Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
I have a Liftmaster 2000SD garage door opener and the other day the power at our house blinked on and off when the door was open. It wouldn't close after the power came back on so I manually closed the door. Later I went out and pushed to button to get the trolley to engage while the door was closed which worked but a few days later after the door opening and closing without problems it decided not to open. After looking everything over I realized the trolley was stuck in the middle of the track and I was able to get it reattached to the door and closed but now it won't open or close again. Not sure what to do
5 Suggested Answers
  • 3197 Answers
SOURCE: Garage door will not open
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. It is most likely stripped.
Posted on May 18, 2009
  • 52 Answers
SOURCE: Liftmaster 1/2 HP Garage Door opener won't open or Close
The shaft on these garage door motors are not direct drive systems. You'll have to open up the box to see what the actual problem is. I have had stuff like this happen where a gear just slipped out of place.
http://www.aaadooropeners.com/?gclid=CLH3wt628p8CFVZS2goduwSLYQ
Here is a link for a parts supplier. I don't know your model but it looks like most of the Liftmaster worm screw gears and drive gears are plastic so it's possible that one of them has cracked.
Posted on Feb 14, 2010
  • 23 Answers
SOURCE: We have a Liftmaster Professional Formula One
did you check the spring tention or it could be a problem with the track
Posted on Sep 13, 2010
swolfinor
  • 504 Answers
SOURCE: Liftmaster Formula One. Garage
Sounds like the gears are stripped.
Open the housing and see if there are white plastic shavings inside.
If so
You can get a gear kit and fix it yourself $ 35 - $50
Or for around $ 125.00 get a pro to fix the problem and lube, adjust, service the door and opener.
You pretty much have to take the unit apart all the way - it's not a simple project but it is doable for a diyer with reasonable skills 1-2 hours.
Follow the instructions step by step and don't cheat by leaving the gear thats hard to get to. The wear pattern on it will chew up your new gear in a few months and you will be doing it all over again.
Hope this helps
Posted on Mar 30, 2011
Liftmaster 1255lm garage door opener
It sounds like a problem with the infrared safety beams, either they are not working, are misaligned (someone might have kicked/bumped into one), or I even had one that didn't work because there was too many cobwebs/dust covering one of the lenses.
Feb 09, 2014 | liftmaster Building Materials
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
R garage door opener model 139.53640srt -remote car openers wont work suddenly. have to open using the house opener, whose light is blinking
Press and hold for 3 seconds the lock button on the wall control. The light should stop blinking and your remotes should now work.
Nov 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
We had a power blink during the night and the next day our garage door wouldn't go down, with the remote or even the house button, unless we hold down the house button until the door is completely down. No...
sounds like a problem in, i want to say the motor, but it opens fine, check your spring assembly, check your chain, and lastly, replace your opener, BUT FIRST, check to see if your garage door opener has a lock feature. most of them do, it disables all wireless remotes. if its only responding to the push of a wired button, then it may be in lock mode, find your manual. the lock button may be on the opener unit or the wall unit
Jan 05, 2010 | liftmaster Chamberlain Garage Door Opener...
Wall opener blinks but will open & close door.
Dec 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
My wired key pad in the garage opens and closes the door but the buttom keeps blinking fast. My two car remotes stopped working. My remote key pad on the house works. Whats with the fast blinking and...
Press and hold for 3 seconds the button on the wall control that has an icon of a lock. The light should quit blinking and your remotes will once again work. Holding that button for 3 seconds toggles your openers vacation mode.
Nov 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door remote
It sounds like the lock function has been toggled on. Press and hold the button on the wall control with the lock icon for 3 seconds. This will toggle that function off.
Jun 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opens/closes slugishly
COULD BE STRIPPED GEARS OR A BAD MOTOR.
IF YOU OPEN THE HOUSING AND FIND LOTS OF WHITE PLASTIC YOU NEED TO REPLACE THE GEAR KIT.
IF THE MOTOR IS BAD - BUY A WHOLE NEW UNIT.
HOPE THIS HELPS
Mar 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Transmitter not working ( 3 of them)
don't hold down green button. push for one second. do yu have console with vacation or lock button. deactivate it.
Dec 27, 2008 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
381 people viewed this question
Top liftmaster Electrical Supplies Experts
Mike
Gil Shultz
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
