My telephone does not ring, though the wringer is on
  • Gold1na May 14, 2008
    Volume is sufficient. I very recently changed my telephone company.
    Scholar:
  • 170 Answers
If it has stopped after the change of phone companies then i would say there is good chance that the problems is in the phone companies settings. Try calling the new company and see if there is anyone else that has had this problems before.
They more then likely have a fix for this problem.
Also, try unplugging the main phone unit, also removing all batteries from handsets for 30 minutes. then put batteries back in and put in charger for 5 minutes. this should reset your handsets.
Posted on May 14, 2008
  • 3,037 Answers
What kind of phone do you have so that I can diagnose this problem with the phone. Also, do any other phones ring when hooked up to this line?
Please respond to my questions so that I can help you out with this
    Genius:
  • 1,665 Answers
Did you try to adjust colume?
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos May 14, 2008
    a soft reset may fix the problem!
    Simply call Customer Care and ask them to walk you through the soft reset...remember to call from a phone other than the one you are having problems with.
    Master:
  • 555 Answers
What is the maker and model of your telephone?
The wringer does not work
I haven't seen a washer equipped with a wringer for many years. The last was a Hotpoint Countess we owned in the 1970's. In these models and similar (Servis) the power wringer was driven by a vertical shaft from the sort of substantial gearbox that would do adequate duty in a fair-sized motorcycle.
Sometimes the drive can be engaged/disengaged and sometimes constant. The drive of the model we had turned constantly and the disengagement lever was on the wringer. the shaft could be clearly seen rotating whenever the wringer was removed. If the shaft is turning the fault is likely with the internal mechanism of the wringer and if not the shaft and the gearbox should be investigated.
Sep 18, 2016 | Washing Machines
MAYTAG wringer washer model#E2L does anybody have any information on this washer?
Maytag Wringer Washer "E" Series Parts
Manualwww.davesrepair.com/pdfmanuals/mytE2partsman.htm
Wringer Washer Restoration
www.youtube.com/watch?v=vTs6ozXTY5U
Oct 19, 2014 | Maytag Model E2l Vintage Wringer Washer...
Phone doesn't ring with in coming calls
your wringer could be turned off on the incoming calls
Sep 02, 2013 | Tablets & eReaders
HP LaserJet 3055 .fax not working
Direct Line:
1.Check telephone line.2.Make sure telephone line is connected in line in port not in extension.3.connect extension telephone phone to the device & check for the dial tone.
Dial the number and observe weather extension phone is ringing?
A. *If extension phone is ringing check display is there any message like "ringing".. wait till fax tone comes,if not check "basic fax settings"... if setting are OK .. Replace formatter
B. *Extension phone is ringing no message displayed on device replace "LIU" card..
If extension telephone is not ringing check telephone line..
No out going faxess:
*Check line is connected though EPABX , if connected Check..prefix setting..
*Check out going..
Best of luck...
Sep 06, 2011 | HP LaserJet 3055 All-In-One Printer
How do i connect a 1960 rotary phone up?Which wires do i hook up? I have a blue wire &a blue white wire coming into my building,
The Blue and Blue/white represent the first pair in a multi pair telephone cable. The second pair is orange the third is green and so forth. If this line is active, you will get a dial tone when you place a telephone instrument on this pair (or any subsequent live pair). Notice. If you are hanging on to the pair when the telephone rings - you will experience a 60 volt DC shock. It will not kill you but you may find it unpleasant.
On your Western Electric '500' telephone set, you should have three wires coming out of the original cable, a red, a green and a yellow. Normally, the red and the green will operate your phone on a 'private line' (only one customer on a private line). Try various combinations until you get a dial tone. You no doubt have a private line as there are very few party lines around these days if you are in the USA (and please do not say). Once up on a time, there were "party lines" where neighbors shared a line and they knew the call was for them based on the number of rings. The first customer got one ring, the second customer got two rings and so forth up th as many as 4 rings. When the telephone rang, you listened for the number of rings and answered only if it was your number. Picking up a call that was not your ring was frowned upon though it was not unknown for neighbors to listen in to other neighbors calls. It was like a reality show!
If your 500 has been upgraded with a RJ-11 wire, plug the wire in just as you would any modern telephone. If yours doesn't ring, remove the cover and study the interface. You will find several terminals marked L1, L2 etc. Move the wire you find on a "L" terminal to the various otgher L terminals until it rings when called. You may also have to adjust the spring on the ringer to get it to operate properly.
I hope this information helps you get your 1960 telephone to work.
Thank you for your interest in FixYa.com and enjoy your old telephone.
Mar 14, 2011 | Computers & Internet
Can't find value or date of manufacture of wringer washer(maytag)
I have a 1936 maytag gyratator wringer type electric washing machine in very good condtion - it works like a charm. What is it worth? I am out of room to continue storing it inside and it too good to leave outside - all the decals on it are like new with the exception of the bottom of the one with the years of maunfacture on it - it goes from 1922 to 1936
Mar 19, 2009 | Maytag Washing Machines
Fax does not connect on distinctive ring
It's either your phone, or it's your fax machine that does not support fax through phone.
Jan 30, 2009 | HP Officejet 5610 All-In-One InkJet...
Apron caught under wringer
Hi Karen,
That is a real pain when that happens, but let me see if I can help.
First on the top of the agitator or wringer you will see a small cover. You will need to pop that off to reveal the screw hidden underneath. Remove the screw and then the agitator will pull upward and off. The agitator on the hotpoint washing machine is really hard to pull off so you will really have to pull. When the agitator comes loose you will ofter be pulling so hard that you could hurt your arm on the top of the tub so be extra careful or get some guy to get hurt for you. Once removed I am sure the apron can be easily removed and all will be well again. Good luck to you and please dont forget to rate me. Have a nice day.
Mike Anderson
Anderson Appliance Repair
(865)945-3808
Oct 28, 2008 | Hotpoint Washing Machines
57 people viewed this question
 Grubhead
Grubhead
