Question about Canon NP 6650II Copier
E531 error code
Does anyone know what this code is for? I think the stapler jammed, but I took care of it yet I'm getting this error code now.
  • Anonymous Mar 19, 2014
    E531
  • Canon Expert
  • 1,326 Answers
Did you remove the jamed staple? Try to disconnect the finisher and power up just the copier it self. Once, warmed up, try to turn it off and reconnect the finisher again and turn the power on and see if the code is gone. Did you also try to leave the staples out and see what happens. Make sure the stapler can find HP. It could be a number things... Go simple first..
Posted on May 15, 2008
Tip
Error codes related to Canon ir 2200/2800/3300
E000 Heater temperature fault
(fails to increase)
E001 Overheating detection error
E002 Heater temperature error (fails to reach
specific level; inadequate increase)
E003 Heater temperature error (abnormal
drop; low-temperature detection)
E007 Fixing film rotation error
E010 Main motor rotation error
E014 Fixing motor rotation error
E019 Waste toner case full, sensor error
E032 DA unit communication error
E051 Horizontal registration HP
detention error
E064 Power supply voltage error
(high-voltage error)
E100 Laser BD error
E110 Polygon motor rotation error
E202 No. 1 mirror base HP detecting error
E204 ADF image leading edge signal
detection fault (absent)
E220 Lamp ON error
E225 Standard white plate/edge white
plate read error
E240 Mcon-Dcon communication error
E243 Mcon-control panel
communication error
E248 Backup (EEPROM) error
E261 Zero-cross signal error
E302 Shading error
E315 Image data processing error
E601 Image transfer error
E602 Hard disk error
E604 Image memory fault
E605 Image memory battery fault
E606 HDD error
E674 Fax board error
E677 PDL board mounting error
E710 IPC initialization error (Rcon)
E711 IPC register error (ctrl)
E712 Communication error (with ADF)
E713 Communication error (with sorter
finisher)
E716 Communication error (with pedestal)
E717 Communication error (with ASSIST)
E719 Card reader, coin vendor
communication error
E732 Reader communication error
E733 Printer communication error
E737 SDRAM error
E740 Ethernet board error
E741 PCI bus error
E742 RIP1 board error
E743 Mcon-Rcon communication error
(Rcon detection)
E744 Language error
E746 Resolution conversion board error
E803 MPWS power supply voltage error
(low voltage error)
E805 Fan rotation error
E901 Pedestal main motor rotation error
[ADF]
E420 Back-up data read error
E421 Back-up data write error
E422 IPC error
[Saddle Finisher-G1]
E501 Communication error (Punch unit)
E505 Back-up RAM
E510 Feed motor
E514 Delivery motor
E530 Width plate shift motor
E531 Stapler motor
E532 Stapler slide motor
E537 Alignment motor
E540 Tray ascent/descent motor
E577 Paddle motor
E590 Puncher motor
E592 Puncher sensor error
E593 Puncher shift motor
E5F1 Saddle folder motor
[Finisher-J1]
E500 Communication error
E514 Stack handling motor
E530 Rear alignment motor
E531 Stapler motor
E537 Front alignment motor
E577 Delivery motor
E580 Delivery tray ascent/descent motor
E585 Stack handling error
If the thermistor has a short circuit, the indication in service mode
(COPIER>DISPLAY>ANALOG) will be as follows from the start: FIXC=250°C
for the main thermistor; FIX-E=310°C for the sub thermistor.
Error codes from E000 to E003 can be in some cases reseted from service mode: PROCEDURE:
Press*
Press2
Press8
Press*
Navigate to: COPIER>FUNCTION>CLEAR>ERR.
Turn off and on.
on Aug 03, 2010 | Office Equipment & Supplies
Error code E000002-0000
dispite the error, you should be able to enter the service mode.
Procedure for service mode is:
- press * ( additional functions - user mode )
- press 2
- press 8
Then choose COPIER, then under FUNCTION screen is CLEAR.
But you only can try to clear the error like E000, E001, E002 and E003.
Wich error code is apearing on display?
Here is some examples of error code:
(fails to increase)
detention error
E100 Laser BD error
E220 Lamp ON error
plate read error
communication error
E302 Shading error
E606 HDD error
finisher)
communication error
E737 SDRAM error
E741 PCI bus error
(Rcon detection)
E744 Language error
(low voltage error)
[ADF]
E422 IPC error
E505 Back-up RAM
E510 Feed motor
E514 Delivery motor
E531 Stapler motor
E577 Paddle motor
E590 Puncher motor
[Finisher-J1]
E531 Stapler motor
E577 Delivery motor
If nothing of these helps, send more specific description of problem.
Hope it helps
Jul 06, 2010 | Canon imageRUNNER 2200
The problem in canon 6050
this error from sorter/stapler unit if this problem is repeated
disconnect the sorter and use copy tray,sorter must be serviced
E530
Main Cause The alignment plate home position sensor (PI6) is faulty. The alignment
motor (M3) is faulty. The finisher controller PCB is faulty.
Mode of
Detection
0001 The alignment plate does not leave home position when the alignment
motor has been driven for 2 secs.
0002 The alignment plate does not return to home position when the
alignment motor has been driven for 2 secs.
E531
Main Cause The stapler home position detecting switch (MS7) is faulty. The stapler motor
(M6) is faulty. The finisher controller PCB is faulty.
Mode of
Detection
0001 The stapler does not leave home position when the stapler motor
has been driven for 0.5 sec.
0002 The stapler does not return to home position when the stapler motor
Jun 06, 2009 | Canon NP 6050 Copier
Tip
ERROR codes Canon 6650
Canon 6650 E000 Thermistor E001 SSR E002 Thermistor, ht. Lamp thermal fuse or SSR E003 Thermistor, ht. Lamp thermal fuse or SSR E005 Fuser cleaning belt E010 Main drive problem E020 Toner motor, toner level sensor, toner hopper sensor E030 Counter E050 Duplex problem E203 Scan home problem E210 Lens home sensor E401 Document feeder paper pickup motor E402 Document feeder belt clock pulse problem E403 Document feeder main motor clock pulse problem E411 Document feeder sensor problem E500 Sorter/copier interface problem E500 An error is identified in the communication between the sorter and the copier E510 The clock signal from the motor is absent for 250ms or more E510 Sorter motor drive E513 The clock signal from the motor is absent for 250 ms or more E530 Sorter home sensor E530 The home position sensor (P17) fails to go OFF when an equivalent of 2560 pulses of the motor drive command has been generated E531 The stapler unit swing sensor (MS9) fails to go ON within 500 ms after the motor drive command has been generated. MS9 fails to go back OFF within 1000 ms after it has gone on E531 Stapler swing sensor E540 The lead cam home position sensor (P12) fails to go OFF within 2000 ms after the motor drive command has been generated. P12 fails to go back ON within 2000 ms after it has gone OFF E540 Sorter lead cam home sensor E541 Sorter lead cam home sensor E710 DC controller board E711 DC controller board E712 Document feeder problem
on Jan 19, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 4835
Canon 4835 E000 Low fuser temperature E001 High fuser temperature E002 Low fuser temperature E003 Low fuser temperature E010 Drive E030 Counter E080 Color change board problems E081 Color horizontal motor problem E082 Color horizontal motor problem E083 Color problem in vertical direction E084 Color problem in vertical direction E085 Color problem in vertical direction E086 Color unit claw release problem E089 Color change incomplete E100 Laser problem E110 Laser motor problem E140 Laser unit E203 Scan drive problem E210 Lens not home or won't leave home E240 DC controller E401 Document feeder pick up motor E402 Document feeder belt motor E403 RADF feed motor E404 Document feeder motor E411 Document feeder sensor E500 Sorter to DC control interface problem E510 Stapler/sorter motor E530 Stapler swing motor E531 Stapler swing motor E540 Sorter bin motor E541 Sorter bin motor E710 DC controller
E531
Check your stapler. If you removed a jam from the sorter you may have accidentally moved the stapler so it is not sitting at a 45 degree angle when you open the front door of the sorter. There's a little lever you can push to swivel the stapler, however don't try to force it. You may have to pry up the plastic lock that is under the stapler with a small screwdriver. Sometimes the stapler assy has to partially removed (slid to the front) of the sorter to be able to see what you're doing.
May 14, 2008 | Canon NP 6551 Black and White Copier
Tip
ERROR codes Canon 4540
Canon 4540 E00 Low fuser temperature E001 High fuser temperature E010 Main motor clock pulse E011 Bind or load on main motor E020 No TF for 3 minutes E030 Copy counter E050 Duplex unit E201 Scan motor E203 Scan motor E210 Lens home E240 DC controller E241 DC controller E320 CCD E400 DC controller, 24V E500 DC controller, 24V E510 Finisher feed motor E520 Stacker motor E530 Guide plate shift motor E531 Stapler motor E620 DC controller, edit board
Tip
ERROR codes Canon 4080
Canon 4080 E000 No fuser heat E001 High fuser temperature or shorter thermistor E002 Low temperature or bad thermistor E003 Fuser problem E004 Bad SSR (heat staying on) E010 Drive E020 Black toner motor E030 Counter E080 Interface problem with color unit E081 Vertical drive motor E082 Horizontal drive motor E083 Color unit sensor on right E084 Color unit sensor on left E085 Color unit release sensor or release or solonoid E086 Color unit claw release E089 Laser problem E100 Laser problem E110 Laser motor E140 Laser E202 Scan E203 Scan E204 Scan E210 Lens E223 Color unit filter drive motor E240 DC controller E401 RDF pickup motor E402 RDF belt motor E403 RDF feed motor E411 RDF document sensor E500 Sorter-Copier communication error E510 Sorter drive E512 Sorter driveE513 Sorter drive E514 Sorter drive E520 Top limit sensor or stack sensor E530 Sorter home sensor E531 Stapler home sensor E535 Stapler swing sensor E540 Stack shift sensor E660 IC card E710 DC controller E711 DC controller E714 DC controller E800 Power off circuit
on Jan 18, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 4050
Canon 4050 E000 No fuser heat E001 High fuser temperature or shorter thermistor E002 Low temperature or bad thermistor E003 Fuser problem E004 Bad SSR (heat staying on) E010 Drive E020 Black toner motor E030 Counter E080 Interface problem with color unit E081 Vertical drive motor E082 Horizontal drive motor E083 Color unit sensor on right E084 Color unit sensor on left E085 Color unit release sensor or release or solonoid E086 Color unit claw release E089 Laser problem E100 Laser problem E110 Laser motor E140 Laser E202 Scan E203 Scan E204 Scan E210 Lens E223 Color unit filter drive motor E240 DC controller E401 RDF pickup motor E402 RDF belt motor E403 RDF feed motor E411 RDF document sensor E500 Sorter-Copier communication error E510 Sorter drive E512 Sorter driveE513 Sorter drive E514 Sorter drive E520 Top limit sensor or stack sensor E530 Sorter home sensor E531 Stapler home sensor E535 Stapler swing sensor E540 Stack shift sensor E660 IC card E710 DC controller E711 DC controller E714 DC controller E800 Power off circuit
Tip
ERROR codes Canon 4035
Canon 4035 E000 Low fuser temperature E001 High fuser temperature E010 Main motor clock pulse E011 Bind or load on main motor E020 No TF for 3 minutes E030 Copy counter E050 Duplex unit E201 Scan motor E203 Scan motor E210 Lens home E240 DC controller E241 DC controller E320 CCD E400 DC controller, 24V E500 DC controller, 24V E510 Finisher feed motor E520 Stacker motor E530 Guide plate shift motor E531 Stapler motor E620 DC controller, edit board
Canon NP 6650II Copier Logo
292 people viewed this question
old marine
old marine
