Samsung ML-4500 with IEEE 1284 to usb cable not working
I have winXP Pro and a Samsung ML-4500 connected using an IEEE 1284 to usb cable. I try to print a test page and it acts like it's working, but nothing prints and I get a printer error. If I cancel the print and try to print again in just hangs until I recieve an error. If I restart my computer and try to print again it acts like it's working, but still no page.
Any help please
  • camboia May 16, 2008
    Terry,
    It's a brand new Belkin cable that didn't come with any drivers. The printer is listed with a yellow question mark as Other devices. I installed the printer through auto detect and manual selecting LPT2 and also usb. I'm using IEEE 1284 to usb because my Dell Inspiron 530 didn't come with a printer port and the printer doesn't support usb directly.
    Thanks,
    dan
  • camboia May 17, 2008
    Terry,
    Thanks for you help it pointed me in the right direction, which was sytematically troubleshoot the problem. I took the Belkin usb hub out of the eqaution and connected the printer directly to a usb port on the front of the compter. This allows me to print, but XP still doesn't recongnize the printer hardware after I restart. It's working for now.
    Dan
Windows XP/VISTA (do not install the CD)
1) Plug the cable into the USB port on your computer.
2) A prompt that says "Found New Hardware" will appear. Windows will then install the USB printing support driver automatically. You do not need to install the driver from the CD.
3) Plug the cable into the printer.
4) If your printer is already installed, click on Start, then Printers & Faxes. Right click on the printer you are connecting to and click on Properties. Click on the Ports tab and check the ‘Virtual printer port for USB’ port. Click OK.
5) You should now be able to print.
With XP, the biggest clue is to FIRST plug the cable into the usb slot, THEN the other end of the cable into the printer.
Posted on Jun 04, 2008
After months of horror, buying and returning adapters, I think I've found the solution for laptop users wanting to use their ML-4500. Samsung ML-4500 printer requires that the port be a LPT1 port. This old, but reliable printer, will not work with any USB adapter even if it's an express card USB adapter. Purchase the StarTech EC1PECPS Paralle Port ExpressCard - Retail http://www.newegg.com/Product/Product.aspx?Item=N82E16839158026 This express card converts to show an LPT1 port and not a USB port... which is what the Samsung ML-4500 requires in order to work.
Make sure you buy the correct expresscard. I had to return and keep on researching until a customer service guy at StarTech figured out what I needed. Newegg was great about letting me return the expresscard and getting the correct one.
Posted on Mar 11, 2010
  • 26 Answers
G'day,
a couple of quick things to check first,
the usb to IEEE1284 cable should have had some drivers, if it is installed properly it should appear in the device manager under ports (com & lpt), make sure all is ok here first.
next when you installed the printer did it auto detect or did you select the port it was installed on, i think the cable will appear in ports (in device manager) as LPT2, if your printer is on LPT1 it wont work.
Lastly, is there any reason you are using usb to IEEE1284 instead of direct to parallel port or usb
please let me know what you find
Terry
Posted on May 15, 2008
Panasonic IEEE 1284
Not sure what the question is. IEEE 1284 is a parallel cable interface, standard on most computers up until Windows XP for sure. http://en.wikipedia.org/wiki/IEEE_1284. This interface was substantially replaced by USB. If you have an older printer with this interface you can still connect this to a newer computer without the parallel interface by installing an interface card (into a desktop computer) or connecting via a Parallel to USB adapter.
http://www.pcfixup.ca/2010/03/connecting-parallel-port-printers-to.html
May 08, 2014 | Microsoft IEEE 1284.4 compatible printer
I am simply making a copy and it is printing super slow.
hELLO IDEAL58ST,
While printing from the USB Port sometimes slow printout/data transfer will result in slow printing of print jobs. SOLUTION: Solution After the printer is installed on the USB Port, check the description under the Ports Tab what is selected. Please refer to the figure below : c00873625.jpg Using the USB/ Virtual Printer Port and DOT4/ HP Laserjet 2420, under the Port/Description Tab printer speed will be as per the standard. Whereas using the DOT4/ Generic IEEE 1284 under Port/Description Tab, Printer speed will be very slow. If DOT4/ Generic IEEE 1284 is selected by default, then you have to uninstall the USB driver from the Device manager and plug in the USB cable again. Then it will detect the printer and USB port with respect to the printer model.
THANKS.
Sep 06, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I have a citizen prolaser 6000 laser printer, it emulates HP Laserjet 3, I want to connect it to my laptop via a usb interface cable, currently it is connected to the printer port of a desktop (lpt1 for...
There is three things that you will need:
Proper port set up on laptop device manager (Check settings) LPT1 is for a parallel port - Need USB Correct Driver for the Citizen 6000 Pro Laser (Windows should auto install) Hub that will communicate via USB to the IEEE 1284 Printer via cable.
Driver Site: http://www.driverfiles.net/Printers/Citizen/Prolaser-6000-Printer-Driver/download/page,sh,38839,389,12,.html
I hate to suggest, but you may have to call Microsoft Citizen Tech Support for suggestions on the Hub that will communicate via USB properly. Check your manual for setup options.
TF
Jun 02, 2011 | Office Equipment & Supplies
I just bought a new computer and the connections don't match up. what do i do? I have the Eltron LP 2443PSA Thanks, Mike
I beleive your printer only has a Parallel interface and your new pc does not. You will need a USB to Parallel cable.
Parallel Connection:
USB to Parallel Cable:
http://www.buy.com/prod/cables-to-go-usb-to-db25-ieee-1284-parallel-printer-adapter-cable-db/q/sellerid/11408470/loc/101/205484702.html
Apr 17, 2011 | Zebra Eltron Orion LP2443 Thermal Printer
What kind of cable is needed to connect a Fargo DTC 520 to a computer?
The cable you need for that printer is a Parallel IEEE1284 Compatible Bi-directional printer cable. It is the regular printer cable everyone used before all the printers went USB. If you dont have a parallel port on your computer, the link below is to USB Parallel adapters that you should be able to use with this printer.
USB Parallel Adapters from Tigerdirect.com
I hope this answers your question. Have a great day!
Apr 06, 2011 | Fargo DTC520 Thermal Label Printer
Connect printer to usb
I apologize for the delay in responding to your inquiry. I have researched this matter for you, and then typed a fairly lengthy solution. For some reason, just before it was to be posted it disappeared. (We have to love these PC's, right?)
At any rate, the connector on the printer is known as a mini- or micro-concentric parallel connection; therefore, you will need an IEEE-1284 premium mini-concentric parallel cable. This reference is posted merely for you to see the particular cable, and should not be interpreted as an endorsement of any kind concerning the vendor. http://sewelldirect.com/ParallelCableMiniCentronics6Foot.asp. In order for the IEEE 1284 end of the cable to attach to a USB port, in this instance, would require an adaptor to convert the parallel to a USB connector of the proper type and size. In fact, given that I do not know the remaining specifics of your system, and so that you will gain familiarity with the various adaptors, I would suggest that you take a look at this page: http://sewelldirect.com/search.aspx?searchTerm=usb+parallel+adaptor.
Again, please do not construe my posting of this vendor's pages as an endorsement of any sort, as I have had no experience with them whatsoever. The references are posted here simply for your review.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Aug 21, 2008 | HP LaserJet 1100 Printer
Using a Samsung ML-4500 printer with a laptop
G'day Nicole, I'm in South Australia if it helps, call me 0886412772, David or Terry will be glad to help
Mar 13, 2008 | Computers & Internet
My HP LaserJet 6L Won't Print on new HP/Vista PC
Use any printer parallel 25pin convertor to USB cable and connect it to pc or notebook
Connect both ends from pc to 6L printer
Go to website to choose the correct O/S driver for installation
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=14974&lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=18972&prodSeriesId=25476
Use virtual USB port005 for printer 6L
Bi-directional option can be ticked
Click apply and ok
Unplug and replug the USB cable
Try printing a test page,
I have tried it, the vista download drivers works on vista, no problems in printing at all, advise from http://www.bebo.com/andythoo
Jan 20, 2008 | HP LaserJet 6L Printer
Computers & Internet Logo
1,301 people viewed this question
David Payne
David Payne
