Question about Maytag M7DH65B2A Dehumidifier
Moldy air just recently, the humidifier started to blw moldy air.... any remedy?
  • 3 Answers
Clean it - this model collects mold if the drain hole gets plugged. You will need to take it apart to do so.
Posted on Jun 22, 2008
Unit trips the breaker when turned on.
could be a lot of things, start capacitor on the motor, control cct etc etc needs an engineer, or use of a test meter to find fault
Aug 04, 2014 | Frigidaire Fdl50s1 Air Purifier &...
GE Humidifier smells terrible
Probably mold in the collection device that empties into the bucket. Try applying Lysol or similar mold killing spray. This is a big problem with automobile air conditioners too.
Sep 13, 2012 | General Electric 65-Pint Dehumidifier...
Start up instruction for dehumidifier
A dehumidifier does not need water in the tank.It takes humidity out of the air and the moisture goes into the bucket. A humidifier has to have water in the tank.Note ,a humidifier puts moisture in the air, and a dehumidifier takes the moisture takes moisture out of the air.
Feb 16, 2010 | Kenmore 54501 Dehumidifier
My dehumidifier is making a power surge every few minutes. why?
A dehumidifier is functionally the same as an air conditioner. It has a compressor motor, which is a fairly high current draw item.
First of all, unless you are well versed in electrical repairs, you should unplug this unit and do not use it. This is a dangerous condition and a fire or electrocution could result.
One of four things is happening:
1) You have a wiring fault in the circuit your humidifier is plugged into. There is a loose connection in the circuit, causing a voltage drop, and the humidifier therefore has to pull much more current to start it's compressor. This is a very dangerous condition, as an electrical fire could result. Try plugging the unit into another circuit and see if it does the same thing.
2) the compressor of the humidifier is going bad and is shorting out internally. Time for a new unit.
3) Many compressor motors use a 'start capacitor' to help the motor get going. If this part has failed, the motor will try to start, but it will not be able to.
4) There is a fault in the power cord or controls of the humidifier. Just like #1 above, a loose connection could cause a voltage drop, making the unit draw high current.
most of these units are standard 110V units. If yours uses 220V (like an electric dryer), then it could have 'lost a phase' which is also a similar electrical issue.
Oct 16, 2009 | Dehumidifiers
I NEED TO KNOW WHAT PERCENTAGE MEANS ON A DE-HUMIDIFIER
In plain English, the Percentage setting on your de-humidifier is the percentage of moisture that you want to maintain in the air. Relative humidity level range from about 10% (VERY dry air) to almost 100% (VERY damp air). When relative humidity is 100%, water vapor in the air will turn into rain, condensation, dew, snow or frost. 50% humidity is usually a comfortable level, but that will also depend on air temperature. The more moisture there is in the air, the warmer it feels and conversely. Warm air will hold more moisture than cooler air.
Your body is cooled when moisture on your skin evaporates into the air, carrying body heat with it. As the humidity in the air rises, less of your body moisture is able to evaporate and thus your body feels wamer. Lower humidty allows moisture from your body to evaporate more quickly and you feel cooler, both at the exact same temperature.
Jun 28, 2009 | Kenmore 54701 Dehumidifier
Humidifier Fan Doesn't Stop
RH at 70 % seems to me a little excessive you really should be working somewhere around 50 to 56% the fan has to move Air through the system.
I would like to know your room Air temp what is the Air temp comming off the system. what are your parameters.
Jun 08, 2009 | GE AHG40LA Dehumidifier
De Longhi DE220 De-Humidifier not collecting water
Hi there - you have to vacuum the filter several times. You can pull it out of the back left hand side of the unit. Vacuum it several times, and then start the unit on the lower fan setting, at a humidity level of around 60%. It will kick in after a bit, and then you can start adjusting the humidity level to where you would normally use it.
Sometimes - after you have vacuumed the filter, it still doesn't work. I used my fingers to pick lint off the filter, and ran a BIC safety razor over it as well, to try and get more out of the filter. You can also wash the filter in warm water, and leave it to dry over night. Don't put it back in until it's completely dry.
This will work! Cheers... E
Sep 12, 2008 | DeLonghi DE500 Dehumidifier
Humidifier Runs but no water collected
Are you talking about a dehumidifier or a humidifier. If you are talking about a dehumidifier, it works by blowing air across a cooling coil causing condensation and the water will drip and pool. The cooling is caused by a compressor working like refrigerator, but using the effect to dehumidify. To check if the cooling coil is working there will be a metal can like in it with tubes in and out. One of the tubes should be warm(input) and the other tube should be cold, if not your compressor is not working. If freezing up, low freon. Check to see if the compressor shuts off very quickly, that would be too much freon. This is not user servicable. Now a humidifier works several different ways. One way is a fan with cloth belts rolling through water using evaporation to humidify. Another way is for a circular fan like on a motor to turn. It has a hollow piece into the water. It picks up water and then through centrifugal force aerates. One way is for a sonic humidifier. All the types have a problem with eventual calcification or mineral build up in the water handling paths. Lime-away or Concentrated Lemon Juice will dissolve this. The lemon juice is the most fun. It will turn your toilet bowl white and also remove rust stains from laundry...
May 01, 2007 | Maytag M7DH65B2A Dehumidifier
Humidifier is very hot
doubt if there is a fault. if something gets cold ie freezing section then something else gets hot
Mar 18, 2007 | Fedders RDG40 Dehumidifier
Maytag M7DH65B2A Dehumidifier Logo
66 people viewed this question
Top Maytag Dehumidifiers Experts
Bill Long
Steve
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
