Question about DCS DD-224C Dishwasher
Hi i have a dcs dd24, the top drawerbis not starting any cycle. Do you have a solution for that. thx
Tip
Hi! Thx for the tip! This was so helpful. My only issue was that my model didn't...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Nov 09, 2008 | Kenmore Elite 45986 Front Load Washer
I have a Fisher Paykel DD24 dishwasher and when using top drawer after wash cycle is complete there is always water in drawer. Top drawer is unable to drain water after wash cycle is complete...what can I...
If the cycle is complete and dishes are clean, then you need to worry. Try to pull the drain hose up a bit under the sink. Also buy a Finish dishwasher cleaning kit and run dishwasher as per instructions on the kit. That should clean any obsrtuctions in the drain side.
Nov 20, 2013 | Fisher and Paykel DD24DCX6 Dishwasher
Fisher and paykel drawer won't open
You can try to reset by unpluging if you have not already. The problem seems as if its the bot actuators even if it was a flood issue you could still pull open the drawers . Now i am pulling this from memory of the few i have serviced in the field so forgive if i am wrong . try holding the start and cancel button at the same time for a few seconds and this will get you into *** mode. then hit the start button this should start a fast cycle. If you can get the bottom drawer open you can get to the tech sheet in the back and trouble shoot from there. good luck
Feb 16, 2013 | Fisher and Paykel Dishwashers
Washing machine noisey when drum turning
Hi, Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 18, 2009 | GE WJSE3110A Top Load Washer
DCS gas oven door won't unlock
the problem could be the latch motor gears are stripped or stripping. try unplugging the range. push the door closed then connect power to the range. keep pressure on the door for about 1 minute then check if the door opens.
Mar 22, 2009 | DCS RGT486GLSS Gas Kitchen Range
Hi, we have a dcs 366 gas range. the pilot light for the oven went out and we can't seem to locate the pilot to re-light. the manual doesn't really go into detail for the oven...only the stove top. is this...
You don't give the model number of your DCS range, but it probably doesn't have a pilot light.
More likely it uses and electronic igniter. Internet search on "gas oven ignitor". I think this
might help you with your problem.
Mar 15, 2009 | DCS Kitchen Ranges
I have a DCS stove. I ran it through the clean cycle about a week ago and one of the glass light covers broke. Do you have replacements?
easiest way to ge that repaced is to call DCS direct, the number is in your user guide, they can ship out to you!
Mar 08, 2009 | DCS Kitchen Ranges
Dcs gas oven/range, ignitor won't go off after burner or burners are lit
They probably cleaned the stove and in replacing the parts of the burner switched the rings on top of the burner. This happened to me. While they look alike, the round rings, not the flat disks, have to be on the right burner in order for the electron spark to ignite the gas. Good luck.
Oct 29, 2008 | DCS 24-24G-1 Gas Kitchen Range
DCS DD-224C Dishwasher Logo
69 people viewed this question
Top DCS Dishwashers Experts
Sal De
Chris Huff
Chris Huff
Are you a DCS Dishwasher Expert? Answer questions, earn points and help others
