Question about Panasonic Televison & Video
My Panasonic projection TV, model pt51g43c ,is about 10 years old and hardly been used. Suddenly it is out of focust, looks like double images on the screen. TV Manual indicates it may be " convergence adjustment " and I tired to adjust it from the SET-Up menu ,but the red and blue cross on the screen just won't move. Any suggestion ? The repair and parts must be costly , should I just dumped it ?
  • Anonymous Dec 15, 2008
    42 inch same problem color blue all over the screen
  • Panasonic Master
  • 8,617 Answers
That repair will cost about 50 dollars if you do it yourself. Go to this link and they will let you know what ICs your model takes just leave them the model number and ask for the number STK Convergence ICs you need. They also provide free instalation instructions with pictures with their replacement ICs so you can do the job yourself. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 15, 2008
My collors are not focust, the collors are not on one line. i see double subtitles
Please rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 09, 2011 | Samsung HC-P4741W 47" Rear Projection...
My 54" rear projection Panasonic TV is turning off and the TV repairman says that it's the transformer. Right now he is looking for a transformer and said that to keep my fingers crossed. Is getting a...
What is model number? If it shuts off does the power light on the front blink?
Without knowing model number and if power light is blinking or not it is hard to help.
SD TECH
Sep 21, 2010 | Panasonic Televison & Video
Blurry picture on left side double image right side is ok....
Ur convergence is dead,need convergence kit.
U know how to solder right?Tries these websites for convergence kit.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com
Sep 25, 2009 | Zenith IQB50M90W 50" Rear Projection...
I have a Panasonic 53" projection tv approx 4 or 5 years old. I have double images what is the problem?
Convergence problem.
Replace STK 392-110, check any resistor around stk.
Thank you
Aug 05, 2009 | Panasonic Televison & Video
Like the blue color is gone and see a double image now
You should have a TV repairman look at your set to see if you have a bad tube in the set, It might just be a convergence ishue, if thats the case it might be worth fixing.
Dec 15, 2008 | Panasonic PT-53WX42 53" Rear Projection...
I have a Panasonic HDTV Projection PT-47WX42 with double imaging.
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 17, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Red tinted double image above the normal image.
hello consumer MG,
you need to change your STK392-110. Replacing those 2 chip will fix your set.
best regards
circuitcity
www.interactiverepair.com
Jun 08, 2008 | Panasonic PT-51HX40 51" Rear Projection...
Panasonic 52"problem
You need to change the two convergence IC's - Generic part# STK392-110, Panasonic part# C5AA00000203. You might have problems using the generic #, I would use the Panasonic #
Sep 26, 2007 | Toshiba 46HM95 46" HDTV
Projection Tv Problem
some of these tvs have internal adjustments for everything including alignment which fixes the double image problem. if you remove the cover you will find a lot of little adjustment dials. you may find that they have symbols that show what the adjustment is for. if you want more info. email me at sb1216us@yahoo.com
Sep 23, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
103 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
