Question about Sony PlayStation Portable (PSP) Console
D-pad how do you clean the D-pad out?
    Guru:
  • 155 Answers
If you take off the front cover then it is extremely easy to clean it. This will void your warranty.
There will be a screw on the bottom to remove, two on the back and three under the battery cover. (one is under the left hand side of the warranty sticker - this is why it voids your warranty)
Don't lose the screws: keep them somewhere where they are not going to move and lay them out so you know how to put them back in.
Once you have taken out the screws then the front will come off and you will be able to see the D-Pad and you can then clean it/the contacts.
Hope this helps
Mowcius
Posted on May 16, 2008
Need self-cleaning instructions....missing manual.
To Self-Clean: 1. Close the oven door. 2. Move the door lock lever to the right to the locked position. 3. Press CLEAN. 4. Press the "up" or "down" arrow pad. CL-M (Clean - Medium soil, 3 hours) appears in the display. If the door is not closed, beeps will sound and "door" will appear in the display until the door is closed and the Clean pad is pressed again. If the door is not closed within 45 seconds, the self-cleaning operation will be canceled and the display will return to the time of day. If more than 5 seconds elapse between pressing the Clean pad and the "up" or "down" arrow pad, the program will automatically return to the previous display
5. To choose a clean setting other then Medium, press the "up" or "down" arrow pads to scroll through the self-cleaning settings. CL-H (Clean - Heavy soil, 4 hours) CL-M (Clean - Medium soil, 3 hours) CL-L (Clean - Light soil, 2 hours) Choosing a cleaning level automatically programs the selfcleaning time. 6. After 4 seconds, the oven will start cleaning. "LOCK" and "CLEAN" will appear in the display. The cleaning time will count down in the display. To Delay Start Self-Clean: Before delay starting Self-Clean, make sure the door is closed completely or it will not lock and the cycle will not begin. 1. Press DELAY. "DELAY" will flash and "00:00" will appear in the display. 2. Press the "up" or "down" arrow pads to enter the amount of time you want to delay the cycle. Delay time can be set from 10 minutes (00:10) to 11 hours and 59 minutes (11:59). 3. While "DELAY" is flashing, press the CLEAN pad. "CLEAN" will flash in the display. 4. Press the "up" or "down" arrow pad. CL-M (Clean - Medium soil, 3 hours) appears in the display. 5. To choose a clean setting other then Medium, press the "up" or "down" arrow pads to scroll through the self-cleaning settings. CL-H (Clean - Heavy soil, 4 hours) CL-M (Clean - Medium soil, 3 hours) CL-L (Clean - Light soil, 2 hours) Choosing a cleaning level automatically programs the selfcleaning time. After 4 seconds, "CLEAN," "DELAY," and "LOCK" will appear in the display to show that the oven is set for a delayed clean operation. The delay time is displayed
Apr 21, 2015 | Kitchen Ranges
Locate waste ink absorber pad
canon pixma ip1000 printer, how do you access and clean waste ink absorber pad
Apr 13, 2010 | Office Equipment & Supplies
Sand paper pad no longer holds the sanding disk
If pad is hook and loop style use compressed air or clean nylon brush to clean debris from hooks.If using adhesive backed dics try wiping a little alcohol across the pad surface to clean it.
Jan 09, 2010 | Dewalt DW421 5'' orbital sander
Ink absorber replacement options - MP130 or how do I clean it? It is almost full according to error message
Removing & Cleaning the Absorbent pads.
The printer has 2 ink absorber pads that are located under the ink cartridges.
1. With power off the head assembly / cartridges can be moved into the middle for access.
2. Each of the 2 ink absorber pads are seated in a rubber retainer. The pads can be easily removed cleaned or replaced.
3. Carefully remove the pads using long nose pliers or tweezers.
4. Clean the using with running warm water, or use an isopropyl alcohol bath, or an isopropyl alcohol based aerosol if they are really dirty. DO NOT USE ANY SURGICAL SPIRIT OR ANY OIL BASED CLEANERS. At a push you can use a warm water mild washing up liquid bath but be sure to thoroughly rinse out the solution after cleaning. The pads should be white when they are clean.
5. Dry the pads – it may take some time and placing them in a warm environment or near a warm radiator will speed this up.
6. Clean away any ink on the retaining rubbers using a cotton bud or clean and soft lint free cloth.
7. Replace the DRY pads in the rubber retainers.
8. Replace the Ink cartridges.
9. Power on the printer and print a test page and clean and realign the heads as required.
10. If the E27 error message reappears then you will need to reset this.
Clearing procedures for E27 or Error 27 Code.
1. Power on the printer by pressing the Power button while pressing and holding the Stop/ Reset button.
2. When the Power led is green press the Stop/Reset button two times while pressing and holding the Power button.
3. When releasing the Power and the Stop / Reset buttons the printer will move into a service mode and will be Waiting for a menu selection.
4. When the Power led is green, press the Stop/Reset button 4 times for waste ink counter reset.
5. Power off the printer and Power it back on again to complete the reset.
Oct 23, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Hi, Waste Ink asorber is full on my Canon PIXMA IP2000, can I find a replacement??
Oct 21, 2009 | Canon Office Equipment & Supplies
My cannon printer/copy machine says my ink absorber is full. What does that mean? what do I do?
The printer has 2 ink absorber pads that are located under the ink cartridges that collect the waste ink.
Oct 07, 2009 | Canon Office Equipment & Supplies
I have HP PSc 1210 all in one printer. It does not load the paper. It makes grinding noise as it is trying to load it. But does not work. Any help will be appreciated.
the noise is coming at the time of cleaning the cartridge.you can remve the printer top cover and right side of the printer you can see the waste ink pad .clean the pad and cartidge cleaning pad. put some grease in the cartrige cleaning pad moving unit area.
Sep 25, 2009 | HP PSC 1210 All-In-One InkJet Printer
Needs new ink pad
I always clean my inkjet printers using isoprophl alcohol. It dries quickly and helps remove the ink. Try that first.
Jun 12, 2009 | Epson Stylus Photo RX500 Printer
I need direction on how to start the clean cycle on my jenn air
CLEAN PAD
Use to set a self-clean cycle or a delayed
self-clean cycle. One press of the Clean
pad sets up an immediate clean cycle. A
second press of the Clean pad sets up a
delayed clean cycle.
• Clean oven
frame, door
frame (area
outside of gasket)
and
around the
opening in the door gasket with a nonabrasive
cleaner such as Bon Ami*. These
areas are not exposed to cleaning temperatures.
• Remove air grille.
• Remove oven racks. If racks are left in
during a clean cycle, it may impair function
and they will discolor. Turn off the
oven light and close door.
* Brand names for cleaning products are
registered trademarks of the respective
manufacturers.
TO SET FOR IMMEDIATE START:
1. Press Clean pad once.
2. Press the Auto Set pad for 3 hours of
cleaning time, press again for 4 hours
and again if 2 hours of clean time are
desired.
3. CLEANING and LOC plus the clean
time will appear in the display.
4. When the clean cycle is complete,
CLEANED will be displayed. LOC will
remain on until the oven has cooled
(approx. 1 hour).
5. When the oven is cool, LOC will no
longer be displayed and the door may be
opened.
6. Wipe out the oven interior with a damp
cloth. If soil remains it indicates the
cycle was not long enough.
TO CANCEL SELF-CLEAN:
1. Press Cancel pad.
2. If LOC is NOT displayed, open oven
door. If LOC is displayed, allow oven to
cool.
Thanks for using Fix Ya, Please take the time to rate this solution.
clarkco
Feb 08, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Maytag gemini self cleaning oven feature
Close door on lower oven (upper oven is not self clean). Press "Clean" pad. Press More pad or Less Pad. H is 4 hour clean, M is a 3 hour clean cycle and L is a 2 hour clean cycle. The door will lock and cleaning will begin. Good Luck!
Dec 18, 2007 | Maytag MER6872BAS Gemini Electric Kitchen...
Sony PlayStation Portable (PSP) Console Logo
23 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
