Question about Whirlpool Refrigerators
My Whirlpool gold model gs6nbexrb00 ice maker stopped filling the tray with water, the gears still turn like the ice maker works, but no water...
  • 90 Answers
SOURCE: Broken ice maker
Make sure icemaker cycles. If it is most likely bad water valve
Posted on Jan 05, 2008
  • 1073 Answers
SOURCE: Whirlpool Gold icemaker not working Model GD5SHAXLB02
problem with the heater or the thermastat of the ice maker
Posted on May 11, 2008
  • 55 Answers
SOURCE: Whirlpool Refrigerator Model ED25PW Ice maker tray not filling with water
  1. Check to see if water is flowing @ the water inlet valve @ the rear of the unit. You can remove it and clean if out-then put it back in service. You can purchase a new valve -- maybe @ home depot.
Posted on Aug 27, 2008
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Posted on Aug 21, 2009
woodchuck789
  • 4070 Answers
SOURCE: Whirlpool Gold Side by Side Ice maker not making ice.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Posted on Aug 31, 2009
Whirlpool Gold icemaker won't make ice
Try this and add tap water to the empty ice maker. Turn it on if off and if after the water freezes the ice maker cycles dumping the ice into ice bucket and if the ice maker does not refill with water on its own you will need to replace the=> 2188746 Water Inlet Valve
If the ice maker does nothing then replace the=>
2198597 Ice Maker Assembly
Thanks John Tripp Appliance 911
Feb 16, 2014 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
My ice maker quit, was replaced with a new one, it filled and dumped one time, filled again, didn't dump, was thawed out then didn't fill at all. Water still dispenses from the door just fine.
If the unit is new return it for another one - if there is water in the tray and it is not dumping, either the unit is not working properly or the internal freezer temperature is not going down low enough for the unit to work. Has to go down to at least 10 degrees for the tray thermostat to start the ice dump/making cycle.
Nov 28, 2013 | Whirlpool Refrigerators
Whirlpool Gold Refrigerator (GS5SHAXNLOO) Ice maker not running, some ice in maker melted together
I have the same model. This has happened to me several times (usually when the door was kept ajar without notice).
Simply open the door, take a common hairdryer and blow at high speed (hottest also) all around the area of where you can feel the ice in the tray, but hasn't dumped yet. It will usually take about 5-8 minutes of consistently moving back and forth around that area. What has happened is the lines bringing water to the trays have frozen over. When you "thaw" them out, the ice made will dump in about 45 minutes. When you hear the ice fall, you will know it's in working order again. I have NOT heard this is a "flawed" icemaker, only that it is hypersensitive to freezing lines when a door is left ajar. In your case, to prevent this from happening again. If you shut the icemaker off again, make SURE you turn off the source of the water feed BEFORE you turn off the ice maker. By doing this, the lines will empty as it makes it's last tray of water. Try that - very confident it will fix your problem!
May 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Ice Maker not filling
If your water valve is good and your filter is not in need of replacing then you probable need a new icemaker, yes.
May 12, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice Maker is not working on my Whirlpool Gold Refrigerator
I removed six screws from the ice maker to pull it out of the refrigerator.  Their are four screws holding the ice maker in place and two screws on the ice maker door.  Had problems getting the electrical harness disconnected.  Used hot water to removed the ice cubes that were struck in the ice tray.  Poured all remaining water into a bucket and re-installed ice maker.  As of now, the ice maker is making ice !
Apr 08, 2009 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Whilpool Side-by-Side ED5PHEXNQ00 Ice Maker Stopped Working. The "level" is down indicating that is needs more ice to fill the bucket, but the ice maker will not make more ice. I felt in the tray, but I...
There are 2 clips that hold the Ice plus on. 1 top left, and 1 on the right side.
Slightly pull up on the front of each clip and remove the controller. most likely behind this you will find a gear that is broken and may fall out of the unit. As usual you can not buy just the gear. Contact Whirlpool for the replacement gear assembly.
Feb 11, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Ice maker Stopped producing ice
What is sounds like is somehow either the water delievery system is clogged or frozen. If your getting water out of the door, then it is probably frozen. If you are able to turn off the freezer for a bit, that would be an easy way to see if that is the problem without having to deal with Whirlpool or a handyman.
Oct 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
May 11, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker not making ice
The same thing happened to my Whirlpool gold. Defrost it for 24 hours and the ice maker now works.
Apr 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a Whirlpool Gold side by side frige Model # GDYHA Ice maker stopped working tried to troubleshoot it but still does not work...Have any idea how to fix it. Thanks
THE ICE MAKER CYCLES WHEN THE INTERNAL THERMOSTAT REACHES 10 DEGREES. IF THE FREEZER IS WARMER THAN 10 DEGREES, FIND THE REASON FOR THE WARMING TREND.
CHECK THE ICE MAKER TO SEE IF IT HAS ICE OR WATER IN IT. IF NOT, CHECK THE FILL TUBE TO SEE IF IT IS FROZEN. REMOVE THE ICE FROM THE FILL TUBE IF IT IS FROZEN OFF. IF THE FILL TUBE IS O.K., CHECK THE WATER VALVE ON THE BACK OF THE REFRIGERATOR TO SEE IF IT HAS GOOD WATER PRESSURE COMING TO IT.
ALSO, CHECK THE FRONT OF THE ICE MAKER BEHIND THE PLASTIC COVER. THE WHITE GEAR IS SUPPOSE TO BE HELD IN PLACE WITH TWO TABS IN THE CENTER OF THE GEAR. IF ONE IS BROKEN OR BENT INWARD, THE GEAR ISN'T MAKING CONTACT WITH THE CIRCUIT BEHIND IT. THE CONTROL MODULE WOULD NEED TO BE REPLACED. OR IT MAY BE JUST AS WELL TO REPLACE THE ENTIRE ICE MAKER.
Mar 09, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
89 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
