Drain line has slime, howto clean? - Heating & Cooling
  • 144 Answers
Bleach you pour bleach down the drain about 4 oz per month
Posted on Sep 12, 2010
Why is under counter ice maker storage bin holding water when unplugged.
There may be slime in the drain line clogging it up... needs to be blown out
Apr 25, 2014 | Kenmore 51lb. Clear Ice Maker
Green slime around rubber and drum that won't come clean. I did 3 maintance washes with bleach and let them air dry and still green slime around rubber and drum of washe. It stinks. I even used a small...
I don't even know if this is possible on your machine but see if you can get bleach into your water intake port, if the green slime still shows up you may need to contact your board of health because it sounds as if the problem is your incoming water and you may need to have your water company clean their pipes or even replace them, did you perchance loose water pressure before the slime became a problem?
Dec 07, 2009 | LG WM2688HWM TROMM SteamWasher
There is water collecting at the bottom of the refrigerator under the vegetable bins.
you have a clogged defrost drain located in the freezer,u can shut the refrigerator off with doors open for 24 hours to allow the drain inlet to thaw on its own,if problem reoccurs within 1 week chances are you will need a technician to install a drain heater kit
Nov 27, 2009 | KitchenAid Refrigerators
Refrigerator keeps defrosting and depositing water in fridge.
if your food is staying cold your fridge is working fine,you probably have a blocked drain.you will find water under criper draws and maybe leaking out on floor,take off the back freezer wall and take out floor, melt out the drain and remove all the ice on freezer floor,now you have to clean out the drain,i use a steamer that you can buy for like 40 bucks,it's a shark super steamer,it will clean out all the slime that builds up in the drain line or you have to snake out the drain line with a plastic tie or something,when you think you cleaned out the line pour hot water into the drain and if the water goes down you know you unclogged it,you can buy a heater probe that installs down the drain and wraps around the heater so the line can't freeze up again,if this is not your problem you can advance the timer in the fridge side on the ceiling by turning it with a screw driver until it comes out of defrost and if it was sticking or not coming out of defrost on it's own change the timer the new part number for your timer is 2183400 hope this helps
Nov 24, 2009 | Refrigerators
Water is leaking from the top of my whirlpool refrigerator, what is the cause of this and how do I repair it ?
You have a icemaker? turn off its water supply, does the water stop leaking then?? Else is condensation from no frost mode which gets bad if your freeser/refrig door leaks air. shut door on sheet of paper drag paper up and down seals top and bottom if resistance is vacant in any seal area FIX IT. You can slightly REFORM a warped door be gentle! CLEAN SEAL AREAS FIRST
Nov 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a GE fridge model TFB26PPDABB that is leaking from the bottom left on the freezer side. The bottom of the freezer is a sheet of ice. Please help
you have a blocked drain,melt out ice with hair dryer,then go to the back wall.on the bottom you'll see a holeyou might have to take wall off,that's where the water drains when the machine defrosts,i use a steamer to clean out the drain,it's a shark super steamer costs around 40 bucks but you can use a long plastic wire tie or something to snake through the drain line,slime builds up in the drain or a piece of food or anything could be in there,when you think you melted and cleaned the drain pour hot water in drain,if it goes down your done
Nov 17, 2009 | GE Refrigerators
My Whirlpool et9ftk refrigerator keeps pouring water from the freezer into the fridge portion what is going on?
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
Nov 08, 2009 | Whirlpool ET9FTKXK Top Freezer...
Kenmore Refrigerator, water forming on glass shelves then freezing, little ice around the thermostate gauge area, banging sound once in a while.
next time send model number and say where the freezer is located top, bottom side by side,if it's a top mount,could be blocked drain,take back wall off in freezer,melt out ice under the evap coil with hair dryer, then i use a steamer to clean out drain line,slime forms in the drain and usually has to be blown out if you have some kind of plastic water line or something you can stick in and blow out that line,or try pooring hot water down drain,after you get it to drain call the local parts store and get a heater probe,this will keep the line from clogging in the future,hope this helps
Nov 07, 2009 | Kenmore Refrigerators
Rv a/c drain water becomes slime
Use a shop vac( wet/dry vaccum) and as you clean the coils use the vaccum to remove the slime and debris. This slime is caused by particles in the air that has been drawn into the coil during a/c usage. To prevent this slime from continuing to build up you can use a tablespoon of bleach and pour it into the drainage pan this will kill all the algae producing bacteria and will keep your a/c condensate drain in tip top shape. Hope this helps Good Luck
Dave
Aug 06, 2009 | Heating & Cooling
Freezer is defrosting water coming down side
Your defrost drain for the condensate is blocked somewhere on its path to the condensate evaporation pan below your refrigerator. The tray begins in the back of freezer at bottom of the evaporator coil. The tray may have a bad seal or have ice blocking the drain entrance. Unplug and locate the blockage remove and clean the opening and flush water with a little Clorox down the line to help to dislodge any algae or slime. Wet vac May Help. Measure flow to see that drain then works properly...Sea Breeze
Jun 21, 2009 | Refrigerators
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
