Question about Kenwood KW85 Air Conditioner
Kenwood KW85 is noisy
I bought the Kenwood airconditioner in 2005, it has worked great. I turned the unit on today, and the airconditioner is very noisy. I tried the fan, and it works fine.
What could be the potential problem. The airconditioner looks as good as new. And, the usage is very limited, as per need.
Thanks,
Cindy
    President:
  • 2,712 Answers
Hello Cindy2,
If you havent used the machine in a while, then it is typical that it makes some noise/vibrations. It could be that there is some loose debris inside that swirls around when the fan rotates. It could also be improper ballasting...(balance) causing the vibrations. Try packing material around the sides of the machine to reduce/prevent this.
There could be some kinked/bent tubing that is touching the body when the machine is run, or it could be something like a leaking compressor.
Try the basic checks first, and if the sound persists, I would recommend calling in a technician for better diagnosis.
Hope that helps,
IrishDruid
Posted on May 14, 2008
    Genius:
  • 3,422 Answers
I completely agree with Pauldonp's solution.Unit may vibrate and make noise because of poor floor or incorrect installation.
So make sure it the unit is at the level.And another thing if the fan makes noise then the unit has to be repaired.
Anyways i have got some info which may help you out.CLICK HERE
Goodluck,
Please don't forget to rate the solution
  • 3,037 Answers
The air conditioner could just use a good cleaning. Is the noise coming from the fan or some other part that you know of?
Please get back to me with further information on this and we will see what is exactly wrong, thanks
  • Benjamin Patri
    Benjamin Patri May 21, 2008
    Have you figured out where the noise is exactly coming from, I would appreciate it if you would respond to my question as the only way for me to help you is for you to first help me. thanks
  • 4,102 Answers
Hi, have you tried moving it to somewhere else as it can be noisy depending on what type of surface its on, as this can cause it to vibrate
E4 Error Message
ok sir! are you sure is the sensor are cleaned? your unit need to general cleaning specially the sensors!
Oct 16, 2007 | Kenwood KW85 Air Conditioner
Water poring out, carpet is now a lake, cant find where pan to empty is ...please help
On page 11 of link below will tell you how to empty water tank. that is if you have the Kenwood KW85
http://www.sylvane.com/images/productpages/DeLonghi/Air-Conditioners/kw85/KW85.pdf
Good Luck end please rate
Jun 05, 2010 | Kenwood KW85 Air Conditioner
Need owners manual for a kenwood model kw85 room a/c
Visit this link: http://www.sylvane.com/images/productpages/DeLonghi/Air-Conditioners/kw85/KW85.pdf
which has it pdf format..................sodeep
May 31, 2009 | DeLonghi Kenwood KW85Portable Air...
Manual
The manual can be downloaded fee.
Here is the link:
May 18, 2009 | Kenwood KW85 Air Conditioner
Kw85 air conditioner
The unit sustained an impact during shipment and was dented on the bottom. I hammered out the dent and the condensation tank fits fine and the unit is working fine as well.
May 17, 2009 | Kenwood KW85 Air Conditioner
E3 code
http://www.sylvane.com/kenwood-kw85.html
They have the user manual for this unit under product information. It might have the info you are looking for.
Apr 24, 2008 | Kenwood KW85 Air Conditioner
Kenwood KW85 Portable Air Conditioner
Using remote control "on" the unit, then push the C button of remote control, if the C display at the unit "off" the unit using also the remote control. Unplug the power supply then plug again and start the unit using the remote control.
It the instruction above don't solve the problem, the return air sensor is out of range or the main board of the unit itself is defective. You need a qualified tech with this problem.
Oct 15, 2007 | Kenwood KW85 Air Conditioner
KENWOOD KW85 Portable Air Conditioner - NO COLD AIR
Chech if control is set to dehumidify in which case you may not get sufficient cooling also Check if control is set to fan.
Sep 03, 2007 | Kenwood KW85 Air Conditioner
Start the unit and press the remote control at C if the display in the unit displays C, then turn off the unit using the remote control and plug out the ac supply. Plug the unit again and using the remote control turn on the unit. If the E4 still display there is something wrong with your air in sensor or the main board itself. Replacement of this parts needs a qualified technician.
Aug 30, 2007 | Kenwood KW85 Air Conditioner
Kenwood KW85 Air Conditioner Logo
112 people viewed this question
Top Kenwood Heating & Cooling Experts
ray gallant
Electro Med Services...
Michael McQuay
Michael McQuay
Are you a Kenwood Heating and Cooling Expert? Answer questions, earn points and help others
