Question about HP Mini 3111000NR Netbook
Cause of low connection from broadbands?? - HP Mini 3111000NR Netbook
    Guru:
  • 689 Answers
Excessive cable lengths can return certain errors
Posted on Sep 12, 2010
Mobile phone GSM/WCDMA
gsm or cdma phone can not use broadband connection it's give low speed
May 30, 2014 | Computers & Internet
Tip
Solution on a slow Internet connections Problem  The major  causes for a slow...
The major  causes for a slow Internet connections. A poor-performing connection can be caused by broadband router configuration issues, wireless interference, or any of several other technical issues with your home network. Follow these steps to diagnose slow Internet connections.
 1. Broadband Router Settings
As the centerpiece of a network, a broadband router can be responsible for slow Internet connections if configured improperly. For example, the MTU setting of your router will lead to performance issues if set too high or too low. Ensure your router's settings are all consistent with the manufacturer's and your Internet Service Provider (ISP) recommendations. Carefully record any changes you make to your router's configuration so that you can undo them later if necessary.
 2. Wireless Signal Interference
Wi-Fi and other types of wireless connections may perform poorly due to signal interference, which requires computers to continually resend messages to overcome signal issues. Household appliances and even your neighbors' wireless networks can interfere with your computers. To avoid slow Internet connections due to signal interference, reposition your router for better performance and change your Wi-Fi channel number.
 3. Internet Worms
An Internet worm is a malicious software program that spreads through computer networks. If any of your computers are infected by an Internet worm, they may begin spontaneously generating network traffic without your knowledge, causing your Internet connection to appear slow. Run antivirus software regularly to diagnose and remove these worms from your computers.
 4. Running Background Applications
Some software applications you install on a computer run in the background, quietly consuming network resources. Unlike worms, these are programs designed to do useful work. Peer to peer (P2P) programs in particular can heavily utilize your network and cause connections to appear slow. It's easy to forget these applications are running. Always check computers for any programs running in the background when troubleshooting a slow network.
 5. Faulty Network Equipment
When routers, modems or cables fail, they typically won't support connections. Certain technical glitches in network equipment, however, adversely affect performance even though connections are maintained. To troubleshoot potentially faulty equipment, temporarily re-arrange and re-configure your gear while experimenting with different configurations. Try bypassing the router, swapping cables and changing network adapters to isolate the slow performance to a specific component of the system.
 6. Service Provider Issues
Internet speed ultimately depends on the service provider. Your ISP may change their network's configuration, or suffer technical difficulties, that inadvertently cause your Internet connection to run slow. ISPs may also intentionally install filters or controls on the network that can lower your performance. Don't hesitate to contact your service provider if you suspect they are responsible for a slow Internet connection.
 www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
I am having much difficulty upload MP3 files to my yahoo website that I am designing. They are no larger than 2MB. Is it maybe my Virgin Mobile Broadband connection? I have to upload directly from my...
You can do a check download/upload speedtest approximate speed for your "Virgin Broadband connection" @ http://www.speedtest.net/
If your upload speed is very low, then you have to talk to you ISP provider.
Hope it helps.
May 29, 2011 | HEWLETT-PACKARD HP Mini 110 101Inch Mobile...
My connection is very slow,it is smart broaband
hi there, you don't need a router for smart broadband or other wireless broadband, cause all wireless broadband is already routed, if you used a router the connection will slow down due to NAT and built firewall of your router. Option: If you want to share your internet connection to other computer, used a HUB switch this would be better. thanks
Apr 30, 2011 | Computers & Internet
I am using linksys wireless g broadband router and i cant connect to the internet it says low connection or no connectivity
I believe you would have a cable connection and no a telephone connection because if you have the second one this router will not be of use to you.
Assuming you are using a cable provider:
http://downloads.linksysbycisco.com/downloads/WRT54GC-EU_V30_UG_NC-WEB.pdf
You could see if you are following all the steps from that manual in order to configure it correctly.
Kind regards
Mar 06, 2011 | Linksys WRT54GC Compact Wireless-G...
It wont let me get internet i have cricket broadband the usb device
Hi Nicholas,
My name is Ryan and I work on behalf of Cricket. If you are experieneing issue with connecting to the internet using your Cricket broadband USB modem, please view the steps below in order to speak with a customer service member directly regarding solutions and area coverage.
Please call Cricket Broadband Customer Service Center at 1-800-CRICKET.
*Before contacting our Customer Service team, please ensure you have the following information:
-Operating system (i.e., Windows XP)
-Cricket Wireless Modem Device number (MDN) assigned to your wireless modem. To find your MDN please use the following steps:
  1. Insert the device into your computer's USB port
  2. Open Cricket Broadband Connection Manager
  3. Go to Help>About, your phone number is listed as your MDN
More FAQ and help can be found on www.Mycricket.com/support
Best,
Ryan on behalf of Cricket
Feb 15, 2011 | Nintendo Wii Console
Usb speed problem
I am not sure you can fix it there or different USB types.
  1. USB 1.0 Specified data rates of 1.5 Mbit/s (Low-Speed) and 12 Mbit/s (Full-Speed).
  2. USB 2.0 Added higher maximum speed of 480 Mbit/s (now called Hi-Speed).
Only certian motherboards have the USB 2.0..
That would seem to be the issue..
Sep 14, 2009 | Computers & Internet
Internet surfing
yes its true. computer specs gives a big factor on internet connection. even though you have a fast speed broadband but your computer is low ed. it will lead to a low opening page like when your browsing with a high definition web page but your processor, memory and graphics coudnt cooperate well to the connection. thats what we called frame per seconds or fps.
cheers
CHARCOIS
Sep 01, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Broadband 2nd Light keeps blinking yellow and then a solid red Light
Ask your Paents to ring the company they connect with it seems to be emulating a disconnection for some reason?
Sep 05, 2007 | 2wire (1000-000057-000) Modem
HP Mini 3111000NR Netbook Logo
20 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
