Question about Philips Magnavox 20MT4405 20" TV
Magnavox 19PRC1 My set has lost its horizontal controls. I get great sound but just lines most of the time. Sometimes, for a few seconds, I actually get a picture, but most of the time just scrolling lines. There's no controls on the back and no visible way to get into the Tv.
3 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: magnavox 19prc1 0121
There aren't any adjustments anymore. This can happen as parts inside age and values change. Also solder connections can fail over time and cause problems. The problem you describe can be in any of several areas of the set. There really isn't anything you can do yourself to repair this. If you want to keep the TV you can get an estimate for repair, but this might be a good time to check out sale prices on new TV's and think about replacing it.
Posted on Dec 16, 2008
  • 668 Answers
SOURCE: magnavox ts2543 with a single horizontal line
Most Probably the Vertical Output IC has failed. If it has, it also could cause resistors that supplt the +/- Voltages to the IC to fail as well.
Hope this helps,
Skyassoc
Posted on Jun 20, 2009
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
My (2) Philips Magnavox 27TS54 C101 have lost the picture accept for one white horizontal line.
Hi Dean,
White horizontal line then the unit automatically shuts off with a led blinking on the front panel is an indication of faulty vertical deflection circuitry.
The most common faulty parts is the vertical deflection IC (TDA9302H) itself. This IC is mounted on the aluminum heat sink near the flyback transformer. You have to replaced it with new one to resolve the issue. Click HERE to have an idea how much it will cost for the parts.
Hope I helped you.
Good luck and take care!
Jdvillanueva
Jan 11, 2012 | Philips Televison & Video
1990 magnavox has a horizontal line running accross still has sounds of the movie. cost approx?
sometimes a leaky primary line filter could caused this type of defect,have a qualified technician for servicing
Jul 18, 2011 | Philips Magnavox 20MT133S 20" TV
My Magnavox plasma screen tv, model number: 42MF237S/37 makes a clicking sound when I try to turn it on. No sounds, no picture, just the clicking noise. Things I have tried so far: 1) Turning the TV off...
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Jan 03, 2010 | Philips Magnavox 27MS343S 27" TV
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Magnavox 19" LCD TV: no sound
it sounds like a dry joint,where the solder cracks if you tap it on the side and it alters its state then you have to locate this cracked solder and re solder,sometimes not visible though
Jul 19, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Toshiba TV CX2789K Horizontal Line
Failure in the vertical deflection amplifier section. This is usualy from failed components, and sometimes cold solder connections. Most of the time, I found bad capacitors, and sometimes the output IC or transistors (depending on the model type) that have failed.
Take the set to a service center for an estimate. You may find it more feasible to buy a new set depending on the parts that failed and the time involved to do the work.
Jerry G.
Apr 14, 2008 | Televison & Video
Horizontal lines on my monitor
Lines on screens are usually caused by damage to the ribbons on the actual screen face itself (something only a few professional lcd repair shops can repair).
Sometimes caused by a bump, other times from over-wetting when cleaning, or dampness/moisture issues
The inverter-power board does Not control picture, It just controls the backlight bulbs and powering the video board.
Picture is powered from the video display board.
Jan 20, 2008 | Gateway FPD2275W LCD Monitor
Magnavox 19prc1 0121
Nov 11, 2007 | Philips Magnavox 20MT4405 20" TV
Phillips/Magnavox 9P5544C102 white raster and shuts down
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
May 29, 2007 | Philips 9P5544C 55" Rear Projection...
Philips Magnavox 20MT4405 20" TV Logo
54 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
