Question about Dometic Rooftop RV Air Conditioner
Remote goes blank when I turn on rear A/C unit and unit does not turn on.
  • rmerli Sep 13, 2010
    There is no battery in the remote. The remote is hard wired from the front a/c unit. Remote works fine for the front a/c unit, but not the rear unit.
  • rmerli Sep 15, 2010
    You can't turn on the a/c unit manualy only by the remote. the remote works fine for the front a/c. the remote does not have batterys The remote runs threw the front a/c unit from there it controls the rear a/c and furnace. i bypassed the front a/c and it still didn't turn on.
  • 942 Answers
This might be a thermostat problem with regards to the aircon itself. You may check the remote by replacing a battery. If and when the remote reacts by pressing the button, there should be a display setting lit up on the remote. Since you have turned on manually the aircon and nothing worked, you may check the thermostat inside of your aircon by making sure the board is connected to the thermostat. Try also to reset the remote control by removing the battery and holding the power button. Then reinsert the battery again... You may check with the technician in solving the problem...
Posted on Sep 13, 2010
  • 2,973 Answers
This happens when the battery is about to go dead. Please replace the battery of the remote.
Posted on Sep 12, 2010
I have a fujitsu a/c unit. Remote Model AR-RAH2U. If I push the on button, the a/c goes on-screen remains blank. I can not adjust the temperature or anything else. I have replaced the batteries.
seems its display and micro receiver r not working .kindly contact to your local repair man to replace remote receiver And display.
Hope answer the question
Aug 07, 2016 | Fujitsu Heating & Cooling
I have a AR-VS7 Fujitsu air conditioner that I have not used for a few weeks, I just went to turn it on but the remote screen is blank so I put in new batteries but it is still blank. Is there anyway to...
In many units no option to use manually without remote and also it's not advisable. With your statement, I conclude your remote is defective and not repairable. Replace with new remote. Helpful?
Jan 04, 2011 | Fujitsu Heating & Cooling
My Sony kp-53xbr35 Rear Projection TV screen turns green for a few seconds when I turn it on, then goes blank. Audio still works. Timer/Stand-by blinks until screen goes green, then stops, even when screen...
check the lamp out if the lamp go to this website http://www.discount-merchant.com or if the lamp is not the issue maybe can be the board in the same page you can find the parts that you maybe would nedd
regards
Dec 18, 2009 | Sony KP-53XBR45 53" Rear Projection...
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Fujitsu remote control unit /MODEL AR-RY16
my remote went blank suddenly. I replaced the batteries and nothing happened. what can I try?
Jun 07, 2008 | Fujitsu 24C1 Air Conditioner
HCM4215W 42 in. Rear Projection Television
When the screen goes blank, hit any remote function that will show up on the screen-like volume bar. If the display is missing as well, then you have a tv problem. If the volume display is there when the tv picture is not, you may require a software upgrade.
Mar 06, 2008 | Samsung HCM4215W 42" Rear Projection...
Wiring color code for xr-c5100
I am about to sell one on eBay - here are the connections from the installation paperwork and connector that I have:
Top row, left to right:
White - Front Left (+)
Green - Rear Left (+)
Purple - Rear Right (+)
Gray - Front Right (+)
Blue/White strip - AMP REMOTE (Max 0.3A)
Blue - ANT REM (Power Antennta Remote) (12V, Max 0.1A)
Red - Power (Accessory)
Black - Ground
Bottom Row, left ot right
White/Black - Front Left (-)
Green - Rear Left (-)
Purple - Rear Right (-)
Gray - Front Right (-)
BLANK
BLANK
BLANK
Yellow - Power (Battery)
One of the BLANKs is for the "Light Blue - ATT (attenuation for car phone)", but it is unclear which one. This wire is not on my connection block...
The circular BUS line to the right of the terminal block is apparently for linking to a CD/MD unit (cable supplied with unit)
The Blue 3.5mm socket is for the RM-X45 Rotary Commander (which attaches to the indicator lever)
Important notes:
If there is no ACC power line in the car, do not connect the red lead.
Ensure the power select switch on the bottom of the unit is in the B position, then press the RESET button (behind the faceplate).
This means that the display will be off when the unit is not in use - avoiding a flat battery risk.
(Posn A is for normal use, with red line on ACC)
The RESET buttom should be pressed after installation, before initial use.
Hope this helps.
Jan 08, 2008 | Sony XR-C5100 CD Changer
Dometic Rooftop RV Air Conditioner Logo
91 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
