Question about Sport & Outdoor - Others
Im looking for a parts diagram for a sears & roebuck single shot 16 gauge shotgun model 101.100
4 Suggested Answers
  • 5 Answers
SOURCE: How to clean 16 Guage Model 37 Ithica Shotgun
The barrel should be all you need to clean, to do this just run a snake down the barrel and pull out the other end. Unless it is a semi-auto then you should not ever have to clean internal mechanisms.
Posted on Nov 03, 2009
Testimonial: "Thank you for your quick response. Very helpful as it kept me from trying to take apart something that is better left alone. Appreciate your time..."
  • 43 Answers
SOURCE: Have I possibly damaged my Browning 16 gauge
Europe loads 2 1/2" and 2 3/4" shells for 16 gauge shotgun as standard and the US only loads 2 3/4" shells. If your shotgun chambers the 2 3/4" shells it should be OK. You can measure the chamber and see if it measures 2 3/4". You can also check your barrel for and bulges in it by looking down the barrel with a bore light shinning down the other end. A bulge should be able to be seen with the eye. If your gun has any bulge, do not fire it again. You will need a new barrel. But It should be OK and I would not expect their to be any bulges.
Posted on Nov 14, 2009
Testimonial: "I goofed my 1st try so here goes again. Advice was very helpful to a neophyte; knowledgeable, understandable & timely---Thanks a bunch! KW "
SOURCE: broken silver tounge where you load shells into
Check the yellow pages for local gunshops,gunsmiths, or on line for the same.
Posted on Nov 21, 2009
Minnnesota model E : threading the machine?
Try Sears. A lot of brands were similar back in those days (because they copied or re-badged other brands), so finding a threading diagram for an old Singer would probably be helpful.
Sears Roebuck and their Sewing Machines
Minnesota Model given to sister in law
Instructions For Operating the Minnesota Model Sewing Machine Sears...
Apr 18, 2017 | Sewing Machines
Will the forend of a 20 guage model 148 H@R shotgun fit a 16 guage model 148 shotgun?
Nope as the 16 gauge foreend has a larger channel than the 20 gauge also the width of grip is thinner on the 20 gauge
Dec 01, 2015 | Optics
Trying to find year and manufacturer of a single shot 410 breakover shotgun. Serial number L5972 has serated area by notched site.
iver johnson single barrel champion shotguns with a single letter suffix to the serial number were manufactured between 1920 and 1929. it seem that most of the 410 were used quite a bit and very few are in excellent condition. the original finish was an oil finished stock, browned barrel and case hardened frame.
CHAMPION MODEL 36--------------------------------1909-1922
Single barrel; rebounding center mounted hammer; top lever operated break open design; gauges: 12, 16, and 20; barrel length: 28, 30, and 32 inches (features barrel and lug forged in one piece) bored full chock only; American black Walnut but* stock and fore-end; automatic extractors; weight 6¾ pounds; overall length with 30 inch barrel 45 inches; case hardened receiver (nickel available as option), browned barrel; automatic ejectors extra cost option; .410 bore, 24 and 28 gauges offered in 1913; 24 gauge dropped 1928; all gauges except 12 dropped after 1941; name changed to Champion single Barrel in 1917.
CHAMPION SINGLE BARREL---------------------------1923-1978
This is the same gun as the earlier Model 36 champion except that the smaller gauges are now built on the same frame as the large gagues. See above picture for specifications. The exact year production stopped has not yet been determined. Some of these single barrel shotguns have been seen with Canadian marking, these were most likely shipped to Canada and then marked as there is no evidence that Iver Johnson's Arms & Cycle Works ever had a manufacturing factory in Canada
Jun 01, 2015 | Optics
Iver johnson 12 gauge single shot breakdown. Serial number 7546....what is this gun worth
Would need more info these guns can range from $100 - $1000 some $5000 + depends on age, condition, model, etc... this is a good site to try and determine what you might have.... http://www.gunsinternational.com/Iver-Johnson-Shotguns.cfm?cat_id=632
Feb 23, 2015 | Optics
WHERE CAN I FIND STEVENS AND TOOL SHOTGUN PARTS
Beings you didn't give a model number, all I can do is direct you here:
http://www.gunpartscorp.com/Manufacturers/SavageStevensSpringfieldFox-33479.htm
Shotguns are the last catagory.
Oct 07, 2014 | Optics
When was my winchester model 12 16ga shotgun serial#787927 manfactured?
Nicknamed, the Perfect Repeater at its introduction, this shotgun se tthe standard for pump action shotguns throughout its fifty one (51) year high rate manufacture and production life. From 1912 until the shotgun was first discontinued by Winchester in 1963, nearly two million Model 12 shotguns were manufactured and produced in various barrel lengths and grades. Initially the M12 was chambered strictly for 20 gauge, however 12 and 16 gauge versions came out in or around 1914, and the 28 gauge version of the Winchester Model 12 came out in 1934. A .410 version was never produced; instead, a stripped down variation of the Model 12, commonly known as the Model 42, was derived directly from scaled drawings of the model 12 and produced instead. The year of manufacture for serial number 787927 is 1939. hope this helps! im pretty sure that this is right. check it out on the web.
Oct 28, 2011 | Winchester (026196062448) (20 - 60x70 mm)
I need a piston stop part#4357.00 craftsman 16 gauge finish nailer model # 351.183210, im told by sears part is not available, any other finish nailer with the same part?
same thing here, I believe it was made by porta cable looked at their nailer, looks the same trying to get that part should be around $14 plus shipping
Jul 29, 2010 | Craftsman Garden
I have an old H&R1871 Topper shotgun patened in feb
Yes you can, those old shotguns were pretty much all the same, a lot of the parts interchange, but go to gunparts.com, they have everything there, if not, find Jackfirst, He has a ton of stuff. I have the same gun right here that was my fathers, bought in 1913 for $13, almost 100 years old!!!
Feb 28, 2010 | Optics
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
