Question about Watches
Removing a link from my Timex (1854) Perpetual calendar watch
I have followed the instructions I found here in FixYa that said to use a push pin and small hammer to 'knock out' the pins on this watch band which I did and it worked perfectly. My watch now fits snugly and I'm very happy to found this site.
Thanks,
JohnW
(pcprntr)
Palm Coast, FL
pgh_pa_guy
  • 2992 Answers
SOURCE: changing the date on a timex perpetual calendar watch
You can download the Perpetual Calendar instructions from Timex's website here.
If you don't like clicking on a link, here's the URL:
http://assets.timex.com/instructions/perpetualCal.pdf
Hope this helps. If this solution has been what you needed, please take a moment to rate it a fixya, and thanks for asking here!
Posted on Mar 11, 2009
escapement
  • 2334 Answers
SOURCE: Can not figure out how to remove links from Casio watch band
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Apr 01, 2009
escapement
  • 2334 Answers
SOURCE: How do I get the pins out of the titanium band for Casio PAW1500T
Job done!
Posted on Jul 09, 2009
escapement
  • 2334 Answers
SOURCE: Perpetual Calendar 100M, Ineed the instruction
Follow this link and click on OPERATIONAL GUIDE.
http://www.seikousa.com/#FAQ
Rate, please.
Posted on Jul 29, 2009
reyjoshua07
  • 1157 Answers
SOURCE: the date is advance by
Hi isengard03,
Setting the day on your Timex analog watch is a simple process. Please follow the steps below.
Multi-Function Models
1. Pull the crown on the side of the watch case all the way out. This will be position "C," with position "A" having the crown pushed all the way in and position "B" being pulled out halfway.
2. Turn the crown clockwise until the correct day appears on the small face displaying the day.
3. Press the crown all the way in, to position "A."
Chronograph Models
1. Pull out the crown on the side of the case to position "B." This is halfway out. You will feel a slight click when the crown is in position "B."
2. Turn the crown clockwise until the watch face shows the correct day.
3. Push the crown all the way into position "A" to complete the process.
Hope it helps.
Thank you for using FixYa.
Posted on Aug 15, 2011
The date is advance by one day its a perpetual calendar timex watch
Hi isengard03,
Chronograph Models
Hope it helps.
Aug 15, 2011 | Timex T Series Perpetual Calendar #T2M458...
I need an owners instruction sheet to learn how to set dATE & TIME.
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Feb 06, 2011 | Timex Expedition Perpetual Calendar...
Model no cr2016 cell timex 1854 can't change the date
Thank you for contacting FIxYa.
You can get instructions/manual at the following link:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
By the way, that is not the style # of watch, that is battery type.
Best regards. Jewel
Sep 10, 2010 | Watches
I cannot set the calendar for this watch...can anyone help me?
mcdevito75 here, Your watch (Timex) may have a 2 position stem. Push the stem (winder) all the way in, NOW just lift the stem a little to it:s first position, this should allow the date, (number ) to change, change that number to the date before the date you want, NOW pull the stem out to set the hands, rotate the hands to set proper date and time.
Jun 28, 2010 | Timex T Series Perpetual Calendar #T2M458...
Rate, please.
Jul 29, 2009 | Seiko Coutura Perpetual Calendar Watch
Changing the date on a timex perpetual calendar watch
Mar 11, 2009 | Timex Watches
Greetings: I recieved a timex perpetual calendar watch for Christmas. No box, no instructions for setting the day and date. It's obviously smarter than me. I would appreciate it so much, if you could give...
http://www.timex.com/gp/node/n/255235011/178-1795200-7359408?ie=UTF8&timexBrand=core
This link will take you to the official Timex page where you can download the instruction manuals for any of their watches.
Dec 31, 2008 | Watches
Watches Logo
1,848 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
