Question about Canon NP 6551 Black and White Copier
E531 Error code 531 on my Canon 6551 copier. What is it? Is it related to the stapler in any way (I had a jam that I think is cleared)
  • 18 Answers
Check your stapler. If you removed a jam from the sorter you may have accidentally moved the stapler so it is not sitting at a 45 degree angle when you open the front door of the sorter. There's a little lever you can push to swivel the stapler, however don't try to force it. You may have to pry up the plastic lock that is under the stapler with a small screwdriver. Sometimes the stapler assy has to partially removed (slid to the front) of the sorter to be able to see what you're doing.
Posted on May 26, 2008
Error code E000002-0000
dispite the error, you should be able to enter the service mode.
Procedure for service mode is:
- press * ( additional functions - user mode )
- press 2
- press 8
Then choose COPIER, then under FUNCTION screen is CLEAR.
But you only can try to clear the error like E000, E001, E002 and E003.
Wich error code is apearing on display?
Here is some examples of error code:
E000 Heater temperature fault
(fails to increase)
E001 Overheating detection error
E002 Heater temperature error (fails to reach
specific level; inadequate increase)
E003 Heater temperature error (abnormal
drop; low-temperature detection)
E007 Fixing film rotation error
E010 Main motor rotation error
E014 Fixing motor rotation error
E019 Waste toner case full, sensor error
E032 DA unit communication error
E051 Horizontal registration HP
detention error
E064 Power supply voltage error
(high-voltage error)
E100 Laser BD error
E110 Polygon motor rotation error
E202 No. 1 mirror base HP detecting error
E204 ADF image leading edge signal
detection fault (absent)
E220 Lamp ON error
E225 Standard white plate/edge white
plate read error
E240 Mcon-Dcon communication error
E243 Mcon-control panel
communication error
E248 Backup (EEPROM) error
E261 Zero-cross signal error
E302 Shading error
E315 Image data processing error
E601 Image transfer error
E602 Hard disk error
E604 Image memory fault
E605 Image memory battery fault
E606 HDD error
E674 Fax board error
E677 PDL board mounting error
E710 IPC initialization error (Rcon)
E711 IPC register error (ctrl)
E712 Communication error (with ADF)
E713 Communication error (with sorter
finisher)
E716 Communication error (with pedestal)
E717 Communication error (with ASSIST)
E719 Card reader, coin vendor
communication error
E732 Reader communication error
E733 Printer communication error
E737 SDRAM error
E740 Ethernet board error
E741 PCI bus error
E742 RIP1 board error
E743 Mcon-Rcon communication error
(Rcon detection)
E744 Language error
E746 Resolution conversion board error
E803 MPWS power supply voltage error
(low voltage error)
E805 Fan rotation error
E901 Pedestal main motor rotation error
[ADF]
E420 Back-up data read error
E421 Back-up data write error
E422 IPC error
[Saddle Finisher-G1]
E501 Communication error (Punch unit)
E505 Back-up RAM
E510 Feed motor
E514 Delivery motor
E530 Width plate shift motor
E531 Stapler motor
E532 Stapler slide motor
E537 Alignment motor
E540 Tray ascent/descent motor
E577 Paddle motor
E590 Puncher motor
E592 Puncher sensor error
E593 Puncher shift motor
E5F1 Saddle folder motor
[Finisher-J1]
E500 Communication error
E514 Stack handling motor
E530 Rear alignment motor
E531 Stapler motor
E537 Front alignment motor
E577 Delivery motor
E580 Delivery tray ascent/descent motor
E585 Stack handling error
If nothing of these helps, send more specific description of problem.
Hope it helps
Jul 06, 2010 | Canon imageRUNNER 2200
Tip
Error codes related to Canon ir 2200/2800/3300
(fails to increase)
detention error
E100 Laser BD error
E220 Lamp ON error
plate read error
communication error
E302 Shading error
E606 HDD error
finisher)
communication error
E737 SDRAM error
E741 PCI bus error
(Rcon detection)
E744 Language error
(low voltage error)
[ADF]
E422 IPC error
E505 Back-up RAM
E510 Feed motor
E514 Delivery motor
E531 Stapler motor
E577 Paddle motor
E590 Puncher motor
[Finisher-J1]
E531 Stapler motor
E577 Delivery motor
If the thermistor has a short circuit, the indication in service mode
(COPIER>DISPLAY>ANALOG) will be as follows from the start: FIXC=250°C
for the main thermistor; FIX-E=310°C for the sub thermistor.
Error codes from E000 to E003 can be in some cases reseted from service mode: PROCEDURE:
Press*
Press2
Press8
Press*
Navigate to: COPIER>FUNCTION>CLEAR>ERR.
Turn off and on.
on Aug 03, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 4835
Canon 4835 E000 Low fuser temperature E001 High fuser temperature E002 Low fuser temperature E003 Low fuser temperature E010 Drive E030 Counter E080 Color change board problems E081 Color horizontal motor problem E082 Color horizontal motor problem E083 Color problem in vertical direction E084 Color problem in vertical direction E085 Color problem in vertical direction E086 Color unit claw release problem E089 Color change incomplete E100 Laser problem E110 Laser motor problem E140 Laser unit E203 Scan drive problem E210 Lens not home or won't leave home E240 DC controller E401 Document feeder pick up motor E402 Document feeder belt motor E403 RADF feed motor E404 Document feeder motor E411 Document feeder sensor E500 Sorter to DC control interface problem E510 Stapler/sorter motor E530 Stapler swing motor E531 Stapler swing motor E540 Sorter bin motor E541 Sorter bin motor E710 DC controller
on Jan 19, 2010 | Office Equipment & Supplies
I have an E0 code
Check the main thermistor,the thermal switch,the heater lamp.This components it is in open circuit.Reset the error code in service mode.
Sep 27, 2009 | Canon NP 6551 Black and White Copier
The problem in canon 6050
this error from sorter/stapler unit if this problem is repeated
disconnect the sorter and use copy tray,sorter must be serviced
E530
Main Cause The alignment plate home position sensor (PI6) is faulty. The alignment
motor (M3) is faulty. The finisher controller PCB is faulty.
Mode of
Detection
0001 The alignment plate does not leave home position when the alignment
motor has been driven for 2 secs.
0002 The alignment plate does not return to home position when the
alignment motor has been driven for 2 secs.
E531
Main Cause The stapler home position detecting switch (MS7) is faulty. The stapler motor
(M6) is faulty. The finisher controller PCB is faulty.
Mode of
Detection
0001 The stapler does not leave home position when the stapler motor
has been driven for 0.5 sec.
0002 The stapler does not return to home position when the stapler motor
Jun 06, 2009 | Canon NP 6050 Copier
Tip
ERROR codes Canon 4540
Canon 4540 E00 Low fuser temperature E001 High fuser temperature E010 Main motor clock pulse E011 Bind or load on main motor E020 No TF for 3 minutes E030 Copy counter E050 Duplex unit E201 Scan motor E203 Scan motor E210 Lens home E240 DC controller E241 DC controller E320 CCD E400 DC controller, 24V E500 DC controller, 24V E510 Finisher feed motor E520 Stacker motor E530 Guide plate shift motor E531 Stapler motor E620 DC controller, edit board
Tip
ERROR codes Canon 4035
Canon 4035 E000 Low fuser temperature E001 High fuser temperature E010 Main motor clock pulse E011 Bind or load on main motor E020 No TF for 3 minutes E030 Copy counter E050 Duplex unit E201 Scan motor E203 Scan motor E210 Lens home E240 DC controller E241 DC controller E320 CCD E400 DC controller, 24V E500 DC controller, 24V E510 Finisher feed motor E520 Stacker motor E530 Guide plate shift motor E531 Stapler motor E620 DC controller, edit board
on Jan 18, 2010 | Office Equipment & Supplies
Error code E522. How to fix this?
You have an issue with your staple finisher, probably need to inspect the stapler unit itself to make sure nothing is jammed in it and it moves freely. If you can't clear the error then most likely the unit is defective.
Hope this helps,
TankMurdock
Apr 24, 2009 | Canon NP 6551 Black and White Copier
Error Code: E631 & E632 on Canon NP6551
make sure the error code you gave to us is E631 & E632 notE531 & E532, you number not on our menu, if my number is correct that's mean stapler motor defect, replace it!
Oct 03, 2008 | Canon NP 6551 Black and White Copier
E531 error code
Did you remove the jamed staple? Try to disconnect the finisher and power up just the copier it self. Once, warmed up, try to turn it off and reconnect the finisher again and turn the power on and see if the code is gone. Did you also try to leave the staples out and see what happens. Make sure the stapler can find HP. It could be a number things... Go simple first..
May 14, 2008 | Canon NP 6650II Copier
Canon NP 6551 Black and White Copier Logo
279 people viewed this question
old marine
old marine
