Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
Removing shaft from 82 lb motorguide - MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
4 Suggested Answers
SOURCE: 46 lb motorguide stays on high speed. Motor is 2
It was just user error. It works now. Thank you.
Posted on Jun 22, 2009
bargainbin2
  • 123 Answers
SOURCE: Only one speed on MotorGuide 300 Stealth 30 lb
The speed control.
Posted on Aug 26, 2009
SOURCE: Wire going to prop of Motorguide trolling motor shorted
Unless you are mechanically inclined, dont attempt this. Take the lower unit apart by removing the prop and removing the two bolts that hold the forward and aft housing to the center housing. Fwd being the cone shaped part. Pull the aft housing away from the motor so you can inspect the connections to the board that holds the brushes and the soldered wiring terminals. You should find the solder missing from at least one of the terminals that connects the wiring from the foot switch to the speed control windings inside the aft housing. Clean up the terminal and wiring and re-solder. Also re-flow the solder on the other terminals. Clean up the seals and the area where the seals meet the housing parts. Replace seals if damaged. Reassemble the lower unit and torque the bolts 45-50 in-lbs and no more otherwise you will fail the seals. This problem is due to a "cold" solder joint that creates a high resistance to elec current flow and heats enough to melt the solder. This is a result of poor quality control at the manufacturer. Good luck.
Posted on Dec 29, 2011
The first thing to check,(After making SURE the electricity is disconnected to the trolling-motor) remove the propeller and see if the shear-pin (Usually made of brass) in in place and not sheared/broken.
If it is, your local marine shop should be able to provide a new one. I always carry spares. If the pin is OK, the windings may have an electrical fault that would require a factory-repair.
Sep 05, 2014 | MotorGuide Transom Mount Great White...
Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
https://www.minnkotamotors.com/
Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
Lost #1 and #2 speeds
Contacts inside switch may have become corroded.
May 12, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
I HAVE A MOTORGUIDE MOTOR WITH THE FOLLOWING LABEL ON IT... "EP2.3HP" WITH SERIAL #SN 42663". LABEL ON TOP OF MOTOR IS "36 VOLT DIGITAL. VARIABLE SPEED". CANT FIND ANY INFO ON THIS MOTOR ANYWHERE? IT HAS...
I need the information off the tag motor frame volts amps and shaft type and I can tell you how to make it work. you didn't leave your e-mail address, also please rate. Thank you.
Aug 08, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
MotorGuide pro series 46 lb.thrust not turning smooth
Check the beaing locted where the inner shaft passes thru the outer tubing below top of motor
Nov 27, 2008 | MotorGuide Electrical Supplies
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
140 people viewed this question
Top MotorGuide Electrical Supplies Experts
jdthefixer
Mike
Mike Marcotte
Mike Marcotte
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
