Question about Maytag Neptune MDE5500AY Electric Dryer
Squeaking noise while running - Maytag Neptune MDE5500AY Electric Dryer
    New Friend:
  • 35 Answers
Could be either or both, worn out:
1) Drum Rollers
2) Idler Pully
Posted on Sep 13, 2010
My new nordictrack 1750 is squeaking.
Talk to the manufacturer or take it back. It should not do this if it is brand new.
Jun 10, 2017 | Cars & Trucks
2007 cadillac esclade ext front end squeaking.
well it can still be anything, locating a steering/suspension noise can be hard. Based on what you typed, what first comes to mind is the steering pump is worn out. If it is more of a low whining sound instead of squeaking, its probably the steering pump.
Nov 01, 2016 | 2007 Cadillac Escalade Ext
Hoover 2300L 6.okg boss. Squeaking when agitating back& forth, not when spinning. Is this a bearing problem? & is it replacable. If so, from where in south australia? Or wherever.?
Washing machines don't usually run silently, but in most cases, a squeaking noise that occurs while the washer is agitating the clothing is not normal and signifies a problem. If the noise only happens when the washing is agitating, the problem is likely connected to the motor or your water pressure. Depending on the specific cause, you may feel comfortable fixing it yourself. Otherwise, call a professional.
Other People Are Reading
The Agitator
  • Agitators are located in the center of the drum, or basket, of top-load washing machines. Front loading washing machines do not use agitators -- instead, gravity moves the clothes from the top of the drum to the bottom. Agitators usually consist of a tall cone fitted with arms at the base. The purpose of the agitator is to rotate the clothes and soapy water around the tub to clean the clothes. The agitator itself is not usually the cause of the squeaking noise. It is powered by the drive mechanism, which consists of a motor, clutch and gears.
Motor Problems
  • A repetitive squeaking noise during the agitation cycle may signify a problem with the motor. Specifically, the belt on the motor may be wearing out. Some motors use rubber couplers, which also wear out easily. The belt is necessary for the agitator to turn, but over time, it wears thin, just like the belts in your car's motor. An easy way to test for this problem -- if you're handy -- is to take the belt off the motor and then run it. If the squeaking noise stops, the problem is indeed your belt. Of course, this means your agitator won't move. Replacing the belt should fix the problem.
Water Pressure Issues
  • The tub, or drum, fills with water right before the agitator turns on, and water continues to circulate throughout the washing process. As the tub fills and water circulates, you may hear a squeaking or squealing noise if you have high water pressure. This sound is caused by the force of the water moving through the pipes. To adjust this, turn the knobs on the hot and cold valves on the pipes that go into your washing machine.
Considerations
  • New washing machines may squeak at first as the parts "warm up," according to the GE Appliances website. The noise should disappear after five complete washing cycles have run on the machine. Unbalanced loads, overly heavy loads and loose items in the drum may also cause noise when the agitator comes on, but these things usually do not produce a squeaking sound.
Read more :http://www.ehow.com/info_12131280_washer-squeaks-agitating.html My Washer Squeaks When Agitating eHow
Jun 14, 2015 | Hoover Washing Machines
Squeaking noise from rear while driving
2 options
the brake pads are worn past safe and the small;; spring is running on the disc rotor , or there is a failing cv joint making the noise
Jul 06, 2017 | 2003 Chevrolet Avalanche
First it started squeaking when it was running. Now it squeaks and doesnt heat while running Model #GLER331AS1
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 13, 2011 | Frigidaire GLER341A Electric Dryer
Intense squeaking noise
When microwave is running, turntable squeaking when rotating. Can problem be fixed? Microwave is about twelve years old.
Mar 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Flair Cleaner makes squeaking noises
There are two items that could squeak:
If it squeaks when pushing/pulling it on carpet, WHILE NOT RUNNING, then the wheels are squeaking when they rotate on the wheel shaft. If so, one drop of oil at the shaft would fix it.
If it squeaks WHILE RUNNING, mostly while pulling backwards on carpet, then the belt is slipping. You may wish to set the nozzle height setting for a higher pile carpet, or could replace the rubber belt.
Oct 25, 2009 | Hoover Vacuums
Squeaking noise on my Proform 580 Cross walk
it is the edge of the belt on the deck. Walk in the middle. Eric
Aug 04, 2009 | Exercise & Fitness
With every step I get squeak / chirp while running on treadmill.
Check the knob used to hold it up in the folded position. While running, have someone pull it to the out position. That was the problem on mine. If it is, a little grease on the end of the rod should do it.
Jul 23, 2009 | Exercise & Fitness
Makes loud squeaking noise, cuts off after a few minutes
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
