Question about Mastercool 67680 Evaporative Cooler Air Conditioner
Noise My new Mastercool AC makes a terrible buzzing noise before it comes on like the motor is just sitting there buzzing then it finally starts blowing but I can't get the people we bought it from to send anyone to check it. I have to pay for someone to come check it myself. This is not right but what can I do?
    Novelist:
    Champion:
  • 230 Answers
If your warranty from the contractor is still in effect then I would demand that they come look at the problem. This however, does not guaranty that you will not have to pay. For instance if the new motor goes bad they might replace the motor for free but the labor may still be applicable. You will have to read through your contract with them to find out.
As far as the noise is concerned, It sounds like maybe a purge pump is failing. It could also be the motor failing due to (assuming the unit is new) a manufacturing default. The motor can also go bad if the belt is not adjusted correctly.
Posted on Jun 17, 2008
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
What is wrong with my car?
Check the belt or belts
May 17, 2015 | 2000 Ford Taurus
BUZZING NOISE
Is this noise a motor buzzing noise? If motor has power but the start circuit is not energized, then the power through the run winding cannot start the motor and may make a buzzing. Need to address the type of buzzing and if the motor, then check motor circuit.
Jan 08, 2014 | Hoover Dryers
Mastercool has loud thump when blower comes on....
Are you sure the blower wheel is not loose on the shaft. There is a set screw to tighten it to the shaft. How are the bearings?
Jun 10, 2013 | Mastercool 67680 Evaporative Cooler Air...
My Maytag Gas Dryer makes a loud buzzing noise when the ignighter and flame come on
thats a good sign the valves that those coils you replaced sit on are getting bad and you will sooner or later need a brand new gas valve
Oct 13, 2012 | Maytag Dryers
Loud humming noise from under my Tahoe. 2WD
The noise is your fuel pump which should hum, but not buzz. It is going bad & will need replaced soon.
murf427
Aug 02, 2012 | Chevrolet 2001 CHEVROLET TAHOE Chassis...
Maytag dryer makes an electrical buzzing noise when start button
It sounds to me like the motor is not turning, but the heating element is coming on. with no air flowing over the element, it is getting too hot. Can you operate the start switch with the top tilted up so you can see if the motor is turning but the drum is not, and just where the buzzing is coming from. Also, I would try the dryer on manual setting and on air dry to see if any setting works. Good luck
Jan 07, 2010 | Maytag MDE6000 Dryer
Noise on mastercool
had the same symptoms and found that tightening the squirrel cage set screws eliminated the noise.
May 23, 2008 | Mastercool 67680 Evaporative Cooler Air...
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
221 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
