What the parameters (The voltage and polarity) of hjwer adapter for the monitor VIDEOSEVEN E17PS?
  • 732 Answers
Grigory27419, I wonder why they didn't print or emboss the polarity symbol on or near the place where the plug is inserted into the back of the monitor? I saw a specification that said it requires 19volts dc. But it didn't mention anything about how much current ( 1.5amp, 1.7 amp, 2.1 amp???) it requires. More importantly, why or what caused failure of original "black-brick" supply??? 12fixlouie
Posted on Sep 13, 2010
I lost my 12 V 3A DC adapter for my LG Flatron E2360V-PN What kind is compatible
have you been tried to find at the shopjimmy.com or at the amazon.com?. you can replaced it with other adapter even not LG, the only need to considered is the same voltage and amper rating as will as the size of the output jack and polarity of the adapter you will replaced. which will fit and same polarity to your monitor .
Dec 11, 2012 | Computers & Internet
What type of cable power supply do I need for a V7 L17PS monitor? I got this monitor for free but no cables came with it. Thanks
Looks like it takes a 19V 3.42A Power supply.
Look on the back of the monitor near the power jack and find where it says "input"
If it says 19V 3.42A then this is what you want:
http://cgi.ebay.com/19V-AC-DC-Adapter-Power-Video7-videoseven-L17PS-LCD-/110632100842?pt=LH_DefaultDomain_0&hash=item19c22fe3ea
Mar 25, 2011 | Videoseven L17PS 17" LCD Monitor
This monitor has a cracked screen where can I purchase a new screen
Hi
in shops with electronics
in case i had help you pls vote me
Nov 04, 2010 | Videoseven E17PS 17" LCD Monitor
I cant get the screen to centre the picture.The start control is just out of sight on the left side when the right margin is in position. I have tried to adjust on the controls on the front but the display...
Right-mouse click anywhere on your desktop "wallpaper".
Click Properties.
Click Settings.
Change the resolution to 800-by-600.
Click Apply, to see if the screen is "filled" by the Windows desktop.
Then, try 1024-by-768.
Then, try 1280-by-1024.
Pick the "best' one.
Aug 22, 2010 | Videoseven V7 E17PS 17" LCD Monitor
Pixels only goes to 640X480
When you cannot increase the screen resolution nor a higher color bit, this usually means the video driver has defaulted to standard VGA driver and 8 or 16 bit color.
Install or re-install the latest video driver for your model video card.
When the correct video driver is installed you will be able to change the screen resolution and 32 color bit.
Dec 31, 2009 | Videoseven V7 E17PS 17" LCD Monitor
Desk top orientation
i think ur moniter roated.if not work u can take other way.As click right mouse then click on graphic. tick on enablerotation and fixed 0 deg.2/clk right mouse then click property--apparance... advance...select card...select o degree normal mode
Jun 10, 2009 | Videoseven V7 E17PS 17" LCD Monitor
Volume
Start --> Settings --> Control Panel.
Sounds and Audio Devices.
There is a volume slider here, and should be an option to put an icon in the system tray where you can click to adjust the volume anytime. Make sure you are not muted.
Jun 20, 2008 | Videoseven E17PS 17" LCD Monitor
My Videoseven Monitor is just displaying a white screen (or sometimes grey) It does not respond to the computer.  I know its not the wires or computer as I have changed the monitor to another one and the...
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burning spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 06, 2008 | Videoseven V7 E17PS 17" LCD Monitor
Settings
Typically its a function of your video card driver. If you look in the system tray (lower right hand part of screen you'll see several icons, one of which represents your video card drivers adjustments. However over each of them one at a time and a label will appear. When you find the video card right click on the icon and you should see a selection about rotation or screen orientation. If you can't find it let us know what video card you have installed and we'll try to help.
Feb 04, 2007 | Videoseven V7 E17PS 17" LCD Monitor
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
