posted by saraanne on May 14, 2008
so i borrowed this from my friend and didnt really know how to use it. i filled up the tank with the water and cleaner and pressed the button and cleaned the carpet, but there is no dirty water in the recovery tank. i must have done something wrong. how do i use this thing?
Best Solution
posted on May 15, 2008
The recovery tank lid isn't locked down all of the way around. The foam filter on the inside of the tank lid is up too far, needs at leasat a 1/4 in gap from the top. The filter screen by thye indicator is clogged. Some have a duct that sits in front of the recovery tank, either it isn't there or not pushed down all of the way.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Hoover SteamVac Carpet/Upholstery
Email this problem
Email this problem
Can you Help with these Vacuums problems?
Hoover SteamVac Carpet/Upholstery Deep...
restrictive valve
restrictive valve
moments after starting the vac... Answer This...
when i fill the water
when i fill the water and soap... Answer This...
My carpet cleaner will not
My carpet cleaner will not pick... Answer This...
cant get upholstery part on
I know where part goes but... Answer This...
Hoover Steamvac Model F6020-900...
The upholstry attachment outer... Answer This...
Repair Service
Find Vacuum Repairman Near You:
