Question about HP iPAQ RX3115 Pocket PC
Have to keep setting up Ipaq
Everytime I turn it off, I have to set it up all over again. Starting from having to align it, using the stylus, etc. It doesn't save any information from previous set ups. It also doesn't stay charged, and turns off in the middle of me using it. any help is appreciated.
Thanks a whole lot!!! i ordered one!!
Posted on May 19, 2008
  • HP Master
  • 13,433 Answers
Battery is dead. You have to replace the battery and possibly the backup 3v battery if this model has one.
These batterys are sold by HP and for most models you can find them from ebay
heres a few - EBAY
  • Ekse Jun 01, 2008
    This thread has gone 7 days or more without a response. Please close the thread with a “FixYa” or “Helpful” rating.
    If the issue is not resolved, please post back with latest developments, what steps you took, etc. and I will assist you further as best I can.
    Thank you.
I have an HP iPAQ 6920 with a Keypad Security Lock Code. My son while playing with the phone repeatedly entered the wrong code and now it's not accepting my original code. Also there's now a 2m 08s...
Welcome to Fixya
Passwords are encrypted type. There is no special code that you need to enter to bypass the password for this unit. The only way for you to use this unit again is to do a Hard Reset. Meaning everything will be back to original factory state. If you decide to do that, then please follow the procedure below:
A clean reset clears all user-installed settings, programs, and data, and restores
your HP iPAQ to factory settings.
To perform a clean reset and return your HP iPAQ to factory settings:
1.Press and hold the Answer/Send, Power, and End Call buttons.
2.While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the HP iPAQ until the device restarts.
3.When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button.
The HP iPAQ restarts and powers on.
Thank you for using Fixya!
Dec 24, 2010 | HP iPAQ hw6920
Touchscreen not reacting to stylus but the buttons work ok
  1. urn on your HP iPAQ Pocket PC.
  2. Use your stylus to tap on the "Start" menu.
  3. Tap on the "System" tab.
  4. Tap the "Screen" icon.
  5. Tap the "Align Screen" button.
  6. Tap the center of the cross-hair object carefully at each location as it moves around the screen.
  7. Tap "OK" to complete the screen alignment.
Mar 28, 2010 | HP iPAQ rx5915
Hp rx4540.How to access the Boot loader mode?? .My ipaq just displays the hp logo on start up and then just freezes.Ive tried soft and hard reset.Help please
A factory reset erases all user-installed settings, programs, and data, and restores your HP iPAQ to factory settings.
CAUTION All user-installed settings, programs, and data are erased from memory with a factory reset.
To perform a factory reset and return your HP iPAQ to factory settings:
  1. Press and hold the OK and Rotate Screen buttons.
  2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until the device restarts.
  3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button.
The HP iPAQ will now restart and power on.
If you have done the above and still no go. Then your main drive has probably failed.
Link below is a repair how to video
http://www.wonderhowto.com/how-to-repair-hp-ipaq-rx4200-rx4240-rx4500-rx4540-243534/view/
Mar 11, 2010 | HP iPAQ rx4240 Pocket PC
Model 2003 ipaq, can't get past alignment screen
try a hard reset(hold down the 2 outside corner buttons,calender and home, then use the stylus and press the button on the back). if this does not help, go to HP support site and get the latest ROM update, download and install. this will completly set device back to factory settings, your sync folder will still have all contact, pics, appmt.,etc. hope this helps.
Jan 17, 2010 | Microsoft Windows Mobile 2003 for Pocket...
HP iPAQ 2490B can not be hard reset
remember that you must hold down the two buttoms at the same time then push in the reset for 2 sec (holding it in). release the 2 buttoms then remove the stylus for the reset port. after about 4 sec press & release the reset buttom again, sytem will pwr up. If this doesn't resolve the issue then try the clean reset but bear in mind u will loss any thing u installed on the ipaq as system go to default setting and u will be required to align the screen. good luck
Mar 07, 2009 | HP iPAQ HX2490 Pocket PC
Hp ipaq hw6915
Try a Reset....
Performing a Clean Reset will help
Thanks
Nov 03, 2008 | HP iPAQ hw6915 Smartphone
Ipaq H3630 how to do a hard reset
Compaq iPAQ h3630
Resetthe iPAQ H3000 and Clear Memory
Resetting the iPAQ
Ifyour iPAQ H3000 responds slowly, stops responding as expected, or“freezes,” try resetting it. A reset causes the iPAQ H3000 to restartand re-adjust memory allocation. Unsaved data in open windows may belost. Use the stylus to press and hold the Reset button for about twoseconds.
NOTE:Do not turn off your iPAQ as it must remain on in order to reset.
Clearing memory
Ifyou want to clear all data from your iPAQ H3000 and return it to thefactory settings, you should clear the memory.
Clearingmemory deletes all data and restores the iPAQ H3000 to its defaultsettings. Programs installed at the factory remain, while data you havecreated and programs you have installed are erased.
1.Using the stylus, slide open the On/Off door on the base of the iPAQH3000.
2.Slide the On /Off switch to the Off position using the stylus. Waitabout one minute, then slide the switch to the On position.
3. Close the Battery On/Off doorusing the stylus.
NOTE
:Use CF Backup/Restore or ActiveSync to keep a backup of your iPAQ dataso that if you need to clear memory, you can restore the data on youriPAQ.
http://www.hardreset.eu/compaq_ipaq_h3630_hard_reset_soft_reset_en.html
Aug 29, 2008 | Compaq iPAQ H3630 Pocket PC
IPAQ 6365 hard reset
I Also Had The Same Problem. Now I Fixed It. Go To Power In Settings. Click On The Advanced Tab. Uncheck The Box Which Says "Turn Off The Device If Not Used For" Box. This Will Solve The Problem. It Solved Mine. Thereafter Once, My Backlight Did Not Switch On. Fix This By Going Into Backlight Settings And Uncheck The Box Which Says "Turn Off The Backlight If Not Used For" Box. This Will Solve It. Then Soft Reset The Device To Change Settings. To Soft Reset, Find A Small Hole In The Left Hand Side Of The Device. Put Your Stylus In And PRESS ONLY ONCE. If You Keep It Pressed, Your Device Will Hard Reset. Don't Do That. Just Press ONCE.
Mar 31, 2008 | HP iPAQ h6315/h6365 Pocket PC
Screen not responding to stylus
SOLUTION:
KEEP PRESING CALENDAR+MAIL+POWER BUTTON
AND INSERT STYLUS IN RESET BUTTON
Nov 26, 2007 | HP iPAQ H1940 Pocket PC
Ipaq RX 3115 Stops at align Screen
solia, I'm sorry, I didn't mean to close the chat session on you.
Is your unit still under warranty? If so, check with the manufacturer.
They can help.
Mike
Sep 27, 2006 | HP iPAQ RX3115 Pocket PC
HP iPAQ RX3115 Pocket PC Logo
79 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
