Question about Proform 775 Crosstrainer Treadmill - Free Silver Service Delivery!
We set up the Proform 775 cooling breeze treadmill, plugged it in and attached magnetic safety key. Immediately, the incline increased to the highest level without pressing any keys. Now the incline is stuck at level 10 and will not lower. We tried all the suggestions like disconnecting power, resetting, checked the voltage of the white to black then white to red wires, which showed no power, etc. Everything works fine except for the incline is still stuck.
SOURCE: Pro Form 745cs Treadmill does not incline
My jack screw needed to be adjusted. It is a long screw about 1" in diameter. If you take the cover off, you should clearly see the jack screw. If you adjust the incline with the cover off, you should see the jack screw rotate. One end of the jack screw may have come out allowing the screw to rotate freely and not raise the incline. If you can reengage the screw, it may work. I don't know if this will help, but I needed to do it.
Posted on Jan 11, 2009
SOURCE: proform 360p stuck on incline
I had the exact same problem.
This usually happens if you switch it off at the mains while the incline is adjusting or is somewhere other than lowest. You should always make sure before finishing off, to lower everything.
Now for the solution: If you open up the case it has 5 or 6 black philips (cross head) screws (use your user manual if you don't have your original go to proform and find the support link and download the .PDF if your model is not available get the one before or after in the same model product line (model number is below the power input)).
Make sure you remove the power before opening the cover, obviously.
Anyway, once opened, you should find a sheet of paper wrapped around in some plastic wallet. On that paper it should explain everything. Try not to mess with too much things in the settings, otherwise you might mess it up badly.
Mine is something like: Hold the speed up (+) button and then while holding the button insert the key - that will get you to the service menu (obviously the power has to be connected).
Once in the menu pressing the incline up does a self-calibration (maximum up and maximum down) after that it should be perfect.
Remove the key any time to come out of that mode and resume normal operation.
I may not find this place for any more replies 'cos i only found this site by accident. While looking for info. on my burnt out motor model: PETL 3013.6 .... But i have come across someone selling a faulty one on ebay for like 5 quids... it's picking it up the trouble!
Posted on May 31, 2009
SOURCE: My Proform treadmill will not incline. It is stuck
My proform treadmill is stuck on the highest incline (10) and it doesn't budge from there..Help my workouts are killing me!
Posted on Jun 24, 2009
SOURCE: Proform 550xp Treadmill in continuous incline/decline mode!!!
i just called the manufacturer on this and found out i have a faulty control panel, but these are the steps they told me to go through to reset. If it works, then you are good, if not, you may also have a control panel issue.
1. plug in and turn on treadmill, keep red key out
2. press and hold the stop button and speed up button at the same time and hold them while you insert the red key
3. after red key is inserted, let go of both buttons
**CAUTION - be sure to stand on side bars of treadmill, clear of the belt for this next part bc it will go VERY FAST***
4. press stop button once
5. press speed up button until it reads 85 (see what i mean?!)
6. press stop button once
7. press incline down or up one time and it should get back into normal mode. mine just started a series of flashing lights and "8"s in all the "windows" so my panel needs to be replaced. here is the number i called - 1-877-993-7999. Good Luck!
Posted on Jan 06, 2010
maxtreadmill
  • 832 Answers
SOURCE: I have a proform xp 580. when I turn it on,
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
After completing calibration of incline, press the Stop key and then remove the safety key.
Posted on Jun 14, 2010
I just replaced the drive motor. How do I calibrate the treadmill before use?
Hold the stop, + speed button and attach the safety key. You should get the software version on the speed window. Continue to hit the stop button until you see zeros on the incline, speed, and heart rate windows. Your incline and speed numbers should match, if not increase the speed to 10 MPH and turn the POT resistor until the numbers match on the windows. The pot resistor is on the Motor control board
Mar 03, 2015 | Proform Exercise & Fitness
Why won't incline go up or down?
Calibrating Your Incline Is your incline not operating correctly? There are a few simple steps that can be followed which will most likely resolve that problem for you.
9bvipvsqvatex9kgfcnn03s5zhvtng9too4023mrox7s22mjjuue73rxrrhupctrxro022nhu0i53bbtrxqocdrxro402hhw0410bbbtxqkad79poo41hbe1410ybbtwq+p8byj8qzuzzwaoaaaaasuvork5cyii=
The first step is to press and hold both the STOP and SPEED INCREASE buttons, this will be either an UP ARROW or a + (plus) symbol. While holding these two buttons down you will need to insert your safety key.
Once you have inserted the safety key you can release the buttons and let go of the key. At this point you will need to press the STOP button one time. Congratulations, you are now in Calibration Mode.
Now that we are in calibration, press the INCLINE UP button one time. This will cause the platform to go all the way up and then it will come all the way back down again.
Now that the incline has stopped moving you can remove the safety key.
Parts for ProForm Fitness Equipment Treadmills Bikes Ellipticals Belts...
Apr 26, 2014 | Proform Sport 1000 Folding Treadmill...
Incline stuck
Run the software calibration for fix it.go under the HOOD motor and follow the steps or use the owner manual
God bless you
Jul 26, 2013 | ProForm 775 CT Treadmill
Proform 995 sel will not incline
Try calibrating the incline.
Start the machine. While the machine is operating, press and hold the incline up button. Remove the safety key. Now replace the safety key. The treadmill should go to full incline, then back to the bottom. Once the cycle is complete, the machine should work normally.
Feb 26, 2011 | Proform Exercise & Fitness
I cannot get it to incline. It will say it goes from .5 to 10 and not incline at all
First perform an incline calibration. The procedure is outlined in your users manual.
It is a simple procedure. Insert the safety key and start the machine in motion. Press the incline up button. While the numbers are increasing remove the safety key.
Now reinstall the safety key, the machine should incline to maximum then lower back down to minimum.
Now you can operate the treadmill, the incline should work.
Jan 04, 2011 | Proform CrossTrainer Treadmill
My proform treadmill turns on and the inlcline works however the belt does not move. Any suggestions?
Enter calibration mode and do a calibration first.
Press the stop & speed up key, insert the safety key/magnet. Press stop 1 more time. Press speed up, the speed display should start to increase in value. By 30-40, the motor should be running. If not, you either need a motor or motor controller PCB. What model is the treadmill?? PCTL???
Dec 14, 2010 | Proform Exercise & Fitness
We have a 600 mx and the pad is not working, the only button working is the start, i cannot increase speed or incline it either.
It is very unusual to have no incline or walking belt operation..
Try entering diagnostic mode and do a calibration. The instructions are found under the motor cover on a tech sheet.
1: with the safety key removed, press stop and speed up simultaniously.
2: Attach the magnetic safety key.
3: press stop 1 time.
4: at this time, by pressing the incline up, the incline should calibrate, going up to maximum then back to minimum..
5: press the speed up key, you will see the numbers on the console increase. The machine should start moving the walking belt around 25-30 on the display. At 85 the belt should be running at maximum speed.
6: press speed down, the machine should stop.
7: remove the safety key. Now replace the safety key and try the machine again.If any of this procedure didn't work, I would suspect a defective console. Otherwise, the motor controller may need replacing.
Good Luck
Dec 14, 2010 | Epic 600 Mx Treadmill
Proform Crosstrainer 5.0 Treadmill
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
Jul 15, 2010 | Proform Exercise & Fitness
Jun 12, 2010 | Proform XP 580 Trainer Treadmill
Treadmill LED Track does not go to start with key inserted
I pulled the safety switch out, and the elevation is stuck on 10 degrees
May 14, 2009 | Proform 775 Crosstrainer Treadmill - Free...
Proform 775 Crosstrainer Treadmill - Free Silver Service Delivery! Logo
254 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
