Monitors
Problem for HP Monitors
Generic problem for all HP Monitors
Monitor problem
By jack39 on May 14, 2008
My monitor just stop working, first it started blinking and them it just went blank....any suggestions?
Solution #1
posted on May 15, 2008
Not Rated)
worldvet
Rank: Guru
Rating: 91%, 846 votes
Disconnect the cable from the computer and see if you have the same problem. If you don't and you get a no signal present message the problem is related to your cable's connection to the display adapter connector or your display adapter itself.
I can assist you further if you get the expected message above after disconnecting the cable.
If it does the same thing after disconnecting the cable the monitor is no longer any good and has failed. There is nothing you can do to fix this problem other than to take it to a qualified repair shop that will work on monitors or you could have it replaced under warranty if one exists.
Hope this has fixed ya.
Regards,
Worldvet
Was this helpful?
Yes
No
Popular Solutions for Monitors
Questions and Unsolved Problems for Monitors
Answer
I need a monitor to work on a old industrial machine it must be vga compatible
Answer
First my monitors was turning off every few seconds, and was only turning back on when i unplugged... (More)
Answer
There is no sound coming for my desktop with Compaq 7500 monitor. Please suggest what to do.
Answer
I have a MAG 700p, it comes on fine then goes black.....after a minute or so....help!
Answer
have 22" monitor and need to know how to remove the boot that fits into table base?
Describe your Monitors problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
in Newport, KY
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
