Question about Philips HTS3450 System
I have got Philips Home Theatre 5.1 (DSP 25000) , but it is not giving expected sound. Right Rear speaker and Left Fornt Speaker are not giving any sound . Please let me know the solution. I have connected lines to DVD Playler to Home Theatre.
    Problem Solver:
  • 8 Answers
Firstly make sure you have connected the speakers to the main system in an proper order. Certain system's have the name of the speaker's mentioned at every output line which is at the rear of the system. If you would connect the wrong wires then it eventually would not play the sound. once this is done make sure that the wires of each speakers are split into two at both the ends. They are normally coded in red and black colours at the tip of the wire. Check if the red of the wire is connected to the red of the system and so on for all the speakers. So try removing all your connections and do it all over in a proper way.
Posted on Sep 13, 2010
Have a Philips 5000 series home theater system and just hooked it up and can not get any sound from the left side speakers front and rear. What should I do or I did not do Thanks.
Most of these home theatre systems come with a speaker set up. Try that. Also look at the speaker settings. It's possible that the speakers you mentioned are switched off, or their output is set to low.
Nov 25, 2016 | Philips Audio Players & Recorders
I recently bought Philips DSP 2500 Home Theater ... i dont have a cd player nor any dvd players. i want to connect it to my pc or my cellphone through aux .... so any sollution 4 this .... m planning 2...
hi! i am the computer expert i will solve your problem , just buy 4nos. 3.5mm jack(without wire connected) . Buy 3meter wire and solder it with one for pc and other 3 for the home theatre.
For more information contact: athibanbirla@yahoo.in, billa_2010@rocketmail.com, rathiban1998@yahoo.in, sachin_vvb@in.com, Ph. no +9104522381424 .
Got It
Oct 25, 2010 | Philips MMS 460 - PC multimedia home...
I need pinout assignments for a Philips 5.1 Home Theater Speaker system (PWR2006-37)? It has a DB-15 style input connector that hooks to the output of a Philips dvd / amp / control unit. this was...
Pin assignment is as follows (not sure of levels required- preamplification / attenuation may be necessary:
1: Control 0/5V.
2: Unused
3: Unused
4. Center speaker in
5. Ground
6. Ground
7. Subwoofer in
8. Ground
9. Unused
10. Ground
11. Left Front speaker in
12. Right Front speaker in
13. Ground
14. Right surround (rear) in
15. Left surround (rear) in
Jul 10, 2010 | Philips DVP642 DVD Player
How to connect 5.1 home theatre to sony bravia lcd tv
how to connect philips home theatre dsp 2500 to sony bravia
Jun 07, 2010 | Altec Lansing VS3251 Speaker
Instalation instructions required
Uhmmm. . .okay. . .I would use nothing less than 16AWG speaker cable. Do not run the speaker cable parallel in close proximity to any AC wiring. Speaker cable rated to run through walls with usually be color coded red and black. Connected the red to the red on the speaker and red on your home theatre receiver. Do the same for the black. If speaker cable insulation is clear, look closely for subtle markings or writing on the insulation. The writing will only be on one of the two wires. Designate that as the POS or PLUS or + or RED. Connected it to the red on the speaker and the red on the back of your home theatre receiver. The other is by default the black and connect it to like colors. Repeat for all 5, or 7 speakers in your theatre. Your subwoofer probably has a seperate amplifier, so it gets it's power from it's own AC power plug. . .so plug it in. The sound coming from the Home Theatre receiver will be low-power and will carry on an RCA cable. Look for the subwoofer output on the home theatre and connect it to the input on the subwoofer. There may be a right and a left input on the woofer. . .it doesn't matter which you plug it into. . .either one will do.
Mar 09, 2009 | Audio Players & Recorders
4.1 speaker setup
So basically if im guessing right you have four satellite speakers(left, right, left surround and right surround) and a sub woofer.
it is reletively easy to setup any sort of surround solution.
the front speakers shoud be set at ear level or angled towards the listening position and the rear speakers shoud be set in a straight line to the ear at a max height of two feet. or at the rear of the room, same height agled towards listening position.
The sub can be place anywhere in the room.
if you give me specific details like size of room type of speakers power handling of speakers, type of amp you are usuing seating area etc i could help you out futher.
all the best
cheers
Jul 15, 2008 | Audio Players & Recorders
Fornt speakers does not have any sound.
remove the front speakers cables from the rear-remove surround speaker cables from the rear and put them in the place of front speaker-run a music if you get good sound the problem in your front speakers(speaker or its cable)-if you got nothing you will have a problem in your system itself and need to fix in service center.
Aug 29, 2007 | Panasonic SC-HT930 System
Philips HTS3450 System Logo
170 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
