Question about Yamaha RX-V861 Receiver
Yamaha RX V861 - Phillips DVD - No sound via digital coax
Recently purchased a new receiver, RX861 and tried connecting to a low end Phillips DVD that supports DIVX etc... I have the DVD connected to the receiver via component video and tried connecting the digital coax from the DVD to the receiver, but there is no sound. The picture is fine, so I know the component works. I also tried disconnecting the digital coax and using the RCA's into the receiver and no sound as well.
I have checked that the I/O settings on the receiver for output 5 which is the digital coax output are configured for DVD as well as the Digital Audio output on the DVD setup is turned on. There are tow choices PCM or All and neither solve the no sound problem.
Any ideas?
  • 979 Answers
Does your TV support "Line In" or "Aux" or "External"? if so plug your "Low end" DVD directly into the back of the tv and verify that you Can get audio. Quite a few DVD players do have a mute feature. Be sure this is turned "off"...accordianman
Posted on Nov 05, 2008
Digital Coaxial not working on DVD player
There might be several problems. As the projector has component only connections and the DVD player none, then if the Receiver has component out, you can hook it up to that. If the receiver has HDMI inputs then you can connect the DVD player via the HDMI socket to it. The Coax sockets on the DVD player will be for sound. Number one should be connected to Digital coax 1 and assigned for it.
It's possible that the sound on the DVD player is switched off on the coax or has the wrong format selected. You will need to see the player's menu for this, so if you can't see the screen using the projector, connect a TV instead.
However if the receiver has no component out and no HDMI sockets you will have real problems connecting the DVD and using the projector with it. Though you should be able to hear the sound via the Denon.
May 28, 2017 | Denon Audio Players & Recorders
HAVE A YAMAHA RX-V371 RECEIVER, NO CABLE BOX AND I CANT GET ANY SOUND FROM MY PHILLIPS HDTV.
if you have a coax digital out on your tv, why not use that, you have coax, optical, and hdmi inputs on your reciever, but the easiest, low cost way is the coax
Feb 20, 2013 | Yamaha RX-V371 A/V Receiver
No volume from surround sound system on dtvcbl cable, dvd or cd modes with yamah rx-v861 powered on.?
Have you looked at the manual? How did it fare using the set up test tones? Did you assign the digital inputs?
http://www.retrevo.com/support/Yamaha-RX-V861-Receivers-manual/id/2526ci757/t/2/
The unnamed sources probably have manuals, too.
Apr 26, 2011 | Yamaha RX-V861 Receiver
I just bought a yamaha rx-v365 receiver and hooked to my cable box via a hdmi and optic audio cable. this is working fine but i cant get a dvd player to work via a component and coax audio cable. neither...
Make sure that the DVD player is connected into the correct inputs on the receiver and that the receiver also has the correct input selected to play. If your TV also has component video inputs it is best to connect the player directly to the TV. Otherwise, make sure you have the TV connected to the receiver via component video out.
Nov 25, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
When connecting hdmi out from my panasonic blue-ray player to the dvd input in my yamaha rx-v365 there is not audio or video,why?
There are several video and audio inputs named DVD. For video you have HDMI, component and composite. For audio you have standard analog stereo and digital coaxial spdif input.
You need to configure the receiver to use the correct inputs - that means HDMI and coax. Also you need to connect the BD player via coax spdif cable to the receiver, because rx-v365 doesn't support audio via HDMI. If BD player has only optical output, use DTV/CABL HDMI input and DTv/CABL Optical input on the receiver.
Nov 23, 2009 | Yamaha DVD-S661 HDMI DVD Player
My Yamaha receiver stops working when using DVD plsyer
Is your BluRay connected via HDMI? and if so, are any other sources connected the same? if not, just for arguments sake, try hooling up the BluRay via component and digital coaxial or optical. Yamaha as well as all other AV receiver MFG have had big issues with HDMI processing. HDMI has been battling with the recording industry over HDCP and copyright issues on recording via HDMI. So, that's why HDMI has been so flaky. It's been thru versions 1.1,1.1a,1.2,1.2a,1.3a, and now 1.3b, which seems to work so far.... Anyway, sorry to stray off topic, however, HDMI has been a blessing and a curse for both professionals and consumers alike and has caused multiple strange issues with all products that use the technology. Hope this helps. Post a comment if you need further help. I've got lots of contacts for crazy issues!
Aug 18, 2009 | Yamaha RX-V861 Receiver
Hooking up a Yamahoa RX-V861 without a manual
If you jump on the Yamaha web site you can download the manual which will show you how to connect the speaker system. Hope this helps.
Regards
Nov 17, 2008 | Yamaha RX-V861 Receiver
No zone 2 sound coming from yamaha amp rx-v861
Had same problem. A and B speakers are basically connected together, and there is no way to get the same volume out of each speaker. This is not a multi-source receiver like Onkyo. Zone 2 needs to go to a seperate amplifier and select teh correct source on the fornt,
Jun 29, 2008 | Yamaha RX-V995 Receiver
Yamaha RX-V861 Receiver Logo
139 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
