Question about LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive
Ticking noise and doesn't show on my computer
    Scholar:
  • 39 Answers
I had a similar situation ticking sound and in my case it was a stuck reader therefore making it defective. Good news is that they usually have good warranties (some have 3 years) and if you call the manufacturer they will replace it with a new one if its still considered under warranty, they can check by either your receipt or some manufacturers can use the serial number and production date. Do this before trying to take it apart since that usually voids some warranties good luck
Posted on Sep 14, 2010
  • 3,153 Answers
The ticking noise is usually a sure sign of a DEAD hard drive.
Quite often in the case of a knocked or dropped drive.
It may be possible to test the drive by removing it from the caseand installing it in a regular computer that has SATA.
These cases are quite tricky to open and I tend to use the flat end of a nail file on each side to keep the sides slightly apart as I work the rest of the case
Posted on Sep 12, 2010
Code p0446 slight ticking noise while engine running
came from engine or something else.446 gsa tank,gas cap,valve vent,solenoid.
Mar 01, 2013 | Lexus GS 300 Cars & Trucks
Disk makes noise and doesn't show on the screen
That usually means it gone. Has it been treated harshly?
Jan 27, 2013 | Computers & Internet
Makes ticking sounds and wont work
The ticking noise is either something touching the fan in the Fan Assembly; or the Harddrive has gone bad.
My thoughts?
Harddrive
http://www.youtube.com/watch?v=ZGqaz4JdS5E
http://www.youtube.com/watch?v=YqgkqcNCrj8
http://www.youtube.com/watch?v=FjYuzjA31mQ
Regards,
joecoolvette
Dec 29, 2012 | IBM Lenovo ThinkPad X41 Motherboard...
My car when i start it start ticking up after it warm up it smoo out.
Unless the noise doesn't go away don't worry about it it is roller rocker noise and normal in this engine.
Sep 12, 2012 | 2002 Saturn Sl
2005 Pontiac sunbird has black gritty oil
sounds like possible lifter ticking due to lack of service. offer to pay for an oil change and drive the car for a couple of days to see if ticking noise quietens down. if it doesn't you may be looking at replacing the lifters.
May 23, 2012 | 2005 Pontiac Sunfire
1995 saturn sl2 ticking noise when accelerating
these are known for carbon build up on the valves that cause several problems.this could be the problem as the carbon can cause the valves to stick a bit in the valve guides while its running and show up as a ticking noise with the gas applied.have the top end service done which cleans the fuel system injectors and any carbon build up on the back of the valves.if this gets bad enough it can cause the cam holders to break locking up the motor if the piston hits the valve.another thing to check is oil pressure and the lifters may be worn to the point that they need replacing.check the cam lobes as well if worn these can cause a ticking noise on acceleration.
Apr 17, 2012 | Saturn SL2 Cars & Trucks
We changed out the battery on the starter and now when we try to start we are getting a ticking noise but the grill is not starting I've used a normal AAA battery-is that correct? What else can it...
The ticking noise doesn't mean your getting spark. Open the grill and look inside (gas off) and look for a spark when you push the starter. There should be a spark gap, if its not sparking look for a piece of food or fat stuck between the burners and the starter probe.
Jun 02, 2011 | Weber Genesis E-310 Gas Grill
Enging ticking on top
it could possibly be worn valves or valve springs. sometimes worn cam bearings can cause this issue. try using 10w 30 motor oil on your next oil change to see if it helps. sometimes the oil you use can cause ticking because it is not thick enough to lubricate the engine properly. if 10w 30 doesn help the noise, it is possible this problem may be linked to worn parts inside the cylinder head. removing the valve cover will give you a better idea of what could be the source of the ticking.
Mar 05, 2011 | 2002 Kia Spectra
I tried to start my car this morning it makes a ticking noise and it doesn`t start. and alarm isn`t going.I have cobra 3190. How i can remove the alarm? plzz some help?
if the ticking noise is coming from the engine compartment, you have a dead battery. some alarms will not function when the voltage is too low, therefore you can't lock/unlock or arm/disarm the alarm.
Feb 21, 2010 | Vehicle Parts & Accessories
Samsung 2253bw lcd monitor makes loud, fast ticking noise > 10hz. Noise occurs even when monitor is powered off with switch.
Turned out ticking noise was harmonic vibration triggered by a nearby airconditioning compressor. Once I guessed the cause, putting a rubber pad under the monitor to dampen the vibrations eliminated the ticking. Removing the pad caused the ticking to reoccur. Ditto with turning the A/C off or on. Weird!
Jun 05, 2009 | Samsung SyncMaster 2253BW LCD Monitor
LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive Logo
342 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
