Question about Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player
Numark cd mix 1
Cue and play buttons on both channels does not work properly. have to press hard to respond. and the player seems to skip often. i had this numark since 2005. pls help me. thanks
The buttons usually wear out, open unit and replace the buttons.
Posted on Oct 03, 2008
Numark ndx400
1 of yor tak switchs are faulty either cue or play button or maybe even the scratch button replace all 3 that should solve
Aug 03, 2013 | Music
Numark idj2 how to cue tracks
Pause on the point you want to be the CUE. Press play from this point and the point now changes to being CUE.
This is unlike most CDJs.
Sep 06, 2012 | Numark iDJ2 - DJ iPOD Mixer Docking...
My right side does not play
Hi I have the CD-Mix 1 unit and my left hand disk tray is doing exactly as you describe, i have dismantled the whole thing and tested out and looked at as much as i can and everything seems okay. It's almost like something isn't quite lining up properly when the disk tray is closed because I have found that pulling down the tray door and using my thump to hit the right hand side of the tray itself eventually gets the disk spinning. The main issue is that when you hit the unit so hard the cd playing in the other tray skips as you would probably expect...But at least this information might at least let you spin up one and then fade/mix with the other afterwards.
If you do find out the exact issue, please email me at littleguydan@googlemail.com
Thanks!
Jul 24, 2009 | Nu Mark Numark Cd-Mix-2 Dual CD...
Numark cue mixing
to change headphone track, use the cue slider which is located on the right of the control panel above the right chanel treble control and below the cue gain control. chanel 1 or 2 can be selected or in the middle for a mix of both tracks just like the cross fader.
Feb 24, 2009 | Nu Mark Numark Dxm06 DJ Mixer With 12...
Cdj 1000-mk-2
Could be either the Track skip switch has collapsed and is thus over sensative or the button bank is broken and the track skip switch is being pressed when the cue button is used.
Could also have liquid spillage on the circuit board which cause all sorts of random problems
Oct 21, 2008 | Pioneer CDJ-1000 CD Player
Numark cd mix 2
just clean the contact using the contact cleaner..remove the shuttle then spray the potentiometer..do not use the oil base cleaner!! look for quick dry non-residue electronic contact cleaner
Jan 21, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Numark cd mix 1
What kinda CD are you trying to play? The CD Mix 1 does not play CD-RWs. Do both bays give you this error? Need some exact info.
Jan 19, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Cdj-500ll cue button repair
the faulty button will not stop it from playing well... replacing them is not hard so long as you have some experience with a soldering iron.
Clean the laser lens with a cotton bud wet with windex... then use a dry one to be sure no residue is left. If it still mistracks... new optics required!. You willl need a pioneer service agent to do this for you. A little complex for the first timer :)
Jan 08, 2008 | Pioneer CDJ-500II CD Player
Numark cd mix 2
Well, it's not that hard to set up. What do you need help with? If you want to know how to connect:
1) The CD units go into the back of the mixer - in the CD / LINE INPUT - Left side on CD / LINE INPUT 1 and Right side to CD / LINE INPUT 2
The output of the mixer - MASTER OUT - goes to the INPUT of your stereo, amplifier, or receiver's LINE INPUT connection.
That's it. Press PLAY on your CD players, and raise the faders/volumes, and your all ready to go.
- TWEAK AV LAB
Nov 30, 2007 | Numark Fusion 494 Complete DJ Package
Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player Logo
252 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
da surgen
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
