Question about Microsoft LifeCam VX-6000 Webcam
Microsoft WDM Image Capture (Win32), Version: 6.0.6001.18000 doesnt work properly although its installed from the drivers cd .....my laptop version is fujitsu siemens.......Esprimo mobile v6505
  • 10,421 Answers
My cam doesnt work because the drivers is omitted my laptop is 10342 msi
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or update driver xp
click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7
software if you dont have the driver you will need to download one here are a few you could try although i could not find one for windows 7
Some webcams and programs require additional software, although that should be installed with the webcam if things are right.
But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date.
But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing.
Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10).
http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer
hope this helps
Aug 20, 2012 | MSI Dc Jack Power For Ms-1039ms-10342b...
I have problems with my ACER Aspire 6930 labtop whereby the following devices:- Network controller, SM Bus Controller; AVer DVD EZmaker-WDM Video Capture & Intell (R) 82852 GM are not active, as such...
Download the drivers from the Acer WEB site. Make sure youselect the model of your laptop and the XP or Vista version of the drivers youthat require and it matches the Windows version that is installed on yourlaptop. Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Jan 24, 2011 | Computers & Internet
C;\Documents and Settings\admin\My Documents\downloads\Silverlight.exe is not a valid win32 appplication
HI,
causes for these problems are:
1. File is corrupt, bad, or missing.
2. File is not designed for your version of Windows.
3. File is a virus, worm, or other malware file.
4. Hardware incompatibility.
Step 1: Verify that the program installation CD is clean. If the CD is dirty or bad, you could get this error during the install and/or get this error after the program has been installed because it was not copied properly onto the computer.
Step 2: Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors.
Step 3: If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
· If the program is an older MS-DOS program or early Windows program you may get this error.
· If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
Step 4: Run an online scan for any threat and try to fix them
http://onecare.live.com/site/en-Us/center/cleanup.htm
Thanks and regards
Nandy
Oct 26, 2010 | Microsoft Computers & Internet
Adcom tv tuner driver of multimedia controller
A driver can be downloaded from DriverGuide.com
http://members.driverguide.com/driver/detail.php?driverid=1281766&action=download
Also Supports: AD-TV878R - ADCOM TV/CAPTURE -, Bt848 Video Capture Device, Bt849 Video Capture Device BtTuner, Temic WDM TvTuner, BtTuner, Philips WDM TvTuner (PAL BG), BtTuner, Alps WDM TvTuner, BtXBar, WDM Crossbar, BtCap, WDM Video Capture, Bt878 Fusion Capture Device - Video Section, BtTuner, Philips WDM TvTuner (PAL I) Manufactured By: Other Companies, Brooktree Corporation, Conexant, Brooktree File Name: PCTV.rar (6.5 MB) -------------
If required register for free donload, driver is available on that forum
Kind regards
Jul 21, 2010 | Adcom GCD-750 CD Player
How to download this driver microsoft WINMM WDM audio compatibility driver free download with file version 5.1.2600.5512
What you are referring to is part of Windows Media Player. WDM is simply Windows Driver Model. The WINMM refers to Windows MultiMedia. If you download and install the latest version of Windows Media Player for your operating system, it should resolve any issues you are having with it.
Jul 10, 2009 | Computers & Internet
Driver problems with OEM 7130AA WDM Video Capture device (Phillips chipset)
Hi.
Use this to update your drivers
http://rapidshare.com/files/149632922/Driver_Scanner.rar
Hope this helps.
Regards
Faraz
Oct 14, 2008 | Philips TV Tuner Video Capture PCI Card -...
Invalid win32 program
this might be at the first look a problem of the softwere you are using...maybe your windows cd is damaged and it doesnt install properly..try to instal another version fisrt of all..and after check the main board drivers..
anyway..nice board you heva there..
Feb 03, 2008 | EPoX EP-8RDA3I Pro Motherboard
WDM capture driver install
Hello heatheriac, Your NVIDIA drivers for WDM are here: http://www.nvidia.com/object/wdm_winxp-2k-Me-98se_2.20.html I have used the same card with these drivers, and have had no issues. Please let us know how it works for you, and if you need any additional information. Best regards, nightdiver
Sep 01, 2006 | AOpen Aeolus FX5900ULTRA-DVC256 (256 MB)...
Microsoft LifeCam VX-6000 Webcam Logo
1,602 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
