Question about Fisher and Paykel DE06 Electric Dryer
Sqeaking when drying - Fisher and Paykel DE06 Electric Dryer
See the answer that just came through regarding the same problem submitted by rijbax2. I think that we have the same problem and the answer is right, I believe.
Posted on Nov 29, 2010
DRYER MODEL # YG20JN2 SQEAKS WHEN DRYING CLOTHES. DOESN'T DO IT ALL THE TIME, BUT GETTING MORE FREQUENT.
drum rollers/glides:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
idler pulley, belt may be wearing:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Mar 05, 2011 | Magic Chef Dryers
There is a sqeaking noise that goes away if I hold the glove box door
the hinge on the door may be loose or the strike try tighting the screws if that dont work i would use a lube called graphite its a dry lube used for locks and electric motors it also works well for sqeaking.
Dec 15, 2010 | 2004 Chevrolet Impala
Hotpoint dryer making sqeaking noises still dries and rolls fine but noises driving family crazy
There are two main causes of dryer noises: foreign objects in the felt strips, and dried bearings. To relube the bearings, you need to disassemble the dryer and pull the drum. Inspect all bearings, including the belt tensioner.
replace what is damaged by wear.
Dec 13, 2010 | Dryers
My truck is sqeaking around the belt? I have replaced the tenion pulley and the idler pulley but it is still sqeaking?
if the belt is dry replace it to for it will squeak as well.
also a glaze can be on all pulleys so wire brushing them all will clean the glaze off and eliminate the squeaks too
Jul 31, 2010 | 1992 Ford Ranger
When drying makes sqeaking sound
You probably have a bad bearing in the center at the back. Or the support pads could be worn out and its starting to rub metal.
May 21, 2010 | GE Dryers
Jeep Cherokee - Sqeaking Undercarriage
If the "sqeak" is more pronoused while going over bumps, then it is most likely a bushing in the front end. Check your fuel tank straps also, they may be loose. Sounds like this are always a pain to locate. Make sure nothing is in the back cargo area. You can also take your foot and shake the exhaust, WHILE THE CAR IS COOLED OFF OF COURSE.
You can also push down on each corner of the vehicle in the front and stand on the rear bumper to try to simulate or isolate the noise. That's all I have for ya. Good luck.
Feb 02, 2010 | 1996 Jeep Cherokee Sport
I have a Gelatao Magnum Plus that makes a horrible sqeaking noise
Maybe blade assembly it's loose, or bearing are dry, if you can take apart, use grease on the shaft and bearings. or replace motor.
Dec 23, 2009 | Kitchen Appliances - Others
Loud sqeak while spinning dryer works otherwise
could be the bearings on the agitator or motor or rubber seal is dry and squeaking
Dec 22, 2009 | Dryers
Sqeaking dryer
Find a heat resistant grease. It must say heat resistant. Then you will need snap ring pliers. The rollers are behind the drum, the whole machine must be taken apart, no fun. While apart, vacuum everything. Note how the belt goes before you take it off. A few extra screws while you're in there will expose the fan area. You will be suprised what you can find there.
Apr 02, 2009 | Maytag PYE2300AY Electric Dryer
Sansui Model: TVS2542A 27" TV
check line output transformer, look for dry joints
Dec 09, 2007 | SansuiM1315 TV
Fisher and Paykel DE06 Electric Dryer Logo
88 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
