is lit up green in the bank of lights on the left; the first light on the right is lit up orange and the third is lit up red. Thanks,Hepi
Jul 24, 2011 | Fisher and Paykel GWL11 Top Load Washer
Model gwl 15 us not draining
find black rubber drain hose under machine and squeeze several times to loosen soap and hair gunk.
start the mahine on the rinse cycle. This should start the draining process.
Dec 08, 2010 | Fisher and Paykel Fisher & Paykel Washer
GWL 11 washer. Water does not come in when power
Hi just read your posting.Now what water setting have you selected?Is it warm cold or hot?Does the machine stop and beep with a series of lights that come on?If there are lights that come on when it beeps, they will be in a row of 8 lights.Starting from left to right which ones are lit?Is it the 3rd and 6th or 1st and 7th --etc--?Now if you have an LCD display what error code is it showing?Please reply with additional information and I can help you rectify this fault.
Jun 23, 2010 | Fisher and Paykel GWL11 Top Load Washer
POWER UNIT IS NOT WORKING
sounds like the motor controller is faulty.if u have power to unit and the lights aren't on then it is either faulty controller, or faulty pump or best case broken power wire.please turn power off b4 u work on it. dont want any accidents. please reply 4 more help.
Apr 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
My GWL 15 pumps so hard water comes out of the
A washer cannot pump the water out too fast, regardless of what you have done or have been told, the problem is too do do with the drain outlet, I suggest you completely take apart the stand pipe and any other pipes connected, and thouroughly clean them .
Please rate my solution.
Thanks.
Jun 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
Beeps 3 times when Power button is pressed
hi im josh in cebu phils. the problem is your washer is on a short circuit. try to check the wires if it has no cut.or loosen. good luck.
Dec 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
51 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
