SOURCE: cannot get the angelcare baby monitor to reset so
press the menu button once, then use the arrows until only the face is displayed (for sound sensing only), press select, and then the centre button.
SOURCE: Baby Monitor False Alarm Problem
You can try adjusting the sensitivity on back of the nursery unit. But the most major thing I found was to ensure the sensor pad was on a firm surface. I used a large piece of cardboard from a flattened box. Angel Care recommends plywood or similar but the cardboard worked perfect for me. Put the sensor on top of the cardboard and then the mattress on top of that. The sensor should also be placed according to directions (under child approx center of mattress).
SOURCE: Angelcare monitor Model #AC420-P no
Had exactly the same problem but this worked. Never even realised there was a button on the top of the unit!!! It looks like a little LED at the base of the hoop. Happy monitoring.
CONNECTING THE PARENTS UNIT TO THE NURSERY UNIT:
If you lose the connection between the 2 units,turn them both off. Turn ON the parents unit and
press and hold the MENU button ,the "out of range"indicator will flash and you will hear a
beep.Turn ON the nursery unit and press and hold the top button of the nursery unit to reconnect.
The Tic light flashes.This normally happens within a few seconds and you will hear a bleep
to confirm it. If successful, the parents unit display will first show the channel of transmission (C1
to C8), which will be replaced by the room temperature and icons for all activated functions.
Note : The connecting process should be done within 30 seconds. If longer, the operation will be
ignored and you will have to start over.
• PAGING: If you want to locate the parents unit, press the top button of the nursery unit.
