Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Washer has water in it and wont drain when setting to drain and spin and doesnt lock
  • teaownam10 Sep 12, 2010
    theres no code which is strange but it wont drain the water
    it wont power off ii have to unplug it and plug it back in for it to come on
    President:
  • 1,554 Answers
The machine will not spin unless the water is drained first and the lid is locked. Check to make sure that the drain hose is clear and the pump is working. You posted your problem under Whirlpool Cabrio WTW6600SBT and this machine has a provision for error codes when a fault is detected. Indicate any fault code and explicitly state the exact model number of the machine for further and specific troubleshooting and repair advice.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions should you need further assistance. But accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Sep 12, 2010
  • Jahn27
    Jahn27 Sep 12, 2010
    I regret to tell you that this sounds like either the machine/motor control or the display module is malfunctioning. Remove the three hex-head mounting screws from the rear of the console then lift the console off the cabinet. Reseat every wire harness connections on the machine/motor control.
  • Jahn27
    Jahn27 Sep 12, 2010
    You can perform a diagnostic test to check the operation of the user interface assembly, pump, and the lid lock. Make sure the washer is in standby mode, i.e., plugged in with all indicators off, or with only the Clothes Clean or Done indicator on. Select and remember any one button, except POWER, START, and STOP, and follow this using the same button: press and hold for 3 seconds, release for 3 seconds, press and hold for 3 seconds, release for 3 seconds, press and hold for 3 seconds then release.
    All indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display if the test mode has been entered successfully. Press the same button within 5 seconds and a single beep occurs and the two-digit display shows one of the following console ID#s: 06, 08, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 44, 45, 46, 47, 48, 49, 60, 61, 62 for 3 seconds, then displays 00 and the Add A Garment indicator LED flashes. If entry into Manual Diagnostic mode is successful, but none of the console ID#s above are displayed, replace the user interface assembly.
    Press and release the CLEAN WASHER or DRAIN & SPIN button to turn on the recirculation pump. Press and release the same button to turn off the recirculation pump. Press again and release the button to turn on the drain pump. Press and release again to turn off the drain pump.
    Select CLEAN WASHER or DRAIN & SPIN if your machine uses a cycle selector then press Start to turn on and off the recirculation pump and the drain pump.
    Open the lid and the Clothes Clean or Done status indicator turns off. Closing the lid should cause the same indicator to turn on. If not, the door switch is not working.
    While the door is closed, press and release the 2nd RINSE or EXTRA RINSE button. The lid should lock and the lid lock indicator turns on. Press the same button and the lid should unlock and the lid lock indicator turns off. If not, the lid lock is not functioning.
  • 262 Answers
SOURCE: washer wont drain
check the pump for socks or anything that dont belong but put your hand on it while its in spin/drain and see if pump is even running
Posted on Dec 21, 2007
  • 148 Answers
SOURCE: washer wont drain water
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Posted on Jul 13, 2008
  • 1028 Answers
SOURCE: washer doesnt spin
ck the coupling between motor and gearcase it is probably broke and won't drive the transmission
Posted on Nov 08, 2008
duby1990
  • 367 Answers
SOURCE: wont spin and drain
What brand is this? If it a whirlpool or kenmore (or roper, estate) It is you lid switch. A very common problem but is cheap and easy to fix. Get me the model number and i can give you the part number for the switch.
Posted on Nov 21, 2008
  • 120 Answers
SOURCE: washer has water but doesnt spin frigidaire gl2940es
Something is stuck in the pump. Remove the hoses and remove the items. It will probably be a coin.
Posted on Jun 02, 2009
The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
More common issues with the door lock.
Is water hooked up to the washer?
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Wont drain or spin is lock up
does not spin all water out, towels are still wet, not overloading, could it be the timer?
Mar 01, 2009 | Estate ETW4400VQ Top Load Washer
Washer doesnt spin
Nov 08, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Apr 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series
Mrquest
If it is draining the water then the motor is running. ou most likely have a broken motor coupler between the motor and gearcase.
Remove the two screws that hold the console to the cabinet and flip the console back.
Remove the two clips that hold the cabinet to the rear panel of the washer and unplug the lid switch harness. The cabinet will tilt forward and slide off.
Remove the clips holding the water pump and move it to the side.
Unplug the wires from the motor and remove the clips holding it.
You will see the motor coupler.
Make sure you can turn the gearcase shaft with a pair of pliers so it is not locked up.
Post back with the complete model number from the washer if you need further help.
Thanks, Mike
Apr 02, 2008 | Kenmore 22422 Top Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Kenmore 2 Way Tumble Action Front Load Washer
no thats two different problems. The rubber piece (boot) forms a seal to prevent the water from leaking out, that should be replaced. Water might have leaked and ruined the pump. At the end of all cycles is there still water in the tub? If so your pump is either clogged or has gone bad, and thats why the washer wont go into extract.
Jul 09, 2007 | Kenmore 44102 Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
79 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
