Question about Nokia Lands Phones
Hi.. 1-Im not able to send msgs from my Nokia phone. I have checked with my operator and there is no problem from their side, as i have been recieving several msgs today, the issue is with sending. 2-Im not able to view the contacts i have saved in phone memory, can view only the one in SIM. Regards Bindiya Gupta
SOURCE:
myterminal
  • 178 Answers
SOURCE: n70 - Music player memory & Operator logo
Try the following things:
  1. Ensure your memory card has enough free space;
  2. Close all applications that may be running in background due to auto start option you might have selected. You may do this by pressing and holding the menu key until the list of applications running appears, and you may close each applications by pressing the 'c' key.
Posted on Nov 27, 2007
pintutelecom
  • 94 Answers
SOURCE: how to unlock a Nokia 6630?
i seen ur problum, if u want to unlock ur 6630 then u must have a ufs box thats cost near about 5000 Rs/- only other wise u may go to any nearst service senterok
that is only solution.
in unloking ur data will not remove. that will remain as it is ok
then dont wory go to any service center an tell them to un loke ur nokia 6630
bye
Posted on Feb 19, 2008
The_PhoeniX
  • 156 Answers
SOURCE: sending text messages
THe message center number if located mostly in messages->settings->center number.
also there is an option like "send via same center" try checking and unchecking it.
Tell the model to be more specific.
You can always get the msg center number from the service provider helpline(customer care)
Posted on Apr 12, 2008
SOURCE: How to transfer SMS from phone memory to SIM??
http://forum.gsmhosting.com/vbb/showthread.php?t=422037&highlight=C168+DOWNLOAD
Posted on Apr 19, 2008
SOURCE: hi, i have a nokia
If N73 is reflected in the paired devices list,go to device properties and disable encrpytion.....
Posted on Jul 05, 2009
Can't send msgs
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Dec 15, 2012 | Nokia N73 Cellular Phone
I hav d nokia E63..! & i cannot send any msgs.....it says "memory full , close some applications first...(& i hav absolutely no applications on except messaging)...... before it said that...
hi, the memory might truly be full...check your memory status and see if truly it is full....if after checking, you realized that it is full, then you will have to delete some messages and delete some applications that you use less often..but, if you check your memory status and you realize you still have space, then it means you will have to scan for virus.
cheers
Mar 16, 2011 | Nokia E63 Cell Phone
Wont send txt msgs
4.note it down
Good luck
Nov 10, 2010 | Nokia N95 Cellular Phone
Msgs sending Faild
check either u have correct balance and phone setting in your mobile about the sms sending options
Sep 17, 2009 | Nokia E66 Smartphone
Nokia n73
Please make sure your outgoing and incoming calls are not barred.
go to settings
go to call settings
go to call barring
and check the status of your outgoing and incoming calls.
There is also a line 1 and line 2 facility. Make sure you are using Line 1
Hope the above is helpful.
Thanks,
Kanu
Aug 04, 2009 | Nokia N73 Cellular Phone
Msg transfer probleam
hi no need to delete ur msgs. jus transfer all ur messages to drafts
Jan 19, 2009 | Nokia N72 Cellular Phone
Sms problem
hey donny, i presume that ur n72 is getting a virus, try backup all ur datas like phone numbers, msgs, pics, songs, etc, than re-format ur phone by pressing *#7370# on the front display. this will set ur settings to factory settings, if it can't solve ur problem, try hard reset. You have to turn off your phone, then, press 3 buttons at the same time, press '*' button, '3' button, and 'call' button, then while pressing those buttons (keypads), press the on-off button. press until it display 'format'. then wait until it formats ur phone, remember, ur battery has to be full during this process, if not, ur phone might be broken. (software, not hardware).
while what you say everytime ur cellphone buzz the stereo, it is natural, called electrical interference, but maybe what u mean is, everytime it buzz, means it always active on the signal, either sending msgs or making call, or doing a gprs connection. i hope those formats helps, remember, ur data will be loss, so backup first, then search for antivirus for nokia. is this still happens after you format and have antivirus, try other simcard, if it doesn't occur after u use other simcard. then ur simcard or operator has the problem. however if u think to trash ur phone, better send it to me ^^ haha.. just jokes. gud luck anyway.
Oct 04, 2008 | Nokia N72 Cellular Phone
Cant send text message on nokia n95 o2 but can recieve everything else
go to messages...
Im sure there is nothing wrong with your cellphone unit.
I think the problem is in your unit message settings, try to adjust it then observe if you can now send text msgs. Try to clear also all in the message counters.
Sep 09, 2008 | Nokia N95 Cellular Phone
Lands Phones Logo
50 people viewed this question
Top Nokia Lands Phones Experts
Piyush Lal
Piyush Lal
ASHRAF CA
ASHRAF CA
Are you a Nokia Lands Phone Expert? Answer questions, earn points and help others
