Question about Car Audio & Video
I have a power acoustik ps2-150 2 channel amp but i dont have the high level input / speaker wire plug. where can i get one or what is the wire order? Thanks!
  • 62 Answers
Just try one wire at a time and trouble shoot it
Posted on Sep 13, 2010
I have a boss 400w riot 2-4 channels,how do i connect the high level wires? Because stereo doesn't have rca's
to use the high level leads, you have to isolate the wires going to each speaker (if using 4 channel mode) or isolate the wires going just to the rear if you are using 2 channel mode. you have to strip a small piece of the insulation off each speaker wire, and run it into the amps high level input harness. if you dont have the high level input harness, you can get a 2 channel high level to rca adapter for around $20. basically, you are tapping into the signal to the stock speakers to feed music to the amp. make sure you get all your positives and negatives correct. brighter wires are usually positive; however you may be faced with sa speaker which uses a grey wire, and another grey wire- the second with a black line. you will have to, again, turn to internet research to determine which is positive and negative, if the colors are not obvious.
Dec 30, 2016 | Boss Car Audio & Video
What wires do I hook up to the high level in plug that came with my dual xp2100 2 channel amp
First, know that you need either high level input or low level input, but not both. Low level input is preferred (RCA cables). If you must use high level input because your head unit doesn't have RCA jacks, you connect the speaker outputs from the head unit to the high level input of your amp. The high level input plug probably has a black wire, this is "signal reference ground". A pair of grey wires which are right positive (grey) and right negative (grey with black stripe). And a pair of white wires, left positive (white) and left negative (white with black stripe).
Feb 26, 2011 | Dual Car Audio & Video
Power Acoustik PWM-16 Equalizer Help
You should be able to use your RCA output (Line Out) from your Pioneer to the input of your PWM-16. Then take the PMW output to an amplifier and then to your speakers. Your EQ only uses RCA's so an amplifier after
it would really bring the sound to life. The amp need not be huge as you have an output for subs also. You could try a line converter to change the RCA lines to speaker wire connections. Not sure if the output would be enough to power a speaker but it's worth a try.
Sep 28, 2009 | Power Acoustik PWM-16 Car Audio Amplifier
Power acoustik gothic OV2 800 manual
Could not get a manual for you but did get the follwing specs. Hope they help.
Power Acoustik Ov2-800 2-Channel Class A/B Gothic Series Amplifier (800-Watt)
POWER ACOUSTIK OV2-800 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER
800-WATT 2-CHANNEL
4 ohm RMS: 150W X 2
2 ohm RMS: 180W X 2
Bridged mode MONO RMS: 360W
BRIDGED MAX: 800W
FULL MOSFET POWER SUPPLY
PWM CIRCUITRY
FULL SELECTABLE CROSSOVER
3-WAY PROTECTION CIRCUIT
TRI-MODE CAPABLE
VARIABLE LOW PASS 40 HZ - 120 HZ
VARIABLE HIGH PASS 150 HZ - 1.5 KHZ
VARIABLE 18 DB BASS BOOST @ 40 HZ
FREQ RESP: 10 HZ TO 30 KHZ
S/N RATIO: 98 DB
THD: 0.02%
2 ohm STABLE STEREO
SYSTEM DISTRESS INDICATOR
HIGH/LOW LEVEL INPUTS WITH FLOATING GROUND
4-GAUGE POWER/GROUND CONNECTION
PLATINUM RCA CONNECTORS
LINE OUTPUT WITH FLOATING GROUND
BLUE LED
CHROME TOP PLATE PANEL 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER (800-WATT)
Aug 18, 2009 | Power Acoustik GOTHIC OV2-800 Car Audio...
How to hook up a pyramid pro plus 4 channel pb-180px without using rca jacks for 6 by 9s
The pb180 has High Input receptacles on the back end. They are marked High Input and identified as Channels 1&2 left/right, and channels 3&4 left/right. You will need to identify all speaker wires coming from your head unit ( left front +&--) , and so on. You will be sending the speaker wires from the head unit to the pb180's High Inputs. In other words, the front left speaker wires(+&-) from the head unit will go to the High Input Channels 1&2 side, left input of the pb180, and so on, so the speaker wires coming out of the head unit will need to be cut. And LABEL all sets of speaker wires before you cut them! Then on the OUTPUT end of the pb180, you will be sending the wires back to the the respective speaker wires which are going to the speakers. So it's out from head unit to pb180 and out from pb180 to speakers.
Hopefully you have the plugs that Pyramid uses for the speaker wire inputs to the amp. If not you have to get creative, and make up terminals to fit into the input receptacles. Maybe a wire terminal from Radio shack will fit those pins..
Also, if you go on line: Google search "Pyramid auto amps" and click on "SEARCH" (upper right hand) of their Web Page. Plug in your model number like this, pb180, and you'll be able to download the manual for this amp. The manual has a full description of the wiring options.
Hope this was helpful and Good Luck!
Jul 27, 2009 | Pyramid Audio Players & Recorders
How to wire an eq to car stereo without an outboard amp?
no those wire is not for speakers out put that for signal in put only if there is rca jack follow the instruction and run your cable if your dont know dont guess you will burn unit audio out put if install wrong
Jun 28, 2009 | Power Acoustik PEQ-70 7-Band Car Equalizer
Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
Jan 31, 2009 | Power Acoustik PTID-8960 Car Video Player
Factory stero to amp
If the amplifier has inputs for a high level signal, you unhook the wires going into the speaker and plug them into the amp, then hook the outputs up to the speakers. If the amp only has rca inputs, you need to also buy a line level converter. Then you unhook the speakers, hook the wires up the the converter, then hook the converter up to the amp, then hook the amp up to the speakers.
Please leave good feedback!
Dec 08, 2007 | Blaupunkt PCA250 Car Audio Amplifier
OEM gm stereo
If your amplifier has what they call High level inputs (basically inputs on the amp that you run the speaker wires from your radio into), you can splice wires from where the connectors are on your rear speaker(s), still leaving the speaker hooked up, and use those as an input into the amp. If your amplifier does not have high level inputs, a convertor is available to turn an audio signal from your radio output speaker wires ( spliced in just as above, leaving the speaker hooked up), into an rca output jack. Or the best thing to do would be to buy another say 2-4 channel amp w/high level inputs and rca inputs and outputs, and run your rear speaker wires into the amp. Then you'll be able to run the rca cables out of that amp and into the sub amp, and you'll have the new amp to power your rear speakers or rears and fronts. That would be ideal. But, A convertor is your best bet. Got em at best buy, circuit city, etc. Hope this was helpful.
Nov 25, 2007 | Car Audio & Video
600 watt 2 channel power acoustik sterling amp
On your amp, there should be a switch (on the side probably) that has "LP", "HP", and "FULL" or "OFF". This is a switch for the low pass/high pass filter. Switch it to "LP" as this will allow only low frequencies to go to your subs, what you want. If you don't have that switch, go to an audio store or online audio supplier and get either a low pass filter, band pass filter, or a cross-over, and follow the wiring diagram that comes with it to filter out the high frequencies before they get to your subs.
Oct 09, 2007 | Power Acoustik TS1440-2 Car Audio...
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
