How do I replace the screws that fell out of the bottom of my monitor near the right hinge of my HP Mini 1000? Currently it only opens partially w little effort but may open fully w assistance.
  • 137 Answers
this is a simple screw and bolt problem.
look for solution in an electronics repair shop.
simple !
Posted on Sep 12, 2010
How to remove the oven door
On many models with the door open there is a screw on either side of the door on the inside. Each screw secures the door to the hinge. Remove the screws lift the door back to the near vertical rest position and carefully lift the door out from the hinges.
Caution the door is heavy!! The door must be in the near vertical position to have the hinge in a neutral location. There is significant spring pressure on the hinges. The door should be partial open held in a neutral position before attempting to lift up.
Dec 01, 2015 | Ovens
I own an HP mini 1000. A few days ago it fell down no so hard. At first I did not notice anything but at some point I could not open the LID properly. I noticed that the screen is a kind of detached or...
Hello Primo,
According to the problem you are facing is to be resolved only any laptop repair technician.
It is advice able to visit the HP service center and they will change the lid cover with proper care.
May 04, 2011 | HP Mini 1000 Netbook
Oven door does not close properly, light stays on.
Check the hinges at the bottom corners to see if the spring is still connected and see if the hinge is wore out. The door lifts off the hinge when it's in the partially open position after loosening the screw holding the door in position on the hinge. Slide the oven out a little to access the hinge to replace or inspect.
Jan 01, 2010 | Kenmore Ovens
I turn my dell vostro 1000 on and the screen is dark but if I hook it up to a another monitor and press fin f8 I can see my desktop how do I check my back light I think this is the problem
The first thing I would suggest is to tighten the LCD hinge screws on the bottom and back corners of the chassis. The LCD grounds through the hinge and if the screws work loose, then there isn't sufficient contact.
If that fails, the inverter or the LCD will likely need replacement.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+1000+lcd&_sacat=See-All-Categories
Nov 19, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Kleenmaid Stainless Steel oven door will not close properly.
The door hinge is probaly broken or could just be the spring. Open the door to the 45 degree position (halfway) and pull on the door. It should come off the hinge assembly. Slide out the oven a little to access the screws for the hinge to see what is broken or wore out.
Aug 10, 2009 | Ovens
The washer/spacer on the bottom of my right side door fell off, and the door now rubs when I open it. Can this be replaced?
Yes , order the parts by model number , then remove the 3 top screws (hinge) , then lift door up and off bottom hinge .
Jul 16, 2009 | GE GSS25JFM Side by Side Refrigerator
Broken (cracked) right Hinge on HP nc 4000 and Dell D600 Laptops
You can get replacement parts for this laptop, however it can get expensive. At the end of the day, you can use a super glue that is safe to use around electrical parts, but you might be better off just using an external monitor if you don't need to carry your laptop around.
Jun 01, 2009 | HP Computers & Internet
Replacement of keyboard on a hp ze 5000 laptop
My buddy and i put together a video a while ago for this you can find it here
This is not your model but the concept is the same.
Disclaimer: careful bad things can happen, not responsible etc etc :)
good luck and tell me how it goes, please don't forget to rate.
Nov 13, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
Broken hinge
Take the scanner lid off by squeezing the plastic hinges inserted into the back of the cabinet.
Take the top hinge of the cartridge door off with the 2 tork screws holding it, using a small screw driver.
Go to a hardware store & pick up a pair of cabinet hinges no more than 2". (You need to buy a pair because they do not come separate)
Place the new cabinet hinge on the back to the right of the bottom hinge of the base cabinet. Mark holes, drill one top, in the door, & 1 bottom cabinet, pilot holes. Check alignment & insert screws.
Tighten the bottom screws. Leave a little slack in the top screws as they have to be a little off set to close completely. You will only need to open this Cartridge door to change cartriges, so, no sweat.
My cost was under $5 for a pair of brass hinges, & my time, about an hour, taking my time.
It's too bad HP won't supply their offset hinges. They are inexpensive & easy to replace.
I've had my unit for exactly 4 years now, so this fix is a lot cheaper than buying a new one. Besides, I have ink already purchased that does not fit new printers.....go figure....
Aloha.
May 31, 2008 | HP Officejet 6310 All-In-One InkJet...
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
