Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
Panafax UF-885 I can send a fax out but I cannot receive a confirmation report or receive faxes because of error code #007 (paper jam). What can I do?
  • Anonymous May 15, 2008
    We have a Panafax UF-755e. It will let you send a fax, but not receive one. The message we get is, "Check Paper Size, Info Code 018," but the instructions do not list that Code to clear the machine. Can anyone help? Thanks
    Scholar:
  • 159 Answers
Paper jam error codes rely on input from sensors in the paper path. On this machine there is 1 sensor that is triggered by a mechanical actuator on the cartridge. Actually, the cartridge is generic, except for the position of this actuator. It is part of the guard that prevents damage to the drum, when it is removed from the machine. The positon of the actuator is different in the case of 4 different manufacturers who use this engine. Now, the effect of this actuator is to tell the machine that a cartridge is actually present in the machine. Now, some cartridge re manufacturers have removed this actuator entirely and technicians will jam the sensor in the machine with gum or a piece of paper to allow the use of this generic cartidge. Unfortunately, the paper path becomes obstructed, not with paper, but by the media that the technician has used to de activate the sensor. Look for this and replace the media with something more robust that will not become dislodged.
Posted on May 27, 2008
Hello i have a panafax uf-280m i would like to
Sometimes you can go to "print reports" then activity report and print your send report
Mar 23, 2010 | Panasonic Panafax UF-585 Plain Paper Laser...
Panafax UF-885 flashing UF-885 (AU) message
yes there is a batt on the board it will need to replaced i have seen this many times
Nov 18, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Error code 634 on the Panafax Uf-885
No dial tone detected, make sure you are plugged into the LINE port.
Sep 10, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
The fax doesn't want to scan or send a fax
Pull straight up on the operation panel to see if paper is stuck in the feeder and that all switches move freely. Any error codes?
Jun 15, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF 885 replace battery
Turn the machine off for 10 seconds.
If the display shows 00% there is nothing in memory.
Apr 20, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Fax machine error code 021
If a new toner cartridge doesn't take care of it, replace the fuser.
Apr 07, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF-885 - Error Code 055
Error 055 is a laser error. the laser is not spinning at the proper speed and may need replacement. There is another solution, where some ferrite cores are added around three cables to reduce electronic interference. Best call a local technician for further diagnosis.
Mar 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
No. If this is needed, make sure to turn on automatic reports
May 01, 2007 | Panasonic Panafax UF-885 Plain Paper Laser...
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
435 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
