Question about Creative Labs ZEN SLEEK MP3 Player
How to arrange songs
Put some songs into a folder and not have the same songs repeated in general playlist
  • 8,596 Answers
Create the playlist in Windows Media Player instead of Windows Explorer.
Posted on May 28, 2008
How do I put songs in playlist on my Coby MP620 MP3 player
The Coby is weird, but I found a way to create playlists. It might not be the "real" way, but it works :)
Before I plug the mp3 in my computer I create folders containing the songs I want for each play list. For example I'd create one folder labeled "work out" for songs I want to listen to while working out, and another folder labeled "sleep" for songs to listen to while sleeping, or you could label them based on artists or genre or etc. Then I would copy the songs I want in each playlist into their respective folders.
Next, I plug my coby into my computer, and open it's folder. (should be in computers, and have a icon with a C on it). I'd copy (or click and drag into the coby folder) my play list folders (the ones I labeled work out and sleep). Then eject and remove my mp3.
If you do this, when you turn on your mp3 you should select Music. Then select Broswer (on the bottom). Select the first row, which has the symbol "\" [underneath this is all your songs] and you'll see the names of your play list folders (they'll be below ROOT, MAC OS X Coby Me, and PHOTOS) . If you select your play list name you'll see and be able to play the songs under that playlist.
Feb 19, 2013 | Coby MP620 MP3 Player
Playing by album
To change the play mode on the GPX ML648B you need to play a song, hit the MODE button on the side of the player and select Play Mode.
The options are INTRO (this will play about 10 seconds of a song and then go on to play the next 10 seconds of every song.) NORMAL which will just continually play through everything on your device, Repeat One, which will repeat one song, FOLDER which I'm not sure of, FOLDER REPEAT which I assume repeates a folder, REPEAT ALL and RANDOM.
May 19, 2010 | GPX ML648B MP3 Player
I have downloaded a number of songs onto the player, however, only one song plays and repeats itself.
The one song that is playing may be located in a different folder on the MP3 player then the others. Check the folders on the MP3 player using your computer and verify that all the songs are on the same folder as the song that keeps repeating(probably your playlist folder)
Sep 19, 2009 | Element Electronics Audio Players &...
Unable to play playlists on my Hitachi MP3
You can try dragging the playlist into the folder that you open up when you connect the player and then you want to drag and drop music. Then drag the folder and drop into the music folder which means you are copying from the player to another folder on the player. This manages to solve the problem of the player re-arranging files alphabetically and may help your playlist issues.
Jan 28, 2009 | Hitachi DMP-7 MP3 Player
Philips GoGear SA3245 - Playlists Not Showing Up on Player
Have solved this problem on GoGear syncing with WMP 11 by going to options on the device itself, then go to the "settings" option, scroll down to "PC Connection Preferences", from here you will select the check box saying "MTP" then back out of options and connect your device and go back to your WMP 11 and drag your playlists to the syncing area and resync your device. You should then be able to see your playlists under the playlist option in music along with the "playlist on the go" playlist.
Hope this will help!
- Jared
Determan Technology LLC
Aug 31, 2008 | Philips GoGear SA3245/37 Digital Media...
Playlist creation
well u don't have to use a program for putting music on to ur mp3 player it works like a flash drive so if u go to my computer and go into the device u can put music on like that and then put wat music u want in a playlist into it's own folder and right click it then click create playlist and just to make sure u have the songs in the right order double click the playlist icon and re-arrange as u want. BUT DON"T DELETE THE FOLDER! i have done that a couple of times, when u delete the folder it, the playlist is gone. anyways hope that helps u but if it doesn't email me at
May 07, 2008 | SanDisk Sansa c150 MP3 Player
Putting music into playlist
do not ADD mp3 tracks into the playlist folder. this is not how it works. connect the player to the pc, then transfer mp3s into the MUSIC folder. Get into the foled, right click on song you want to be on playlist, and option PLAYLIST comes up. press on it and a new window will open, with playlist options. you can drag and drop mp3s in there, and so you'll have your playlist.
Jan 17, 2008 | Samsung YP-U3 MP3 Player
My 2gb yp-k3 mp3 player freezes when there is too many playlists
The answer is not to use more than 2 playlists. If you haven't upgraded the firmware you can try that.
Nov 29, 2007 | Samsung YP-K3 MP3 Player
Cant arrange songs according to my way
I used ID3-TagIT to change the album name of my songs to the name of the folder on my Sansa c250 that I want to put the songs in. Open your Sansa in My Computer, double click on Internal Memory and open the music folder. Add a new folder and name it whatever you put in for the album name of your songs. Highlight all your songs and drag and drop them into your folder. Don't use media player to sync or they end up all mixed up in different folders.
Nov 11, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
How do i put a playlist on a sansa m240
Creating Playlists on the Sansa M240
The Sansa M240 is a decent device, but if you are like many, you have not been able to create playlists. The instructions with the player and the maker’s website offer little help. Here a solution that I found on-line with some additional detail. The step by step instructions for even those with little computer savvy.
1. power up your M240 player without connecting to your computer. Scroll thru the menu to the “settings” menu. Select “USB”, deselect “auto detect” then select “MSC”. (I don’t know if this step is critical, but I picked up this suggestion from another site)
2. Power down the MP240 and using the cable supplied with your player, connect to the USB port of your computer. The display will show “MSC” when connected.
3. If you have not already done so, download the songs you want to include on your playlist from your computer to the M240. Any number of media player software packages will allow you to copy or burn your songs to a “portable media device” for this step.
4. After your songs are downloaded, on your computer, go to “My Computer” and open the "Sansa M240" icon. On the explorer task bar, select “view”> “details”. You should see several standard folders and all your songs. (Note I have used this for both .wma and .mp3 formats and have intermixed them in the playlist)
5. On your computer, open a new Notepad document and save it to your desktop.
Name it whatever you like, but it has to have “.m3u” as a file extension when you save it.
For example I named mine…. playlist1.m3u, playlist2.m3u, playlist3.m3u.
6. Next, in this newly saved notepad document, type this exactly on the very first line < #EXTM3U > without the brackets.
7. Now, find your first song in the open M240 folder, place your cursor on it, right click and select "rename". When the song title is highlighted hit control + C or "Copy" the entire title, being careful not to change anything. Now place your cursor immediately after the #EXTM3U text, hit return and paste the title of your first song directly below it with NO line space in between.
8. Repeat the steps to copy the title of your next song from the M240 folder. When copied, place your cursor immediately after the previous song title copied in the step above. Hit return Twice to create a single line space after the song title and paste in the next song title at the beginning of the line. Repeat this process til you have built your playlist.
8. After you’ve entered your last song title, it should look something like this. (Either .mp3 or .wma extensions can be used)
First song.mp3
Second song.mp3
Third song.mp3
And so on.mp3
Now, within your notepad playlist document, click File/Save (noting where it was saved) and close the file. Now, find that same original playlist on your computer. Highlight it and copy / paste it onto your M240. I copied mine into a folder called “playlist” on the M240. Then I repeated the process for other playlists, giving each a unique name.
After allowing sufficient time for the file to copy, use the icon in the lower taskbar of your computer to “safely disconnect hardware” to unplug your player. Disconnect the USB cord, power up and your ready to enjoy your playlists.
Mar 11, 2007 | SanDisk Sansa m240 MP3 Player
Creative Labs ZEN SLEEK MP3 Player Logo
61 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
