Question about Vulcan VG260 Gas Kitchen Range
6 burner propane fed will not allow all burners to produce a usable flame for cooking,grill is not hot enough
    Sergeant:
    Novelist:
  • 193 Answers
I need more information, but I suspect you may not have a large enough regulator on your propane line. The only way to know for sure is to attach a gauge called a manometer onto the manifold that feeds the gas burners. There is a 1/8 inch pipe fitting on the manifold for this purpose. It should read 10 inches of water column. You need a capacity to run about 300,000 BTUs when everything is on at the same time. This requires a large capacity regulator. Also the line from the regulator to the range should be at least 3/4 inch pipe.
Posted on Sep 13, 2010
Grill troubleshooting
It's not getting hot enough.Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 31, 2014 | Holland Grill Classic II (NG)
I can not get my flame to come up to temp. When I turn one of the other burner on the first flame dies down to nothing. It is just not generating enough heat to cook. I did try different propane tanks and...
This is a typical symptom of a failing LP regulator. Replace the regulator and hose that attaches to the LP tank. When a regulator is failing, it allows enough gas through for the burners to light, but not enough to keep all the burners going at the same level.
Jul 03, 2011 | Jenn-Air Grilling
I have a Cook by Number gas grill, model LG36C, that isn't cooking as hot as it should. I've disassembled all the gas lines and blew them out with compressed air. I cleaned the burner. I cleaned the...
Since your grill only has one main burner and it requires more gas to heat with than the side burner. I still suspect you have a grill regulator issue. But, if you've done your research, you know it's easy to solve. Turn the propane tank valve OFF. Disconnect the hose from the tank valve and wait at least 5 minutes before reconnecting it. Once it has been reconnected, turn the tank valve on VERY, VERY SLOWLY (slow motion, slow). Once the tank valve is fully open, turn your main burner on, light it and turn it to high. Do the flames appear to be higher than before? If so, light and turn ON the Side Burner. Now do all the burner flames appear to be higher than before? If so, you solved the problem. If not, either the grillhose/regulator assembly needs to be replaced or the Venturi Valve on the main burner needs some adjusting. As the air to gas ratio may be off sightly.
Hope this helps to solve your problem and Happy Grilling!
Mar 29, 2011 | Fire Stone LG36C Propane
My weber genesis silver starts up, but doesn't get hot enough to cook the food. Seems like not enough flame out of either front or back burners. I tried Outting in a full propane tank, but that didn't...
Try these steps in order.
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
Sep 06, 2010 | Weber Genesis Silver B Grill
The burners do not get a full flame anyomre, nor
you may have spider web in the burner ... disassemble and blow it out with canned air or a air compressor ...
May 02, 2010 | Brinkmann Charmglow 810-7400-S Propane...
I can not get any gas pressure in main burners or side burner, i have a new propane tank, just a trickle of gas not even enough to keep side burner going when only using side burner, will only produce a...
Look for spider webs in the venturi tubes, check the orfices or it could be faulty controls. Verify the tank working properly by trying on another grill.
Eric
Jan 24, 2010 | Brinkmann Charmglow 810-7400-S Propane...
How do I take my Weber Genesis grill apart to clean the burners? The burners are not heating up properly. The flame is very poor and not hot enough to cook food.
Turn on just one burner, once it is lit, turn on a second burner, if the flame gets lower or goes out, you probably need a new regulator.
Dec 03, 2009 | Weber Genesis Silver A Grill
Propane flame is not blue but too high
A yellow or orange flame means (1) too much fuel, or (2) not enough air. Make sure the air ports where the regulator attaches are clear and that spiders or bugs haven't built a nest in the burner tube. If that's all clear, it's likely that the propane regulator has failed and is allowing too much fuel to enter the burner tube. The regulators are inexpensive and are not repairable; get a replacement unit.
Oct 08, 2009 | Weber Gas Go-Anywhere Grill
Not enough gas through buners
it may be the regulator not sure but a easy fix
Jul 12, 2009 | Grilling
Weak Flames on Propane Grill
It is possible that your burners are clogged. Clean the burner ports with a paperclip (not a toothpick).
Jun 01, 2009 | Kenmore Elite 644 sq. in. Cooking Area Gas...
Vulcan VG260 Gas Kitchen Range Logo
98 people viewed this question
Top Vulcan Kitchen Ranges Experts
Treefrog15
Treefrog15
Paul Carew
Are you a Vulcan Kitchen Range Expert? Answer questions, earn points and help others
