Question about McCulloch 26cc Gas Blower Mcb3208
Re McCulloch MB3202 gas blower: My blower will idle "forever", but as soon as I try speeding up, the engine dies. Apparently it is not getting enough fuel. Is the fuel reservoir filter clogged and blocks the flow of fuel, or is it the carburator?
4 Suggested Answers
  • 4 Answers
SOURCE: Carb adjustment on McCulloch 32cc?
the l is for idle and the h is for top end but thats not ur problem it sounds like ur carb is clogged there is a screen inside of the carb the fuel gets crystalized and blocks off some and sometimes all of the fuel ill bet thats the problembut u can try the adjustments first give the unit full throttle and turn the h adjustment screw in and or out till it sounds great and at full power if that dont work then do the screen in the carb
Posted on Nov 14, 2008
  • 1584 Answers
SOURCE: I have a McCulloch MB3202 back pack blower that
Must have good strong blue spark
Must have correct fresh fuel / oil mix.
Must have air. Check for leaks at intake manifold.
Can you use choke to keep it running, if so air leak OR lack of fuel.
Posted on Jan 08, 2010
  • 150 Answers
SOURCE: I have a mcculloch backpack
I am assuming the carburetor is ok. Check your spark arrestor. This is a screen located at muffler exit. Usually just a screw holds it in, pull it out with a pair of pliers and clean or replace. I usually hold it with pliers and burn it clean with a little bernzamatic torch. If that doesn't fix it probably a carburetor problem.
Posted on Oct 14, 2010
Mcculloch MB3202 32cc gas blower it will run for 10 to 20 mins or so then shuts off it seems that it's getting to warm then shuts off it will start back up but then shuts off again. Why is this doing that?
You could be running the oil gas mixture with not enough oil. The high speed jet could be running the engine lean. The cooling air thru the engine could be blocked by debris/leafs.
Oct 21, 2014 | Garden
Is the kill switch an open switch or is it closed,on the MB3202 McCulloch leaf blower
most units they ground out the coil to kill the engine
Aug 11, 2012 | Garden
I have a McCulloch M # MB3202 Backpack blower what`s it worth is it worth repairing ?
I can see cheap parts on amazon, so take a look... Amazon com mcculloch blower parts I hope this was helpful. cheers
May 05, 2012 | Garden
I have a mcculloch backpack mb3202 that I run but can not speedup.It wants to quit. The carburator is adjusted okay, but I cannot speed it up! What do I do?
Oct 14, 2010 | McCulloch Garden
I have a McCulloch MB3202 back pack blower that will not stay running. I have pulled carburetor and cleaned and reassembled. Replaced fuel filter and lines. I can get running if I use starter fluid for a...
Jan 08, 2010 | McCulloch Garden
Dies when i give it gas
Sounds like your carburetor either needs cleaned or the needles need adjusted. Try turning them just a bit and continue trying to accelerate the engine. If your carb has adjustable needle screws, one will be the low speed adjustment and the other will be the high speed adjustment. You'll know when you have the right one when the motor starts to run just a bit better after adjusting the correct one.
Nov 14, 2009 | Garden
Spark plug
The User Manual States .025" (.635mm)
Apr 05, 2009 | McCulloch 26cc Backpack Blower with Dual...
Nov 12, 2008 | McCulloch 26cc Backpack Blower with Dual...
McCulloch 32cc backpack leaf-blower
Mcculloch MB3202 anti-vibration back pack leaf blower, runs better at the middle setting of the choke than it does if it's wide open the way it should be. Can't get it to blow leaves well. Owners manual lost. ANY ADVICE???????? New gas, spark plug starts on the first pull but just doesn't give out like it should.
Nov 07, 2008 | McCulloch 26cc Backpack Blower with Dual...
McCulloch 26cc Gas Blower Mcb3208 Logo
193 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
