Monitor wont turn on... its completely plugged in and i tried different power cords and letting the cords cool down but it just stops working for awhile and sometimes wont go back on for weeks
  • alekberry1 Sep 13, 2010
    id like to fix the monitor though...
    Sergeant:
  • 235 Answers
Try a different monitor.
Posted on Sep 13, 2010
  • Juan Perez
    Juan Perez Sep 14, 2010
    A local tv shop might be able to do that but, quite honestly, depending on the monitor, it may be cheaper to replace it.
Marshall sd monitor wont power up
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your Monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 02, 2014 | Marshall Electronics V R84DP SD 84 144...
How do i stop auto adjusting
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 31, 2014 | Computers & Internet
Non-Stop Auto Configure
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Apr 09, 2014 | Acer X203H bd Monitor
Monitor light up then shut down itself
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 11, 2014 | Sony SDM HS93 19" LCD Monitor
My screen turns off and on... stays off for several seconds and thens turns back on... does this several times, then wont turn back on until I unplug the power cord and replug.??? Unit is about 1.5 yrs...
Before we start taking things apart, lets try your simple remove power plug routine and power system back up. Also, please try your unit on a few different channels to see if your problem continues on each channel. Your Main Board, Power Board, T-Control Board are suspected problems at this time. Press and hold the power button for about 15 seconds, the unit should power down by itself after you have powered it on. If it does not, then do not be concerned. Let me know if the problem continues. The first link below will bring you directly to the troubleshooting guide if you need to continue forward with the same error. Additional information http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com
Jan 20, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
Old Gateway system (Desktop), Celeron 800MHz. After being on for 30min to an hour, operating system quits. Monitor displays first "no input" then "power saving" and will indefinitely keep cycling between...
sounds like its an over heating issue,i would check the fans to make sure they are all working and clean.Check that the cpu has thermal paste and that it still good(if its stiff or crumbles when you take off the heatsink it needs to be replaced)also check the memory is seatted all the way in.
Sep 01, 2010 | Gateway (683728192730) Barebone
Monitor wont power back on, Tried almost everything. Some days it will power up , sometimes is wont. If my timing is perfect and I plug the monitor into power cord at exact time I turn on computer it will...
Hello Adam,
You have a monitor with a power supply that is failing. The most likely cause is capacitors on the power supply board. We have an article posted on our site at: http://www.ccl-la.com/blog/index.php/capacitors/ That explains what they are and what you need to get to repair the board. If you don't want to do the repair yourself then we do offer a repair service, more information on this can be found at:http://www.ccl-la.com/blog/index.php/service-request-form/ If you have any questions please contact us thru our web site.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Mar 14, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Toshiba wont power on
try turning off and then remove battery and plug in a/c cord.turn back on..still nothing let me knowRICHARDM69
Aug 24, 2009 | Toshiba Satellite A135 Notebook
L1932TQ LCD Monitor won't turn on.
I'm affraid you did about everything you can to find the issue. Trying to isolate the problem is the best way to come close to a solution eventually. But after all the tests you did, it seems that the monitor itself got a problem. I dont suggest you to try to fix it yourself, some electrical parts may need to be electrically discharged before being removed from the monitor. If your monitor is still in waranty, contact LG for support. Otherwise, you could bring it to a local tv/monitor store to see if they can repair it. LG support rep could also give you some advice, maybe they got a certified partner in your area that could take a look at it. P.S. If your computer is on windows XP it should shut down the usual way just by pressing the power button once. The shutdown will be the same as if you go Start->Shutdown->Shutdown the computer.
Jun 03, 2009 | LG L1932TQ LCD Monitor
Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
