Question about VeriFone 250 Matrix Printer
Verifone 250 keys not striking paper, any way to adjust this
The Verifone 250 doesn't have keys. What are you talking about?
If you mean that it just isn't printing, verify that the ribbon is properly inserted and the impact setting is correct.
Posted on Jul 02, 2008
Cutting of bottom of letters
Really, you have a typewriter?
You stop typing before you reach the end. If it is the electronic type with a display, you need to set the paper size to the size of paper you are using.
If you are using a computer and word processing program, again, set the paper size.
Oct 01, 2015 | Office Equipment & Supplies
How do you feed the paper in to verifone v510?
Ensure thermal paper is being fed from underneath the roll, as it will only print on one side of the paper. hope this help :-)
Feb 07, 2012 | VeriFone Omni 3700
Reloading paper in the verifone 3730
place thermal paper roll
pull the end of paper roll over the printer
and
close the lid.
tear off excess paper
http://www.gorillapaper.com/verifone-vx510-le.html
May 13, 2010 | VeriFone (M19755014US1) Magnetic Card...
How do I reset the time on a VeriFone 3730 omni510? It did not change with the spring time change. Thanks for your help
Simultaneously press [F2] & [F4].Key in 1, Alpha, Alpha, 66831 and press [Enter].Key in the Year, the Month and the Day and then press [Enter]. Do not press [Enter] between these values, the terminal will automatically populate the appropriate fields as they are entered. Use the down arrow to scroll down to check/adjust the time.y in the hour, using military format (ex: 3 p.m. = 15), then key in the minutes and press [Enter] to complete and return to Menu 1. Do not press [Enter] between these values, the terminal will automatically populate the appropriate fields as they are entered.Select Restart [F4].I hope this help don't forget to rate this post : - )
Apr 19, 2010 | VeriFone Omni 3700
Drivers for a verifone 250 printer in winxp
You can try to find it at this link
http://verifone.50webs.com/
Dec 18, 2008 | VeriFone 900 Matrix Printer
I have a VeriFone Printer 250 and the paper will not feed and the power light is blinking....I have turned it off and on and it still does not work. HELP!
I had the same problem - I took out the ribbon and tightened it, put it back in and replaced the cover securely. Then I disconnected the power and turned the switch off. I plugged it back in, switched it on, and the problem was gone.
Dec 15, 2008 | VeriFone PRINTER 250 RS232C INTERFACE
Spits out Paper
This is an internal problem that can only be repaired by a Verifone service center or company with verifone service experiance.
Nov 12, 2008 | VeriFone 900 Matrix Printer
Spits out extra paper
This is a VERY common problem for these printer models and occurs as the terminal ages. This is caused by a faulty paper feed sensor and needs to be sent in to an authorized service center to have the sensor replaced and paper feed adjusted.
Sorry it wasn't better news, but at least it can be repaired fairly inexpensively. Good luck!
Aug 30, 2008 | VeriFone 900 Printer
Inserting Paper into Verifone Credit Card machine
I do not have a pictur eor video but it is not difficult. Open printer door, place paper in printer with the paper coming out towards the keys of the terminal from underneath the roll. Pull slacked paper over keys of terminal and shut printer door.
Aug 21, 2008 | VeriFone Omni 3700
Using a Verifone P250 Printer with a PC Credit Card Program
which one ? i have tried all also the cable i have is a serial 25 pin female so i got a adapter to serial male still wont print can anyone help ?p250 to pc windows xp
Dec 19, 2007 | VeriFone 250 Matrix Printer
VeriFone 250 Matrix Printer Logo
175 people viewed this question
Top VeriFone Office Equipment & Supplies Experts
George Mclaughlin
Willie Cooper
Willie Cooper
Are you a VeriFone Office Equipment and Supply Expert? Answer questions, earn points and help others
